单片机驱动标准pc机键盘的C51程序
2923|5
 楼主| turmary 发表于 2007-3-7 02:00 | 显示全部楼层 |阅读模式
单片机驱动标准pc机键盘的C51程序
网上流行的这个程充很垃圾,
在我的单片机上无论如何都调试不成功.
正确的程序见http://home.hn8868.com/tary/download.html
该程序由AVR程序移植过来...
C语言写的,风格棒极了.
在P1口显示ASCII吗,也有使用LCD1602显示的,需要的请连系我.
以下是主要的代码KB.C
#include <Atmel\AT89X52.h>
#include "Pindefs.h"
#include "kb.h"
#include "gpr.h"
#include "Disp1602.h"
#include "Scancodes.h"
#define BUFF_SIZE 32
unsigned char edge, bitcount;    // 0 = neg. 1 = pos.
unsigned char kb_buffer[BUFF_SIZE];
unsigned char *inpt, *outpt;
unsigned char buffcnt;
void init_kb(void)
    inpt = kb_buffer;    // Initialize buffer
    outpt = kb_buffer;
    buffcnt = 0;
    // INT0 interrupt on falling edge
    edge = 0;        // 0 = falling edge 1 = rising edge
    bitcount = 11;
void INT0_interrupt(void) interrupt 0 using 2
    static unsigned char cdata;    // Holds the received scan code
    EA = 0;
    if (!edge)         // Routine entered at falling edge
        if(bitcount < 11 && bitcount > 2)    // Bit 3 to 10 is data. Parity bit,
        {     // start and stop bits are ignored.
            cdata = (cdata >> 1);
            if(PIND)
                cdata = cdata | 0x80;    // Store a '1'
        /*MCUCR = 3; */    // Set interrupt on rising edge
        edge = 1;
    if (edge) {         // Routine entered at rising edge
        /*MCUCR = 2; */    // Set interrupt on falling edge
        edge = 0;
        if(--bitcount == 0)    // All bits received
            decode(cdata);
            bitcount = 11;
    EA = 1;
void decode(unsigned char sc)
    //extern void clr(void);
    static unsigned char is_up = 0, shift = 0, mode = 0;
    unsigned char i;
    if (!is_up)    // Last data received was the up-key identifier
        switch (sc)
        case 0xF0 :            // The up-key identifier
            is_up = 1;
            break;
        case 0x12 :            // Left SHIFT
            shift = 1;
            break;
        case 0x59 :            // Right SHIFT
            shift = 1;
            break;
        case 0x05 :            // F1
            if(mode == 0)
                mode = 1;        // Enter scan code mode
            if(mode == 2)
                mode = 3;        // Leave scan code mode
            break;
        default:
            if(mode == 0 || mode == 3)    // If ASCII mode
                if(!shift)        // If shift not pressed,
                {             // do a table look-up
                    for(i = 0; unshifted[0]!=sc && unshifted[0]; i++);
                    if (unshifted[0] == sc) {
                        put_kbbuff(unshifted[1]);
                } else {        // If shift pressed
                    for(i = 0; shifted[0]!=sc && shifted[0]; i++);
                    if (shifted[0] == sc) {
                        put_kbbuff(shifted[1]);
            } else{             // Scan code mode
                print_hexbyte(sc);    // Print scan code
                put_kbbuff(' ');
                put_kbbuff(' ');
            break;
    } else {
        is_up = 0;        // Two 0xF0 in a row not allowed
        switch (sc)
            shift = 0;
            break;
            shift = 0;
            break;
        case 0x05 :        // F1
            if(mode == 1)
                mode = 2;
            if(mode == 3)
                mode = 0;
            break;
        case 0x06 :        // F2
            clr();
            break;
void put_kbbuff(unsigned char c)
    if (buffcnt < BUFF_SIZE)    // If buffer not full
        *inpt = c;        // Put character into buffer
        inpt++;         // Increment pointer
        buffcnt++;
        if (inpt >= kb_buffer + BUFF_SIZE)    // Pointer wrapping
            inpt = kb_buffer;
int getchar(void)
    int byte;
    while(buffcnt == 0);    // Wait for data
    byte = *outpt;        // Get byte
    outpt++;        // Increment pointer
    if (outpt >= kb_buffer + BUFF_SIZE)    // Pointer wrapping
        outpt = kb_buffer;
    buffcnt--;        // Decrement buffer count
    return byte;
相关链接:http://home.hn8868.com/tary/download.html
fish1983 发表于 2007-3-7 10:03 | 显示全部楼层
支持
支持
 楼主| turmary 发表于 2007-3-7 11:44 | 显示全部楼层
硬件接法
数据线接P2.3
时钟线接P3.2(INT0)
键盘的电源当然接5V与GND.
P1口接八个上拉发光二极管
 楼主| turmary 发表于 2007-3-7 18:57 | 显示全部楼层
binbinwb 发表于 2007-3-7 20:53 | 显示全部楼层
有意思
yongzai 发表于 2011-5-11 12:00 | 显示全部楼层
看不懂
