哪位大虾讲解一下stm32f10x_vector.s的构成
5372|4
 楼主| lpdyd 发表于 2008-4-8 10:37 | 显示全部楼层 |阅读模式
哪位大虾讲解一下stm32f10x_vector.s的构成,越详细越好吧,呵呵.至少给大家"领读"一遍.
;******************** (C) COPYRIGHT 2007 STMicroelectronics ********************
;* File Name          : stm32f10x_vector.s
;* Author             : MCD Application Team
;* Version            : V1.0
;* Date               : 10/08/2007
;* Description        : This module performs:
;*                      - Set the initial SP
;*                      - Set the initial PC == Reset_Handler,
;*                      - Set the vector table entries with the exceptions ISR address,
;*                      - Branches to __main in the C library (which eventually
;*                        calls main()).
;*                      After Reset the CortexM3 processor is in Thread mode,
;*                      priority is Privileged, and the Stack is set to Main.
;* <<< Use Configuration Wizard in Context Menu >>>
; THE PRESENT SOFTWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
; WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
; AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
; INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
; CONTENT OF SUCH SOFTWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
; INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
; Amount of memory (in bytes) allocated for Stack and Heap
; Tailor those values to your application needs
;// <h> Stack Configuration
;//   <o> Stack Size (in Bytes) <0x0-0xFFFFFFFF:8>
;// </h>
Stack_Size       EQU     0x00000400
                 AREA    STACK, NOINIT, READWRITE, ALIGN=3
Stack_Mem        SPACE   Stack_Size
__initial_sp
;// <h> Heap Configuration
;//   <o>  Heap Size (in Bytes) <0x0-0xFFFFFFFF:8>
;// </h>
Heap_Size        EQU     0x00000200
                 AREA    HEAP, NOINIT, READWRITE, ALIGN=3
__heap_base
Heap_Mem         SPACE   Heap_Size
__heap_limit
                 THUMB
                 PRESERVE8
                 ; Import exceptions handlers
                 IMPORT  NMIException
                 IMPORT  HardFaultException
                 IMPORT  MemManageException
                 IMPORT  BusFaultException
                 IMPORT  UsageFaultException
                 IMPORT  SVCHandler
                 IMPORT  DebugMonitor
                 IMPORT  PendSVC
                 IMPORT  SysTickHandler
                 IMPORT  WWDG_IRQHandler
                 IMPORT  PVD_IRQHandler
                 IMPORT  TAMPER_IRQHandler
                 IMPORT  RTC_IRQHandler
                 IMPORT  FLASH_IRQHandler
                 IMPORT  RCC_IRQHandler
                 IMPORT  EXTI0_IRQHandler
                 IMPORT  EXTI1_IRQHandler
                 IMPORT  EXTI2_IRQHandler
                 IMPORT  EXTI3_IRQHandler
                 IMPORT  EXTI4_IRQHandler
                 IMPORT  DMAChannel1_IRQHandler
                 IMPORT  DMAChannel2_IRQHandler
                 IMPORT  DMAChannel3_IRQHandler
                 IMPORT  DMAChannel4_IRQHandler
                 IMPORT  DMAChannel5_IRQHandler
                 IMPORT  DMAChannel6_IRQHandler
                 IMPORT  DMAChannel7_IRQHandler
                 IMPORT  ADC_IRQHandler
                 IMPORT  USB_HP_CAN_TX_IRQHandler
                 IMPORT  USB_LP_CAN_RX0_IRQHandler
                 IMPORT  CAN_RX1_IRQHandler
                 IMPORT  CAN_SCE_IRQHandler
                 IMPORT  EXTI9_5_IRQHandler
                 IMPORT  TIM1_BRK_IRQHandler
                 IMPORT  TIM1_UP_IRQHandler
                 IMPORT  TIM1_TRG_COM_IRQHandler
                 IMPORT  TIM1_CC_IRQHandler
                 IMPORT  TIM2_IRQHandler
                 IMPORT  TIM3_IRQHandler
                 IMPORT  TIM4_IRQHandler
                 IMPORT  I2C1_EV_IRQHandler
                 IMPORT  I2C1_ER_IRQHandler
                 IMPORT  I2C2_EV_IRQHandler
                 IMPORT  I2C2_ER_IRQHandler
                 IMPORT  SPI1_IRQHandler
                 IMPORT  SPI2_IRQHandler
                 IMPORT  USART1_IRQHandler
                 IMPORT  USART2_IRQHandler
