28335 cmd
972|3
 楼主| lixglixg 发表于 2015-12-24 16:30 | 显示全部楼层 |阅读模式
大神帮忙看看
MEMORY
PAGE 0 :
   /* BEGIN is used for the "boot to SARAM" bootloader mode      */
   BEGIN      : origin = 0x000000, length = 0x000002     /* Boot to M0 will go here                      */
   RAMM0      : origin = 0x000050, length = 0x0003B0
   RAML0      : origin = 0x008000, length = 0x001000
//  RAML1      : origin = 0x009000, length = 0x001000
//   RAML2      : origin = 0x00A000, length = 0x001000
//  RAML3      : origin = 0x00B000, length = 0x001000
   RAML1_3      : origin = 0x009000, length = 0x003000
   ZONE6A     : origin = 0x100000, length = 0x010000    /* XINTF zone 7 - program space */
   CSM_RSVD   : origin = 0x33FF80, length = 0x000076     /* Part of FLASHA.  Program with all 0x0000 when CSM is in use. */
   CSM_PWL    : origin = 0x33FFF8, length = 0x000008     /* Part of FLASHA.  CSM password locations in FLASHA            */
   ADC_CAL    : origin = 0x380080, length = 0x000009
   RESET      : origin = 0x3FFFC0, length = 0x000002
   IQTABLES   : origin = 0x3FE000, length = 0x000b50
   IQTABLES2  : origin = 0x3FEB50, length = 0x00008c
   FPUTABLES  : origin = 0x3FEBDC, length = 0x0006A0
   BOOTROM    : origin = 0x3FF27C, length = 0x000D44
PAGE 1 :
   BOOT_RSVD  : origin = 0x000002, length = 0x00004E     /* Part of M0, BOOT rom will use this for stack */
   RAMM1      : origin = 0x000400, length = 0x000400     /* on-chip RAM block M1 */
   RAML4      : origin = 0x00C000, length = 0x001000
   RAML5      : origin = 0x00D000, length = 0x001000
   RAML6      : origin = 0x00E000, length = 0x001000
   RAML7      : origin = 0x00F000, length = 0x001000
   ZONE6B     : origin = 0x120000, length = 0x000400     /* XINTF zone 7 - data space */
SECTIONS
   codestart        : > BEGIN,     PAGE = 0
   ramfuncs         : > RAML0,     PAGE = 0
   .text            : > ZONE6A,     PAGE = 0 //提示错误
   .cinit           : > RAML1_3,     PAGE = 0
   .pinit           : > RAML1_3,     PAGE = 0
   .switch          : > RAML1_3,     PAGE = 0
   .stack           : > RAMM1,     PAGE = 1
   .ebss            : > RAML4,     PAGE = 1
//  .econst          : > RAML5,     PAGE = 1
   .esysmem         : > RAMM1,     PAGE = 1
   IQmath           : > ZONE6A,     PAGE = 0   //提示错误
   IQmathTables     : > IQTABLES,  PAGE = 0, TYPE = NOLOAD
   /* Uncomment the section below if calling the IQNexp() or IQexp()
      functions from the IQMath.lib library in order to utilize the
      relevant IQ Math table in Boot ROM (This saves space and Boot ROM
      is 1 wait-state). If this section is not uncommented, IQmathTables2
      will be loaded into other memory (SARAM, Flash, etc.) and will take
      up space, but 0 wait-state is possible.
   IQmathTables2    : > IQTABLES2, PAGE = 0, TYPE = NOLOAD
              IQmath.lib<IQNexpTable.obj> (IQmathTablesRam)
   FPUmathTables    : > FPUTABLES, PAGE = 0, TYPE = NOLOAD
   DMARAML4         : > RAML4,     PAGE = 1
   DMARAML5         : > RAML5,     PAGE = 1
   DMARAML6         : > RAML6,     PAGE = 1
   DMARAML7         : > RAML7,     PAGE = 1
   ZONE6BDATA        : > ZONE6B,    PAGE = 1   //提示错误
   .reset           : > RESET,     PAGE = 0, TYPE = DSECT /* not used                    */
   csm_rsvd         : > CSM_RSVD   PAGE = 0, TYPE = DSECT /* not used for SARAM examples */
   csmpasswds       : > CSM_PWL    PAGE = 0, TYPE = DSECT /* not used for SARAM examples */
   /* Allocate ADC_cal function (pre-programmed by factory into TI reserved memory) */
   .adc_cal     : load = ADC_CAL,   PAGE = 0, TYPE = NOLOAD
尤彼卡 发表于 2015-12-24 21:46 | 显示全部楼层
zhangmangui 发表于 2015-12-24 22:33 | 显示全部楼层
参考
 楼主| lixglixg 发表于 2015-12-25 13:08 | 显示全部楼层
谢谢,解决了,编译器问题。
