STR912的I2C读写24C16
3911|2
 楼主| SkyCode 发表于 2009-4-10 10:36 | 显示全部楼层 |阅读模式
请香版主跟哪位用过STR912的同仁指点一下
代码如下:
函数名:EEPROM_I2CInit()
void EE_I2CInit(void)
  I2C_InitTypeDef   I2C_Struct;
  /* Peripherals enable */
  SCU_APBPeriphClockConfig(__I2C1,ENABLE);
  I2C_DeInit(I2C1);
  /* I2C0 Configuration */
  I2C_Struct.I2C_GeneralCall = I2C_GeneralCall_Disable;
  I2C_Struct.I2C_Ack = I2C_Ack_Enable;
  I2C_Struct.I2C_CLKSpeed = 400000;
  I2C_Struct.I2C_OwnAddress = 0xA0;
  I2C_Init(I2C1, &I2C_Struct);
  //I2C_AcknowledgeConfig(I2C1,ENABLE);
  /* Enable I2C0, I2C1 */
  I2C_Cmd(I2C1, ENABLE);
*函数名:EE_WriteOneByte()
*功能描述:向E2的指定地址写入一个字节的数据
void EE_WriteOneByte(u16 adr,u8 dat)
    u8 addresstemp=0;
    //I2C_AcknowledgePolling();
    GPIO_WriteBit(GPIO0,GPIO_Pin_4,Bit_RESET);
    addresstemp=adr>>8;
    addresstemp=(((addresstemp&0x07)<<1)&0xfe)|0xa0;
       I2C_GenerateStart(I2C1, ENABLE);
    /* Test on EV5 and clear it */
    while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT));
     /* Send RTC address for write */
    I2C_Send7bitAddress(I2C1, addresstemp, I2C_MODE_TRANSMITTER);
    /* Test on EV6 and clear it */
    while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECTED));
       I2C_SendData(I2C1,(u8)adr);
    /* Test on EV8 and clear it */
    while(! I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
       I2C_SendData(I2C1,dat);
    I2C_GenerateSTOP(I2C1,ENABLE);
功能描述:向E2的随机地址读出一个字节的数据
u8 EE_ReadOneByte(u16 adr)
    unsigned char addresstemp=0;
    unsigned char result = 0;
    GPIO_WriteBit(GPIO0,GPIO_Pin_4,Bit_SET);
    addresstemp=adr>>8;
       I2C_GenerateStart(I2C1,ENABLE);
       I2C_SendData(I2C1,  ( u8)adr);
    while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
     /* Send RTC address for read */
      I2C_Send7bitAddress(I2C1, addresstemp, I2C_MODE_RECEIVER);
     while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_RECEIVED));
        result = I2C_ReceiveData(I2C1);
     __nop();
     //I2C_AcknowledgeConfig(I2C1, DISABLE);
        return   result;
在主程序中:
 只要我读取24C16中的一个随机地址的数据后,单片机就不能再对24C16进行读或者写操作了
每当我读取数据后,看到i2c的SR1寄存器的值为0x9A,其中第四位为BUSY被置1了,
可能就是这个原因导致我下面不能正常读写了
我每次读的子程序后面都会有一个 I2C_stop()执行,怎么还会有BUSY呢
香版主指点一下,谢谢   期待您的回复
 楼主| SkyCode 发表于 2009-4-10 11:05 | 显示全部楼层
很奇怪
在向24C16中写数据后,执行I2C_GenerateSTOP(I2C1,ENABLE);后看到寄存器I2C1->CR中的 stop位是0,这个好像是硬件自动清0的
但是执行了从24C16中读取数据后吧,执行I2C_GenerateSTOP(I2C1,ENABLE);后看到I2C1->CR中的 stop位是1,
不知道为什么会出现这个原因
晕乎乎  走过的路过的都来看看是怎么回事啊
是我的读子程序有问题吗
 楼主| SkyCode 发表于 2009-4-13 14:55 | 显示全部楼层
香主帮忙
香主,您能帮俺看看吗
每次读操作后  总线怎么着都busy    下面的操作没有办法继续了
只好重新初始化I2C  汗!!