                 IMPORT  USART3_IRQHandler
                 IMPORT  EXTI15_10_IRQHandler
                 IMPORT  RTCAlarm_IRQHandler
                 IMPORT  USBWakeUp_IRQHandler
; Fill-up the Vector Table entries with the exceptions ISR address
                 AREA    RESET, DATA, READONLY
                 EXPORT  __Vectors
__Vectors        DCD  __initial_sp              ; Top of Stack
                 DCD  Reset_Handler
                 DCD  NMIException
                 DCD  HardFaultException
                 DCD  MemManageException
                 DCD  BusFaultException
                 DCD  UsageFaultException
                 DCD  0                 ; Reserved
                 DCD  0                 ; Reserved
                 DCD  0                 ; Reserved
                 DCD  0                 ; Reserved
                 DCD  SVCHandler
                 DCD  DebugMonitor
                 DCD  0                 ; Reserved
                 DCD  PendSVC
                 DCD  SysTickHandler
                 DCD  WWDG_IRQHandler
                 DCD  PVD_IRQHandler
                 DCD  TAMPER_IRQHandler
                 DCD  RTC_IRQHandler
                 DCD  FLASH_IRQHandler
                 DCD  RCC_IRQHandler
                 DCD  EXTI0_IRQHandler
                 DCD  EXTI1_IRQHandler
                 DCD  EXTI2_IRQHandler
                 DCD  EXTI3_IRQHandler
                 DCD  EXTI4_IRQHandler
                 DCD  DMAChannel1_IRQHandler
                 DCD  DMAChannel2_IRQHandler
                 DCD  DMAChannel3_IRQHandler
                 DCD  DMAChannel4_IRQHandler
                 DCD  DMAChannel5_IRQHandler
                 DCD  DMAChannel6_IRQHandler
                 DCD  DMAChannel7_IRQHandler
                 DCD  ADC_IRQHandler
                 DCD  USB_HP_CAN_TX_IRQHandler
                 DCD  USB_LP_CAN_RX0_IRQHandler
                 DCD  CAN_RX1_IRQHandler
                 DCD  CAN_SCE_IRQHandler
                 DCD  EXTI9_5_IRQHandler
                 DCD  TIM1_BRK_IRQHandler
                 DCD  TIM1_UP_IRQHandler
                 DCD  TIM1_TRG_COM_IRQHandler
                 DCD  TIM1_CC_IRQHandler
                 DCD  TIM2_IRQHandler
                 DCD  TIM3_IRQHandler
                 DCD  TIM4_IRQHandler
                 DCD  I2C1_EV_IRQHandler
                 DCD  I2C1_ER_IRQHandler
                 DCD  I2C2_EV_IRQHandler
                 DCD  I2C2_ER_IRQHandler
                 DCD  SPI1_IRQHandler
                 DCD  SPI2_IRQHandler
                 DCD  USART1_IRQHandler
                 DCD  USART2_IRQHandler
                 DCD  USART3_IRQHandler
                 DCD  EXTI15_10_IRQHandler
                 DCD  RTCAlarm_IRQHandler
                 DCD  USBWakeUp_IRQHandler
                 AREA    |.text|, CODE, READONLY
; Reset handler routine
Reset_Handler    PROC
                 EXPORT  Reset_Handler
                 IMPORT  __main
                 LDR     R0, =__main
                 BX      R0
                 ENDP
                 ALIGN
; User Stack and Heap initialization
                 IF      :DEF:__MICROLIB
                 EXPORT  __initial_sp
                 EXPORT  __heap_base
                 EXPORT  __heap_limit
                 ELSE
                 IMPORT  __use_two_region_memory
                 EXPORT  __user_initial_stackheap
                 LDR     R0, =  Heap_Mem
                 LDR     R1, =(Stack_Mem + Stack_Size)
                 LDR     R2, = (Heap_Mem +  Heap_Size)
                 LDR     R3, = Stack_Mem
                 BX      LR
                 ALIGN
                 ENDIF
                 END
;******************* (C) COPYRIGHT 2007 STMicroelectronics *****END OF FILE*****
香水城 发表于 2008-4-8 10:40 | 显示全部楼层
文件里的注释已经再清楚不过了
除非你不会看英文:
              - Branches to __main in the C library (which eventually calls main()).
 楼主| lpdyd 发表于 2008-4-9 10:11 | 显示全部楼层
还是斑竹牛啊!
还是斑竹牛啊!
qiuzhi2010ncepu 发表于 2014-5-21 13:47 | 显示全部楼层
都是牛人一两枚,大家加油。
戈卫东 发表于 2014-5-21 17:55 | 显示全部楼层
好像真的不需要讲解。。。。。
那些符号本身就已经说明了它自己是什么。。。。。。
