[应用相关] 请问香主,用STM32的硬件编码器如何扩展成32位?
24680|61
梦翔青春 发表于 2015-7-31 19:02 | 显示全部楼层
auzxj 发表于 2010-4-26 13:13
您的这种方法依然规避不了我7楼的那种情况吧,计数器正向加,然后溢出,假如溢出后又累加了N个数,若此时 ...
请问一下,能否看看我的代码错在哪里,编码器没反应
梦翔青春 发表于 2015-7-31 19:05 | 显示全部楼层
auzxj 发表于 2010-4-27 16:30
我在这里写了篇学习笔记,有兴趣的可以看下:http://blog.**/auzxj/1473143/message.aspx ...
#include"zjbmq.h"
void ENC_Init(void)
        TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
        TIM_ICInitTypeDef TIM_ICInitStructure;
        NVIC_InitTypeDef NVIC_InitStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);//使能TIM3
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
        GPIO_StructInit(&GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
        TIM_DeInit(TIM3);
        TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
        TIM_TimeBaseStructure.TIM_Prescaler = 0; //设置预分频:
        TIM_TimeBaseStructure.TIM_Period = (4*1000)-1;;
        TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
        TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
        TIM_EncoderInterfaceConfig(TIM3, TIM_EncoderMode_TI12,
                             TIM_ICPolarity_Rising, TIM_ICPolarity_Rising);
        TIM_ICStructInit(&TIM_ICInitStructure);
        TIM_ICInitStructure.TIM_ICFilter = 6;
        TIM_ICInit(TIM3, &TIM_ICInitStructure);
        // Clear all pending interrupts
        TIM_ClearFlag(TIM3, TIM_FLAG_Update);
        TIM_ITConfig(TIM3, TIM_IT_Update, ENABLE);
        //Reset counter
        TIM3->CNT = 0;
        TIM_Cmd(TIM3, ENABLE);
s16 ENC_Get_Electrical_Angle(void)
        static u16   lastCount =0;
        u16 curCount = TIM3->CNT;
        s32 dAngle =curCount - lastCount;
        if(dAngle >= 500)
                  dAngle -=1000;
        else if(dAngle < -500)
                   dAngle += 1000;
        lastCount = curCount;
        return (s16)dAngle;
请问一下我代码哪里改错了,怎么编码器没反应呀,谢谢啦
梦翔青春 发表于 2015-7-31 19:08 | 显示全部楼层
请问一下我的代码哪里出问题了,编码器没反应谁能帮帮我,感谢感谢。
#include"zjbmq.h"
void ENC_Init(void)
        TIM_DeInit(TIM3);
        //Reset counter
        TIM3->CNT = 0;
        if(dAngle >= 500)
                  dAngle -=1000;
                   dAngle += 1000;
        return (s16)dAngle;
冰冷的游客 发表于 2015-8-10 14:01 | 显示全部楼层
心染红尘 发表于 2015-10-8 22:20 | 显示全部楼层
lxyppc 发表于 2010-4-23 23:12
这个是我经常用的编码器读取方法
s16   Enc_GetCount(void)
这个MAX_COUNT的值如何求得?
tianhaolan 发表于 2016-1-14 11:29 | 显示全部楼层
这个MAX_COUNT的值如何求得?
根据你的编码器的最大旋转速度算出来的。比如说,你的编码器最大旋转速度是1秒钟10圈(这里就是为了好计算,一般没有转这么快的编码器),通过另一个定时器来定时的话,如果定时器取10mS的话就是0.1圈也就是36°。如果分辨率是1000的编码器0.1圈的话会计数1000*4*0.1=400下,那么你这个MAX_COUNT就要取得比这个400还要大一些,比如500或者600都行。
zhenglingo 发表于 2016-2-26 11:53 | 显示全部楼层
非常好的设计。用一个定时器10MS定时读取编码器值也不会占用CPU很多时间,还是可以干其他事的,只是要将定时器中断优先级提升。
940126mc 发表于 2016-5-5 16:19 | 显示全部楼层
我是刚接触stm32,要用其做光栅尺数显表设计,光栅尺输出A,B两路信号我接到stm32的PA6和PA7,如何实现测距呢,显示部分已做出来,计数部分不懂,光栅尺分辨率5um,量程200mm,求教
SantaBunny 发表于 2023-2-23 19:54 | 显示全部楼层
搞个计数器溢出中断
Pretext 发表于 2024-4-4 15:54 | 显示全部楼层
为什么我们要反过来做? 我们不能再做一次吗?
香水城 发表于 2024-4-5 09:27 | 显示全部楼层
很难有完美的方法,编码器的加和减是基于硬件识别的。
第2级定时器只能基于溢出事件【更新事件】进行加,不能再减了。
要减的话在第一级就已经减了,而且第2级减1就不是减1个计数脉冲了,而是减掉前级的ARR+1个脉冲。
童雨竹 发表于 2024-7-1 08:26 | 显示全部楼层
会使二极管导通
Wordsworth 发表于 2024-7-1 09:29 | 显示全部楼层
对于电力电路来说串联的电阻起阻尼作用
Clyde011 发表于 2024-7-1 10:32 | 显示全部楼层
甚至会造成模块电源的损坏
公羊子丹 发表于 2024-7-1 11:25 | 显示全部楼层
将ESD静电保护二极管并联于电路中
万图 发表于 2024-7-1 12:28 | 显示全部楼层
电阻阻值大小则需根据元器件可承受电流大小而决定
Uriah 发表于 2024-7-1 13:31 | 显示全部楼层
小型电子设备
帛灿灿 发表于 2024-7-1 15:27 | 显示全部楼层
电阻元件的电阻值大小一般与温度,材料,长度,还有横截面积有关
Bblythe 发表于 2024-7-1 16:30 | 显示全部楼层
灌封之前需要使用抽空机进行天然脱泡和真空脱泡预处理
周半梅 发表于 2024-7-1 18:26 | 显示全部楼层
当电压超过二极管的导通电压的时候
