[AVR单片机] AVR时分秒,数码后面的
709|0
 楼主| 524464881 发表于 2015-12-20 21:18 | 显示全部楼层 |阅读模式
数码管不该亮度的段位,都有暗光,请问是什么原因?
#include <iom16v.h>
#include <macros.h>
#define uchar unsigned char
#define uint  unsigned int
#pragma interrupt_handler miao:9
char num=0,fen=0,shi=0;
#pragma data:code
const  SMG[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d, 0x07,
                           0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x40};
const key[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
void ld(uchar i,uchar j)
  PORTB=0Xff;
  PORTA|=BIT(1);
  PORTB=SMG;
  PORTA&=~BIT(1);
  PORTB=0XFF;
  PORTA|=BIT(4);
  PORTB&=~BIT(j);
  PORTA&=~BIT(4);
  delay(3);
void lde(uchar i,uchar j)
  PORTB=0Xff;
  PORTA|=BIT(1);
  PORTB=key;
  PORTA&=~BIT(1);
  PORTB=0XFF;
  PORTA|=BIT(4);
  PORTB&=~BIT(j);
  PORTA&=~BIT(4);
  delay(1);
void delay(uint ms)
  uint i,j;
  for(i=0;i<ms;i++)
    for(j=0;j<1000;j++);
void miao()
   if(num==59)
     num=-1;
         if(fen==59)
             fen=-1;
           if(shi==23)
             shi=-1;
           shi++;
           fen++;
         num++;
  TCNT1H=0X48;
  TCNT1L=0XE4;
void timer_init()
  TCCR1B=0X04;
  TCNT1H=0X48;
  TCNT1L=0XE4;
  TIMSK|=BIT(2);
  SREG|=BIT(7);
void main()
  DDRB=0XFF;
  DDRA|=0X12;
  timer_init();
  while(1)
    ld(shi/24,0);
    ld(shi%24,1);
        lde(6,2);
    ld(fen/10,3);
    ld(fen%10,4);
        lde(6,5);
    ld(num/10,6);
        ld(num%10,7);
