[ZLG-ARM] directfb是Linux平台上开发机顶盒使用的一个图形系统
8839|1
 楼主| lpczcy 发表于 2009-6-22 13:59 | 显示全部楼层 |阅读模式
Lifview-D&nbsp;双模机顶盒整体架构<br />硬件部分:&nbsp;<br /><br />单芯片&nbsp;IP/DVB&nbsp;解决方案&nbsp;<br />丰富的外围借口:支持以太网(&nbsp;RJ45,10/100Mbs&nbsp;)、&nbsp;MiniPci&nbsp;(支持无线网卡)、双路&nbsp;DVB&nbsp;输入(支持&nbsp;DVB-C/T/S&nbsp;);具备&nbsp;2&nbsp;个串口,&nbsp;4&nbsp;个&nbsp;USB&nbsp;接口,&nbsp;2&nbsp;个&nbsp;SmartCard&nbsp;接口(&nbsp;CA&nbsp;),红外输入接口;&nbsp;SATA&nbsp;接口(&nbsp;PVR&nbsp;);丰富的音视频输出接口&nbsp;CVBS&nbsp;,&nbsp;S-Video&nbsp;,&nbsp;YPbPr&nbsp;,&nbsp;L/R&nbsp;Radio&nbsp;,&nbsp;SPDIF<br />软件部分:&nbsp;<br />嵌入式&nbsp;Linux&nbsp;操作系统&nbsp;网络协议:&nbsp;TCP/IP&nbsp;,&nbsp;DHCP&nbsp;,&nbsp;RTP/RTSP&nbsp;,&nbsp;HTTP&nbsp;图形系统:&nbsp;DirectFB&nbsp;,可实现输入&nbsp;/&nbsp;输出管理,图形显示、硬件加速、窗口管理以及字体库等功能&nbsp;<br />C/C++&nbsp;(&nbsp;GNU&nbsp;Tools&nbsp;)<br />Lifview-D&nbsp;双模机顶盒功能及技术指标&nbsp;<br />1&nbsp;)&nbsp;DVB&nbsp;Streaming&nbsp;<br /><br />MPEG-2&nbsp;<br />Digital&nbsp;Front-End&nbsp;(Tuner&nbsp;and&nbsp;Demodulator)&nbsp;<br />Descrambling&nbsp;(DVB-CA)&nbsp;<br />Transport&nbsp;Stream&nbsp;Demultiplexing&nbsp;:&nbsp;From&nbsp;Front-End&nbsp;(C/T/S)&&nbsp;Middleware&nbsp;(for&nbsp;IP-STB&nbsp;&&nbsp;PVR&nbsp;playback)&nbsp;<br />Single-Program&nbsp;Transport&nbsp;Stream&nbsp;Extraction&nbsp;:&nbsp;For&nbsp;PVR&nbsp;record&&nbsp;network&nbsp;distribution&nbsp;<br />PVR&nbsp;<br />2&nbsp;)&nbsp;IP&nbsp;Streaming&nbsp;<br /><br />IP&nbsp;Protocol:&nbsp;IPv4/IPv6&nbsp;<br />TCP/IP,HTTP,DHCP,DNS,FTP,SSL,PPPoE,SNMP&nbsp;<br />Streaming&nbsp;Protocol:&nbsp;<br />Multicast&nbsp;IPTV(IGMP&nbsp;Control)&nbsp;<br />Video&nbsp;On&nbsp;Demand(RTSP/RSVP&nbsp;control)&nbsp;<br />Transport&nbsp;Protocol:&nbsp;ISMA&nbsp;&&nbsp;TS,&nbsp;RTP/RTCP&nbsp;<br />3&nbsp;)信源音视频解码器&nbsp;<br /><br />视频支持的解码标准:&nbsp;AVS&nbsp;标清(&nbsp;720x576,720x480)&nbsp;,&nbsp;MPEG2&nbsp;标准、高清(&nbsp;1080i&nbsp;),&nbsp;MPEG4&nbsp;标清&nbsp;ASP@L3&nbsp;,&nbsp;WMV9&nbsp;标清&nbsp;MP@L3&nbsp;<br />音频支持的解码标准:&nbsp;MPEG(Layer1,2)&nbsp;、&nbsp;MP3&nbsp;、&nbsp;AAC&nbsp;、&nbsp;WMA&nbsp;<br />4&nbsp;)&nbsp;OSD&nbsp;显示&nbsp;<br /><br />Color:&nbsp;32-bit&nbsp;RGB&nbsp;for&nbsp;Video&nbsp;<br />Alpha&nbsp;Blending:256&nbsp;level&nbsp;<br />OSD&nbsp;Ficker&nbsp;Filter&nbsp;<br />Picture-in-Picture&nbsp;<br />5&nbsp;)&nbsp;DirectFB&nbsp;中间件接口<br /><br />Playback&nbsp;of&nbsp;compressed&nbsp;Video&nbsp;and&nbsp;Audio:&nbsp;<br />Video&nbsp;Provider&nbsp;Interface&nbsp;<br />Example:AVI&nbsp;、&nbsp;MP4&nbsp;、&nbsp;WMV&nbsp;、&nbsp;MP3&nbsp;<br />Decode&nbsp;(and&nbsp;display)&nbsp;of&nbsp;compressed&nbsp;Images&nbsp;<br />Image&nbsp;Provider&nbsp;Interface&nbsp;<br />Example:&nbsp;JPEG&nbsp;file&nbsp;<br />Graphics&nbsp;Drawing&nbsp;Operations:&nbsp;Lines&nbsp;/&nbsp;Boxes&nbsp;、&nbsp;Text&nbsp;/&nbsp;Fonts&nbsp;、&nbsp;Region&nbsp;copying&nbsp;、&nbsp;Hardware&nbsp;accelerated&nbsp;<br /><br />&nbsp;<br /> &nbsp;&nbsp;<br />如何选择合适的图形系统呢?