[AVR单片机]
串口中断通信
745|5
小风车|  楼主 | 2015-8-26 09:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我用的是ATMEga64A的芯片,想用串口做一个通信程序,但是不能接受和发送,这是程序,求各位大神帮忙指点一下
#include  "math.h"
#include  "iom64v.h"
#include  "main.h"
#include  "AVRdef.h"
#include  "uart.h"
#include <macros.h>
//#pragma interrupt_handler UART0_RX_interrupt:10 UART0_TX_interrupt:11
#pragma interrupt_handler UART0_RX_interrupt:iv_USART0_RXC
#pragma interrupt_handler UART0_TX_interrupt:iv_USART0_TXC
/* UART Buffer Defines */
#define UART0_RX_BUFFER_SIZE 128 /* 1,2,4,8,16,32,64,128 or 256 bytes */
#define UART0_RX_BUFFER_MASK ( UART0_RX_BUFFER_SIZE - 1 )
#define UART0_TX_BUFFER_SIZE 128 /* 1,2,4,8,16,32,64,128 or 256 bytes */
#define UART0_TX_BUFFER_MASK ( UART0_TX_BUFFER_SIZE - 1 )
#if ( UART0_RX_BUFFER_SIZE & UART0_RX_BUFFER_MASK )
#error RX buffer size is not a power of 2
#endif
/* Static Variables */
static unsigned char UART0_RxBuf[UART0_RX_BUFFER_SIZE];
static volatile unsigned char UART0_RxHead;
static volatile unsigned char UART0_RxTail;
static unsigned char UART0_TxBuf[UART0_TX_BUFFER_SIZE];
static volatile unsigned char UART0_TxHead;
static volatile unsigned char UART0_TxTail;
void Delay(int t)
         while(t--);
void delay_ms(unsigned int time)
    unsigned int  t=0;
        for( ;t<=1000*time;t++);
void IO_Configuration(void)
      // PORTE=(0<<PE0);
        // DDRE=(0<<DDE0);
      // PORTE=(0<<PE1);
      // DDRE=(1<<DDE1);
     // PORTD=(0<<PD3)|(0<<PD2);
      // DDRD=(1<<DDD3)|(0<<DDD2);
/* initialize UART */
void InitUART0( unsigned char baudrate )
        unsigned char x;
        UBRR0H=(unsigned char)(baudrate>>8);
        UBRR0L=(unsigned char)baudrate; /* set the baud rate */
        /* enable UART receiver and transmitter, and
        receive interrupt */
       UCSR0B=( (1<<RXCIE0) | (1<<RXEN0) | (1<<TXEN0) );
       UCSR0C=(1<<USBS0)|(3<<UCSZ00);
        x = 0; /* flush receive buffer */
        UART0_RxTail = x;
        UART0_RxHead = x;
        UART0_TxTail = x;
        UART0_TxHead = x;
/* interrupt handlers */
void UART0_RX_interrupt( void )
        unsigned char data;
        unsigned char tmphead;
        data = UDR0; /* read the received data */
        /* calculate buffer index */
        tmphead = ( UART0_RxHead + 1 ) & UART0_RX_BUFFER_MASK;
        UART0_RxHead = tmphead; /* store new index */
        if ( tmphead == UART0_RxTail )
                /* ERROR! Receive buffer overflow */
        UART0_RxBuf[tmphead] = data; /* store received data in buffer */
void UART0_TX_interrupt( void )
        unsigned char tmptail;
        /* check if all data is transmitted */
        if ( UART0_TxHead != UART0_TxTail )
                tmptail = ( UART0_TxTail + 1 ) & UART0_TX_BUFFER_MASK;
                UART0_TxTail = tmptail; /* store new index */
                UDR0 = UART0_TxBuf[tmptail]; /* start transmition */
        else
                UCSR0B &= ~(1<<UDRIE0); /* disable UDRE interrupt */
/* Read and write functions */
unsigned char ReceiveByte0( void )
        while ( UART0_RxHead == UART0_RxTail ) /* wait for incomming data */
        tmptail = ( UART0_RxTail + 1 ) & UART0_RX_BUFFER_MASK;/* calculate buffer index */
        UART0_RxTail = tmptail; /* store new index */
        return UART0_RxBuf[tmptail]; /* return data */
void TransmitByte0( unsigned char data )
        tmphead = ( UART0_TxHead + 1 ) & UART0_TX_BUFFER_MASK;
                /* wait for free space in buffer */
        while ( tmphead == UART0_TxTail )
        UART0_TxBuf[tmphead] = data; /* store data in buffer */
        UART0_TxHead = tmphead; /* store new index */
        UCSR0B |= (1<<UDRIE0); /* enable UDRE interrupt */
unsigned char DataInReceiveBuffer0( void )
        return ( UART0_RxHead != UART0_RxTail );
                /* return 0 (FALSE) if the receive buffer is empty */
void main(void)
    IO_Configuration();//
    InitUART0( 6 );
    _SEI();
while(1)
                TransmitByte0( ReceiveByte0() ); /* echo the received character */
ningling_21| | 2015-8-26 10:05 | 只看该作者
多用例程实验
小风车|  楼主 | 2015-8-26 10:15 | 只看该作者
我就是在例程上改的
小风车|  楼主 | 2015-8-26 10:16 | 只看该作者
我就是在例程上该的
ningling_21| | 2015-8-26 10:46 | 只看该作者
小风车 发表于 2015-8-26 10:16
我就是在例程上该的
有些程序功能跟芯片内部的熔丝配置有关
qin552011373| | 2015-8-26 13:28 | 只看该作者
自己也不仔细对下datasheet看看register对不对。
