[Atmel] 跑一下XMEGA-B1程序(9)RTC模块
1972|2
 楼主| ddllxxrr 发表于 2015-12-29 06:45 | 显示全部楼层 |阅读模式
今天跑一下RTC模块,工程还用上次的不用建了。
首先加入RTC模块。然后从ASF EXPLORER中找到快速指导,打开,上边有提示,按照提示往下进行就可以。
需要注意的是,在CLOCK.h中一定要设为32K的晶振。
#define CONFIG_SYSCLK_SOURCE SYSCLK_SRC_RC32KHZ
#define CONFIG_RTC_SOURCE SYSCLK_RTCSRC_ULP
  1. #ifndef CONF_CLOCK_H_INCLUDED
  2. #define CONF_CLOCK_H_INCLUDED
  3. //#define CONFIG_SYSCLK_SOURCE          SYSCLK_SRC_RC2MHZ
  4. //#define CONFIG_SYSCLK_SOURCE        SYSCLK_SRC_RC32MHZ
  5. #define CONFIG_SYSCLK_SOURCE        SYSCLK_SRC_RC32KHZ
  6. //#define CONFIG_SYSCLK_SOURCE        SYSCLK_SRC_XOSC
  7. //#define CONFIG_SYSCLK_SOURCE        SYSCLK_SRC_PLL
  8. /* Fbus = Fsys / (2 ^ BUS_div) */
  9. #define CONFIG_SYSCLK_PSADIV          SYSCLK_PSADIV_1
  10. #define CONFIG_SYSCLK_PSBCDIV         SYSCLK_PSBCDIV_1_1
  11. //#define CONFIG_PLL0_SOURCE          PLL_SRC_XOSC
  12. //#define CONFIG_PLL0_SOURCE          PLL_SRC_RC2MHZ
  13. //#define CONFIG_PLL0_SOURCE          PLL_SRC_RC32MHZ
  14. /* Fpll = (Fclk * PLL_mul) / PLL_div */
  15. //#define CONFIG_PLL0_MUL             (24000000UL / BOARD_XOSC_HZ)
  16. //#define CONFIG_PLL0_DIV             1
  17. /* External oscillator frequency range */
  18. /** 0.4 to 2 MHz frequency range */
  19. //#define CONFIG_XOSC_RANGE XOSC_RANGE_04TO2
  20. /** 2 to 9 MHz frequency range */
  21. //#define CONFIG_XOSC_RANGE XOSC_RANGE_2TO9
  22. /** 9 to 12 MHz frequency range */
  23. //#define CONFIG_XOSC_RANGE XOSC_RANGE_9TO12
  24. /** 12 to 16 MHz frequency range */
  25. //#define CONFIG_XOSC_RANGE XOSC_RANGE_12TO16
  26. /* DFLL autocalibration */
  27. //#define CONFIG_OSC_AUTOCAL_RC2MHZ_REF_OSC  OSC_ID_RC32KHZ
  28. //#define CONFIG_OSC_AUTOCAL_RC32MHZ_REF_OSC OSC_ID_XOSC
  29. /* The following example clock configuration definitions can be used in XMEGA
  30. * devices that contain a USB controller. It configures the USB controller clock
  31. * source to use the internal (nominally) 32MHz RC oscillator, up-calibrated to
  32. * run at 48MHz via the periodic 1ms USB Start Of Frame packets sent by the
  33. * host. The USB controller requires 48MHz for Full Speed operation, or 6MHz
  34. * for USB Low Speed operation.
  35. *
  36. * Note that when the 32MHz RC oscillator is tuned to 48MHz, it cannot be used
  37. * directly as the system clock source; it must either be prescaled down to a
  38. * speed below the maximum operating frequency given in the datasheet, or an
  39. * alternative clock source (e.g. the internal 2MHz RC Oscillator, multiplied
  40. * to a higher frequency via the internal PLL module) must be used instead.
  41. */
  42. #define CONFIG_USBCLK_SOURCE                USBCLK_SRC_RCOSC
  43. //#define CONFIG_OSC_RC32_CAL                 48000000UL
  44. //#define CONFIG_OSC_AUTOCAL_RC32MHZ_REF_OSC  OSC_ID_USBSOF
  45. /* Use to enable and select RTC clock source */
  46. #define CONFIG_RTC_SOURCE           SYSCLK_RTCSRC_ULP
  47. #endif /* CONF_CLOCK_H_INCLUDED */
在RTC.h中定义好:
# define CONFIG_RTC_PRESCALER RTC_PRESCALER_DIV1024_gc
那么下列小程序就可运行了:
  1. #include <asf.h>
  2. uint32_t ddd;
  3. int main (void)
  4. {
  5.         /* Insert system clock initialization code here (sysclk_init()). */
  6.         //sysclk_init();
  7.
  8.
  9.         sysclk_init();
  10.         //board_init();
  11.         rtc_init();
  12.
  13.         while(1)
  14.         {
  15.         ddd = rtc_get_time();
  16.         }
  17.
  18. }
以下是运行截图:可以看到ddd的数在增加:
dirtwillfly 发表于 2015-12-29 11:26 | 显示全部楼层
wuxiaoxingxing 发表于 2015-12-30 12:24 | 显示全部楼层
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2404