<br /><br />大家知道嵌入式领域是一个很丰富的领域,包括诸多的嵌入式操作系统和嵌入式图形支撑系统,所以除了MiniGUI之外,还有一些其他的嵌入式GUI,比如QT/E,micwindows,&nbsp;DirectFB&nbsp;+GTK,fltk,openGUI,TILCON等等,我们这里重点讨论一下DirectFB,directfb是跟window下的directx类似的一套库<br />&nbsp;<br /> &nbsp;&nbsp;<br />directfb简介<br /><br />什么是directfb呢<br /><br />一个新的Linux图形标准<br /><br />面对嵌入式设备的特殊需求环境,我们为图形加速和图形增强支持开发了一个小巧、强大和易于使用的技术:directfb。<br /><br />directfb是一个瘦函数库,为开发者提供硬件加速,输入设备处理,并在Linux&nbsp;FB设备之上抽象、集成了支持半透明窗口和多层显示的窗口系统。它是一个完全的硬件抽象层,在每个图形操作上都具有软件后备机制,用于那些不被底层硬件支持的功能。DFB让嵌入式系统图形功能更强大,并在Linux上建立了一个新的标准。<br /><br />硬件图形加速&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />DirectFB&nbsp;提供以下图形操作:&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />Rectangle&nbsp;filling/drawing&nbsp;矩形填充/绘制<br />Triangle&nbsp;filling/drawing&nbsp;&nbsp;&nbsp;&nbsp;三角形~~/~~<br />Line&nbsp;drawing&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;画线<br />Flat&nbsp;shaded&nbsp;triangles&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;三线质素平面阴影&nbsp;(平面阴影更平滑)<br />Simple&nbsp;blitting&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;简单位块传输<br />Stretched&nbsp;blitting&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;拉伸~~~~~~~<br />Textured&nbsp;triangles&nbsp;(perspective&nbsp;correct)&nbsp;三角纹理&nbsp;(透视校正)<br />Blending&nbsp;with&nbsp;an&nbsp;alphachannel&nbsp;(per&nbsp;pixel&nbsp;alpha)&nbsp;&nbsp;Alpha融合&nbsp;单像素<br />Blending&nbsp;with&nbsp;an&nbsp;alpha&nbsp;factor&nbsp;(alpha&nbsp;modulation)&nbsp;~~~~~~~~&nbsp;&nbsp;全局<br />Nine&nbsp;source&nbsp;and&nbsp;destination&nbsp;blend&nbsp;functions<br />Porter/Duff&nbsp;rules&nbsp;are&nbsp;supported&nbsp;&nbsp;&nbsp;&nbsp;算法规则,也是涉及透明的图形混合算法<br />Premultiplied&nbsp;alpha&nbsp;supported<br />Colorized&nbsp;blitting&nbsp;(color&nbsp;modulation)<br />Source&nbsp;color&nbsp;keying<br />Destination&nbsp;color&nbsp;keying<br /><br />管理<br />directfb对显存实现了自我资源管理。诸如显示层,输入设备等资源在排斥存取时能通过加锁锁定,例如全屏游戏。directfb针对不同的图形对象提供抽象,如显示层,窗口和通用表层。在从窗口切换到全屏和复原的编程设计尝试上被最小化到设置预期的协作等级。<br /><br />directfb的模块<br />#&nbsp;Graphics&nbsp;acceleration&nbsp;<br />#&nbsp;Input&nbsp;devices&nbsp;<br />#&nbsp;Image&nbsp;Provider&nbsp;<br />#&nbsp;Video&nbsp;Provider&nbsp;<br />#&nbsp;Font&nbsp;Provider<br />&nbsp;<br /> &nbsp;&nbsp;<br />DirectFB入门的一些感悟<br />下面是我对Directfb刚入门时的一些感悟,应该对刚入门的朋友有好处:<br />在我们到www.directfb.org的官方网站上看到的API函数,刚入门的朋友可能会觉得这些函数的调用还真是麻烦,其实他一点不麻烦,比如我们需要调用一个Flip函数,像<br /><br />primary-&gtFlip&nbsp;(primary,&nbsp;NULL,&nbsp;DSFLIP_WAITFORSYNC);<br /><br />我们在API中可以看到在进入IDirectFBSurface的这个接口就可以看到它的子页面有Flip这个函数了。所以我们得先定义一个IDirectFBSurface *primary&nbsp;=&nbsp;NULL;然后再由这个primary surface指向它的下级:primary-&gtFlip&nbsp;(primary,&nbsp;NULL,&nbsp;DSFLIP_WAITFORSYNC)。这样这个函数调用就出来了。<br /><br />另外,在API函数的首页面有三个部分:Interfaces,Types和Definitions。我们知道Interfaces在我们调用函数的时候用到,那Type和Definitions会在哪用到呢?下面我们还是看看这个Flip函数原型:<br /><br />Flip&nbsp;(&nbsp;<br />&nbsp;&nbsp;IDirectFBSurface&nbsp;&nbsp;&nbsp;&nbsp;*&nbsp;&nbsp;thiz,&nbsp;&nbsp;<br />&nbsp;&nbsp;const&nbsp;DFBRegion&nbsp;&nbsp;&nbsp;&nbsp;*&nbsp;&nbsp;region,&nbsp;&nbsp;<br />&nbsp;&nbsp;DFBSurfaceFlipFlags&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;flags&nbsp;&nbsp;<br />);&nbsp;<br /><br />看第一个参数IDirectFBSurface型的,这个是在Interfaces中定义的,而第二、三个参数DFBRegion,DFBSurfaceFlipFlags都是在Type中出现的,他们就是指这些接口函数的变量类型,所以要调用函数就在Interfaces中调用,要查看函数参数的类型就可以到Type中查看了。