2357|0
吕萌|  楼主 | 2007-4-3 13:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
 if key_ch_release = '1' then  -- released => return to idle
          release <= '1';
          state   <= ST_IDLE;
        elsif cntr = REPEAT_START - 1 then  -- timeout =>
          cntr  <= (others => '0');
          press   <= '1';
          state <= ST_REPEAT;
        end if;
这是用VHDL写的,但是这没有else,会产生latch吗?用Verilog怎么翻译过来,
还有other=>0,是所有输出都为0吗????
Please answer!!!
Thanks thanks.
best regdards!
