Orcad10.0 更新的一些功能
3326|1
 楼主| limee 发表于 2007-2-25 20:04 | 显示全部楼层 |阅读模式
Thermal&nbsp;prioritization&nbsp;enhancements<br /><br />In&nbsp;earlier&nbsp;versions&nbsp;of&nbsp;Layout,&nbsp;Layout&nbsp;stopped&nbsp;at&nbsp;the&nbsp;first&nbsp;via<br />that&nbsp;thermals&nbsp;and&nbsp;did&nbsp;not&nbsp;try&nbsp;to&nbsp;thermal&nbsp;other&nbsp;vias&nbsp;in&nbsp;the&nbsp;same&nbsp;connection.&nbsp;If&nbsp;you&nbsp;have&nbsp;planes&nbsp;that&nbsp;have&nbsp;been&nbsp;split&nbsp;into&nbsp;multiple&nbsp;isolated&nbsp;polygons,&nbsp;this&nbsp;behavior&nbsp;made&nbsp;it&nbsp;difficult&nbsp;to&nbsp;tie&nbsp;together&nbsp;plane&nbsp;regions&nbsp;using&nbsp;vias&nbsp;and&nbsp;traces&nbsp;on&nbsp;routing&nbsp;layers.&nbsp;Layout10.0&nbsp;attempts&nbsp;to&nbsp;thermal&nbsp;every&nbsp;via&nbsp;in&nbsp;the&nbsp;connection&nbsp;and&nbsp;no&nbsp;longer&nbsp;stops&nbsp;at&nbsp;the&nbsp;first&nbsp;successful&nbsp;thermal.<br /><br />Where&nbsp;no&nbsp;&quot;Preferred&quot;&nbsp;or&nbsp;&quot;Forced&quot;&nbsp;thermal&nbsp;pin&nbsp;existed&nbsp;on&nbsp;a&nbsp;connection,&nbsp;earlier&nbsp;versions&nbsp;of&nbsp;Layout&nbsp;would&nbsp;randomly&nbsp;choose<br />a&nbsp;pin&nbsp;from&nbsp;the&nbsp;connection&nbsp;to&nbsp;thermal&nbsp;into&nbsp;the&nbsp;plane.&nbsp;The&nbsp;randomization&nbsp;was&nbsp;designed&nbsp;to&nbsp;distribute&nbsp;thermals&nbsp;over&nbsp;the&nbsp;widest&nbsp;possible&nbsp;area&nbsp;of&nbsp;the&nbsp;plane&nbsp;but&nbsp;any&nbsp;change&nbsp;to&nbsp;your&nbsp;MAX&nbsp;database<br />could&nbsp;change&nbsp;the&nbsp;randomization&nbsp;results.&nbsp;<br /><br />Layout10.0&nbsp;still&nbsp;<br />distributes&nbsp;such&nbsp;pin&nbsp;thermals&nbsp;over&nbsp;the&nbsp;widest&nbsp;possible&nbsp;plane&nbsp;area&nbsp;but&nbsp;uses&nbsp;a&nbsp;priority&nbsp;scheduling&nbsp;algorithm&nbsp;which&nbsp;will&nbsp;not&nbsp;change&nbsp;a&nbsp;pin's&nbsp;plane&nbsp;thermalization&nbsp;unless&nbsp;the&nbsp;pin&nbsp;is&nbsp;physically&nbsp;moved&nbsp;to&nbsp;a&nbsp;new&nbsp;location.
cyh 发表于 2007-2-26 01:02 | 显示全部楼层
现在都用15.7版本了