这样在DirectFB官方网站www.directfb.org上有些例子,我们就可以试试了:http://www.directfb.org/docs/DirectFB_Tutorials/<br />交叉编译directfb<br /><br />开始动手交叉编译directfb到我的arm&nbsp;linux平台,步骤如下:<br /><br />1.&nbsp;下载&nbsp;DirectFB-1.2.1.tar.gz<br /><br />2.&nbsp;解压缩&nbsp;tar&nbsp;xvzf&nbsp;&nbsp;&nbsp;DirectFB-1.2.1.tar.gz<br /><br />3.&nbsp;配置交叉编译方式&nbsp;:<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;./configure&nbsp;--prefix=/home/xinlian/rootfs/home/directfb&nbsp;--target=arm-linux&nbsp;--host=arm-linux&nbsp;LD=arm-linux-ld&nbsp;--enable-png=no&nbsp;--enable-freetype=no<br /><br />注:其中禁止了png和freetype因为我都没有用到。<br /><br />4.编译&nbsp;:make<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;编译时会遇到编译gfxdrivers目录的部分驱动时通不过,比如tiomap等,由于这些驱动对于我来说是用不到的,我就直接把该目录下的makefile里相应的项屏蔽掉了。<br /><br />5.安装<br /><br />make&nbsp;install<br />一个使用DirectFB包的简单编程示例<br /><br />主要实现了3个内容:<br /><br />1。surface的绘图函数<br />2。如何在surface中获取类似framebuffer的绘制内存地址(去掉代码中的注释)<br />3。eventbuffer的使用,按escape退出,移动鼠标绘点<br /><br /><br />代码:<br />#include&nbsp;“directfb.h”&nbsp;#include&nbsp;'stdio.h'static&nbsp;IDirectFB&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;*dfb&nbsp;&nbsp;&nbsp;=&nbsp;NULL;static&nbsp;IDirectFBDisplayLayer&nbsp;*layer&nbsp;=&nbsp;NULL;static&nbsp;IDirectFBSurface&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;*surface&nbsp;=&nbsp;NULL;static&nbsp;IDirectFBEventBuffer&nbsp;*events&nbsp;=&nbsp;NULL;int&nbsp;main(&nbsp;int&nbsp;argc,&nbsp;char&nbsp;*argv[]){&nbsp;&nbsp;&nbsp;&nbsp;void&nbsp;*point&nbsp;=&nbsp;NULL;&nbsp;&nbsp;&nbsp;&nbsp;int&nbsp;pitch;&nbsp;&nbsp;&nbsp;&nbsp;int&nbsp;i,j;&nbsp;&nbsp;&nbsp;&nbsp;int&nbsp;quit=0;&nbsp;&nbsp;&nbsp;&nbsp;int&nbsp;x=0;&nbsp;&nbsp;&nbsp;&nbsp;int&nbsp;y=0;&nbsp;&nbsp;&nbsp;&nbsp;DirectFBInit(&argc,&argv);&nbsp;&nbsp;&nbsp;&nbsp;DirectFBCreate(&dfb);&nbsp;&nbsp;&nbsp;&nbsp;dfb-&gtGetDisplayLayer(dfb,&nbsp;DLID_PRIMARY,&nbsp;&layer);&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;dfb-&gtCreateInputEventBuffer(dfb,DICAPS_ALL,DFB_TRUE,&events);&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;layer-&gtSetCooperativeLevel(layer,DLSCL_EXCLUSIVE);&nbsp;&nbsp;&nbsp;&nbsp;layer-&gtGetSurface(layer,&surface);&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;surface-&gtSetColor(surface,80,80,0,0xff);&nbsp;&nbsp;&nbsp;&nbsp;surface-&gtFillRectangle(surface,100,0,100,100);&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;while(!quit){&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;DFBEvent&nbsp;evt;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;events-&gtWaitForEvent(events);&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;while(!quit&nbsp;&&&nbsp;events-&gtGetEvent(events,&evt)&nbsp;==&nbsp;DFB_OK)