STM32101运行频率设置问题
3096|1
 楼主| pb486 发表于 2008-7-1 11:52 | 显示全部楼层 |阅读模式
我的STM32101运行频率设置如下:
   ErrorStatus HSEStartUpStatus;
    // RCC system reset(for debug purpose)
    RCC_DeInit();
    // Enable HSE
    RCC_HSEConfig(RCC_HSE_ON);
    // Wait till HSE is ready
    HSEStartUpStatus = RCC_WaitForHSEStartUp();
    if(HSEStartUpStatus == SUCCESS)
        // HCLK = SYSCLK
        RCC_HCLKConfig(RCC_SYSCLK_Div1);
        // PCLK2 = HCLK
        RCC_PCLK2Config(RCC_HCLK_Div1);
        // PCLK1 = HCLK/2
        RCC_PCLK1Config(RCC_HCLK_Div2);
        // Flash 1 wait state 24MHZ < SYSCLK << 48MHZ
        FLASH_SetLatency(FLASH_Latency_1);
        // Enable Prefetch Buffer
        FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
        RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_6); // HSE=6MHZ
        // Enable PLL
        RCC_PLLCmd(ENABLE);
        // Wait till PLL is ready
        while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
        // Select PLL as system clock source
        RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
        // Wait till PLL is used as system clock source
        while(RCC_GetSYSCLKSource() != 0x08)
问一下,上面的设置对吗? RCC_PCLK1Config(RCC_HCLK_Div2)可以设置成
RCC_PCLK1Config(RCC_HCLK_Div1)吗
ST_ARM 发表于 2008-7-2 10:03 | 显示全部楼层
可以
因为APB1、2的最大频率为36MHz。
