[AVR单片机] 请教ATmega640模拟器和比较器的使用
2772|5
 楼主| jjl3 发表于 2007-5-10 15:49 | 显示全部楼层 |阅读模式
请帮我看看下面的程序:
#include<avr/io.h>
#include<avr/interrupt.h>
#define __disable_interrupt()       asm("cli")  //Turn off global interrupt
#define __enable_interrupt()        asm("sei")  //Turn on global interrupt
unsigned char ADC_valH = 0;
unsigned char ADC_valL = 0;
unsigned char first1 = 0;
unsigned char first2 = 0;
void ADC2_ini(void)
    ADCSRB = 0x40;
         ADMUX  = 0x42;
    ADCSRA = 0xEF;                   // ADC2使能,free run模式
SIGNAL(ADC_vect)                                      // ADC Conversion Complete interrupt service routine
    if(ADC_valH != (ADCH& 0x03) || ADC_valL != ADCL)
       ADC_valH = ADCH & 0x03;
            ADC_valL = ADCL;
            UART_transmit(ADC_valH);
            UART_transmit(ADC_valL);             //如果ADC转换值变化就发送新值
void Comparator_ini(void)
    ACSR = ACSR & 0xF7;                               //ensure interrupt is off before changing
    ADCSRB = 0x40;
    DIDR1  = 0x03;
    ADMUX  = 0x00;
    ACSR   = 0x08;                              // AIN0接正输入,ADC0接负输入,比较器变化就产生中断
SIGNAL(ANALOG_COMP_vect)                              // Analog Comparator interrupt service routine
    sends("Comparator changed!");
    UART_transmit('\n');
void UART3_ini(void)
    //UART3 口
    UCSR3B = 0x00;                                  //disable while setting baud rate
    UCSR3C = 0x06;                                  //异步,8位数据,无奇偶校验,一个停止位,无倍速
    UBRR3L = 0x67;                                  //baudrate = 9600 at system clk = 16MHz
    UBRR3H = 0x00;
    UCSR3B = 0x98;                                  //接收中断使能,接收允许,发送允许
void UART_transmit(unsigned char dat)
   while ( !( UCSR3A & (1<<UDRE3)) );
    UDR3 = dat;
void sends(unsigned char *ptr)
    while (*ptr)
        UART_transmit(*ptr++);
int main(void)
    __disable_interrupt();
    //上电默认DDRx=0x00,PORTx=0x00 输入,无上拉电阻
    PORTA = 0xFF;               //不用的管脚使能内部上拉电阻
    DDRD  = 0xC0;
    PORTD = 0xC0;
    UART3_ini();
    __enable_interrupt();
    while(1)
      if(PINJ & 0x04)
           if(first1 ==0)
              ADCSRA = 0x00;
              Comparator_ini();
              first1 = 0xaa;
              first2 = 0;
              sends("Comparator enable! ADC disable!");
            PORTD = 0x80;
        else
            if(first2 == 0)
              ACSR = 0x00;
              ADC2_ini();
              first1 = 0;
              first2 = 0xaa;
              sends("ADC enable! Comparator disable!");
              ADCSRA = (1<<ADSC);                      // 启动ADC
             PORTD = 0x40;
    return 0;
SIGNAL(USART3_RX_vect)                              // USART Receiver interrupt service routine
     UART_transmit(UDR3);
PJ2是个摇杆开关,用于选择使能比较器使能或ADC使能.
当使能比较器时,输出如下:
Comparator changed!
然后再怎么改变负端的电压也不会再产生输出了.
不知为什么?
当使能ADC时,输出如下:
改变ADC2的输入电压没输出,
好象没有进入到ADC的中断中.
请帮忙,谢谢!!
 楼主| jjl3 发表于 2007-5-10 22:44 | 显示全部楼层
现在比较器可以产生中断了,但是。。。
有时调节比较器的输入端电压产生中断,但会产生很多次中断,
我在中断服务程序改为:
    ACSR   = (1<<ACI);
增加了一句ACSR   = (1<<ACI);
竟然再也产生不了中断了.
晕死了!:(
szxw 发表于 2007-5-11 16:10 | 显示全部楼层
多次中断可能是正负端电压差接近零伏时的临界抖动所致
xwj 发表于 2007-5-11 19:52 | 显示全部楼层
正是有钱人啊...
 楼主| jjl3 发表于 2007-5-13 13:19 | 显示全部楼层
我又修改了中断程序
    if ((ACSR&(1<<ACO))==0)
        sends("Voltage is higher than VREF!");
       else{
             ("Voltage is lower than VREF!");
(注:Voltage 是接ADC0的电压;VREF是接AIN0的电压)
发现怎么调节比较器两端电压只有当Voltage > VREF时,有如下输出:
当Voltage < VREF时,无输出
为什么呀?这个比较器快搞疯我了:((((((((
enjoy21cn 发表于 2008-6-26 20:31 | 显示全部楼层
强人啊!
强人啊!见识了!
