C8051F340的SMbus程序求助
5765|4
 楼主| 还我今生 发表于 2008-12-4 14:47 | 显示全部楼层 |阅读模式
// F34x_SMBus_EEPROM.c
// Copyright 2006 Silicon Laboratories, Inc.
// http://www.silabs.com
// Program Description:
// This example demonstrates how the C8051F34x SMBus interface can communicate
// with a 256 byte I2C Serial EEPROM (Microchip 24LC02B).
// - Interrupt-driven SMBus implementation
// - Only master states defined (no slave or arbitration)
// - Timer1 used as SMBus clock source
// - Timer2 used by SMBus for SCL low timeout detection
// - SCL frequency defined by <SMB_FREQUENCY> constant
// - Pinout:
//    P0.0 -> SDA (SMBus)
//    P0.1 -> SCL (SMBus)
//    P2.2 -> LED
//    all other port pins unused
// How To Test:
// 1) Download code to a 'F34x device that is connected to a 24LC02B serial
//    EEPROM (see the EEPROM datasheet for the pinout information).
// 2) Run the code:
//         a) the test will indicate proper communication with the EEPROM by
//            turning on the LED at the end the end of the test
//         b) the test can also be verified by running to the if statements
//            in main and checking the sent and received values by adding
//            the variables to the Watch Window
// FID:            34X000078
// Target:         C8051F34x
// Tool chain:     Keil C51 7.50 / Keil EVAL C51
// Command Line:   None
// Release 1.0
//    -Initial Revision (TP)
//    -30 MAR 2006
// Includes and Device-Specific Parameters
#include <C8051F340.h>
// Global CONSTANTS
// System clock frequency in Hz
#define  SYSCLK         12000000
#define  SMB_FREQUENCY  10000          // Target SCL clock rate
                                       // This example supports between 10kHz
                                       // and 100kHz
#define  WRITE          0x00           // SMBus WRITE command
#define  READ           0x01           // SMBus READ command
// Device addresses (7 bits, lsb is a don't care)
#define  EEPROM_ADDR    0x40           // Device address for slave target
                                       // Note: This address is specified
                                       // in the Microchip 24LC02B
                                       // datasheet.
// SMBus Buffer Size
#define  SMB_BUFF_SIZE  0x08           // Defines the maximum number of bytes
                                       // that can be sent or received in a
                                       // single transfer
// Status vector - top 4 bits only
#define  SMB_MTSTA      0xE0           // (MT) start transmitted
#define  SMB_MTDB       0xC0           // (MT) data byte transmitted
#define  SMB_MRDB       0x80           // (MR) data byte received
// End status vector definition
// Global VARIABLES
unsigned char* pSMB_DATA_IN;           // Global pointer for SMBus data
                                       // All receive data is written here
unsigned char SMB_SINGLEBYTE_OUT;      // Global holder for single byte writes.
unsigned char* pSMB_DATA_OUT;          // Global pointer for SMBus data.
                                       // All transmit data is read from here
unsigned char SMB_DATA_LEN;            // Global holder for number of bytes
                                       // to send or receive in the current
                                       // SMBus transfer.
unsigned char WORD_ADDR;               // Global holder for the EEPROM word
                                       // address that will be accessed in
                                       // the next transfer
unsigned char TARGET;                  // Target SMBus slave address
bit SMB_BUSY = 0;                      // Software flag to indicate when the
                                       // EEPROM_ByteRead() or
                                       // EEPROM_ByteWrite()
                                       // functions have claimed the SMBus
bit SMB_RW;                            // Software flag to indicate the
                                       // direction of the current transfer
bit SMB_SENDWORDADDR;                  // When set, this flag causes the ISR
                                       // to send the 8-bit <WORD_ADDR>
                                       // after sending the slave address.
bit SMB_RANDOMREAD;                    // When set, this flag causes the ISR
                                       // to send a START signal after sending
                                       // the word address.
                                       // For the 24LC02B EEPROM, a random read
                                       // (a read from a particular address in
                                       // memory) starts as a write then
                                       // changes to a read after the repeated
                                       // start is sent. The ISR handles this
                                       // switchover if the <SMB_RANDOMREAD>
                                       // bit is set.
bit SMB_ACKPOLL;                       // When set, this flag causes the ISR
                                       // to send a repeated START until the
                                       // slave has acknowledged its address
// 16-bit SFR declarations
sfr16    TMR3RL   = 0x92;              // Timer3 reload registers
sfr16    TMR3     = 0x94;              // Timer3 counter registers
//sbit LED = P2^2;                       // LED on port P2.2
sbit SDA = P0^0;                       // SMBus on P0.0
sbit SCL = P0^1;                       // and P0.1
// Function PROTOTYPES
void SMBus_Init(void);
void Timer1_Init(void);
void Timer3_Init(void);
void Port_Init(void);
void SMBus_ISR(void);
void Timer3_ISR(void);
void EEPROM_ByteWrite(unsigned char addr, unsigned char dat);
void EEPROM_WriteArray(unsigned char dest_addr, unsigned char* src_addr,
                       unsigned char len);
unsigned char EEPROM_ByteRead(unsigned char addr);
void EEPROM_ReadArray(unsigned char* dest_addr, unsigned char src_addr,
                      unsigned char len);
void mDelayS( unsigned char s );
void mDelaymS( unsigned char ms );
// MAIN Routine
// Main routine performs all configuration tasks, then loops forever sending
// and receiving SMBus data to the slave EEPROM.
void main (void)
//   char in_buff[8] = {0};              // Incoming data buffer
//   char out_buff[8] = "ABCDEFG";       // Outgoing data buffer
//   unsigned char temp_char;            // Temporary variable
//   bit error_flag = 0;                 // Flag for checking EEPROM contents
   unsigned char i;                    // Temporary counter variable
   PCA0MD &= ~0x40;                    // WDTE = 0 (disable watchdog timer)
   // Set internal oscillator to highest
   // setting of 24500000 (or 12000000 for 'F320)
   OSCICN |= 0x03;
   // If slave is holding SDA low because of an improper SMBus reset or error
   while(!SDA)
      // Provide clock pulses to allow the slave to advance out
      // of its current state. This will allow it to release SDA.