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;{&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;switch(evt.clazz){&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;case&nbsp;DFEC_INPUT:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;switch&nbsp;(evt.input.type)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;{&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;case&nbsp;DIET_KEYPRESS:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if(evt.input.key_symbol&nbsp;==&nbsp;DIKS_ESCAPE)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;quit&nbsp;=&nbsp;1;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;break;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;case&nbsp;DIET_AXISMOTION:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if&nbsp;(evt.input.flags&DIEF_AXISREL)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;switch&nbsp;(evt.input.axis)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;{&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;case&nbsp;DIAI_X:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;x+=evt.input.axisrel;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;break;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;case&nbsp;DIAI_Y:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;y+=evt.input.axisrel;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;break;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;default&nbsp;:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;break;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;}&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if&nbsp;(x&lt0)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;x=0;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if&nbsp;(y&lt0)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;y=0;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;surface-&gtSetColor(surface,0,0xff,0,0xff);&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;surface-&gtDrawLine(surface,x,y,x,y);&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;//printf('&lt&nbsp;%&nbsp;d,%d&gt\n',x,y);&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;break;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;default:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;break;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;}&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;break;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;default:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;break;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;}&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;}&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;}&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;surface-&gtRelease(surface);&nbsp;&nbsp;&nbsp;&nbsp;layer-&gtRelease(layer);&nbsp;&nbsp;&nbsp;&nbsp;dfb-&gtRelease(dfb);&nbsp;&nbsp;&nbsp;&nbsp;return&nbsp;0;&nbsp;&nbsp;}<br />
arminfo 发表于 2009-6-22 14:03 | 显示全部楼层
不错,谢啦
