| 在执行./ltib后,出现error,进入/ltib/ltib/host_config.log 下查看: .....................
 Processing: wget
 Build path taken because: no prebuilt rpm,
 rpmbuild --dbpath ///opt/freescale/ltib/var/lib/rpm --target i686 --define '_unpackaged_files_terminate_build 0' --define '_target_cpu i686' --define '__strip strip' --define '_topdir /opt/freescale/ltib/usr/src/rpm' --define '_prefix /opt/freescale/ltib/usr' --define '_tmppath /home/zhouh/work/ltib/ltib/tmp' --define '_rpmdir /opt/freescale/ltib/usr/src/rpm/RPMS'  --define '_mandir /opt/freescale/ltib/usr/share/man' --define '_sysconfdir /opt/freescale/ltib/etc' --define '_localstatedir /var' -bb --clean --rmsource  /home/zhouh/work/ltib/ltib/dist/lfs-5.1/wget/wget.spec
 Building target platforms: i686
 Building for target i686
 gen_sslfunc.o: In function `init_ssl':
 gen_sslfunc.c:(.text+0x351): undefined reference to `SSLv2_client_method'
 collect2: ld returned 1 exit status
 make[1]: *** [wget] Error 1
 make[1]: Leaving directory `/opt/freescale/ltib/usr/src/rpm/BUILD/wget-1.9.1/src'
 make: *** [src] Error 2
 error: Bad exit status from /home/zhouh/work/ltib/ltib/tmp/rpm-tmp.93719 (%build)
 RPM build errors:
 Build time for wget: 13 seconds
 Failed building wget
 Died at ./ltib line 1392.
 traceback:
 main::build_host_rpms:1392
 main::host_checks:1447
 main:554
 Started: Sat Oct 17 19:34:40 2015
 Ended:   Sat Oct 17 19:34:54 2015
 Elapsed: 14 seconds
 These packages failed to build:
 wget
 Build Failed