      XBR1 = 0x40;                     // Enable Crossbar
      SCL = 0;                         // Drive the clock low
      for(i = 0; i < 255; i++);        // Hold the clock low
      SCL = 1;                         // Release the clock
      while(!SCL);                     // Wait for open-drain
                                       // clock output to rise
      for(i = 0; i < 10; i++);         // Hold the clock high
      XBR1 = 0x00;                     // Disable Crossbar
   Port_Init ();                       // Initialize Crossbar and GPIO
//   LED = 0;                            // Turn off the LED before the test
                                       // starts
   Timer1_Init ();                     // Configure Timer1 for use as SMBus
                                       // clock source
   Timer3_Init ();                     // Configure Timer3 for use with SMBus
                                       // low timeout detect
   SMBus_Init ();                      // Configure and enable SMBus
   EIE1 |= 0x01;                       // Enable the SMBus interrupt
   EA = 1;                             // Global interrupt enable
   EEPROM_ByteWrite(0x48, 0x01);
   mDelayS(1);
while(1){
   EEPROM_ByteWrite(0x64, 0x3f);
   mDelayS(1);
   EEPROM_ByteWrite(0x68, 0x3f);
   mDelayS(1);
   EEPROM_ByteWrite(0x6A, 0x3f);
   mDelayS(1);
// Initialization Routines
// SMBus_Init()
// Return Value : None
// Parameters   : None
// The SMBus peripheral is configured as follows:
// - SMBus enabled
// - Slave mode disabled
// - Timer1 used as clock source. The maximum SCL frequency will be
//   approximately 1/3 the Timer1 overflow rate
// - Setup and hold time extensions enabled
// - Free and SCL low timeout detection enabled
void SMBus_Init (void)
   SMB0CF = 0x5D;                      // Use Timer1 overflows as SMBus clock
                                       // source;
                                       // Disable slave mode;
                                       // Enable setup & hold time extensions;
                                       // Enable SMBus Free timeout detect;
                                       // Enable SCL low timeout detect;
   SMB0CF |= 0x80;                     // Enable SMBus;
// Timer1_Init()
// Timer1 is configured as the SMBus clock source as follows:
// - Timer1 in 8-bit auto-reload mode
// - SYSCLK / 12 as Timer1 clock source
// - Timer1 overflow rate => 3 * SMB_FREQUENCY
// - The maximum SCL clock rate will be ~1/3 the Timer1 overflow rate
// - Timer1 enabled
void Timer1_Init (void)
// Make sure the Timer can produce the appropriate frequency in 8-bit mode
// Supported SMBus Frequencies range from 10kHz to 100kHz.  The CKCON register
// settings may need to change for frequencies outside this range.
#if ((SYSCLK/SMB_FREQUENCY/3) < 255)
   #define SCALE 1
      CKCON |= 0x08;                   // Timer1 clock source = SYSCLK
#elif ((SYSCLK/SMB_FREQUENCY/4/3) < 255)
   #define SCALE 4
      CKCON |= 0x01;
      CKCON &= ~0x0A;                  // Timer1 clock source = SYSCLK / 4
#endif
   TMOD = 0x20;                        // Timer1 in 8-bit auto-reload mode
   TH1 = -(SYSCLK/SMB_FREQUENCY/12/3); // Timer1 configured to overflow at 1/3
                                       // the rate defined by SMB_FREQUENCY
   TL1 = TH1;                          // Init Timer1
   TR1 = 1;                            // Timer1 enabled
// Timer3_Init()
// Timer3 configured for use by the SMBus low timeout detect feature as
// follows:
// - Timer3 in 16-bit auto-reload mode
// - SYSCLK/12 as Timer3 clock source
// - Timer3 reload registers loaded for a 25ms overflow period
// - Timer3 pre-loaded to overflow after 25ms
// - Timer3 enabled
void Timer3_Init (void)
   TMR3CN = 0x00;                      // Timer3 configured for 16-bit auto-
                                       // reload, low-byte interrupt disabled
   CKCON &= ~0x40;                     // Timer3 uses SYSCLK/12
   TMR3RL = -(SYSCLK/12/40);           // Timer3 configured to overflow after
   TMR3 = TMR3RL;                      // ~25ms (for SMBus low timeout detect)
   EIE1 |= 0x80;                       // Timer3 interrupt enable
   TMR3CN |= 0x04;                     // Start Timer3
// PORT_Init
// Configure the Crossbar and GPIO ports.
// P0.0   digital   open-drain    SMBus SDA
// P0.1   digital   open-drain    SMBus SCL
// P2.2   digital   push-pull     LED
// Note: If the SMBus is moved, the SCL and SDA sbit declarations must also
// be adjusted.
void PORT_Init (void)
   P0MDOUT = 0x00;                     // All P0 pins open-drain output
 //  P2MDOUT |= 0x04;                    // Make the LED (P2.2) a push-pull
                                       // output
   XBR0 = 0x04;                        // Enable SMBus pins
   XBR1 = 0x40;                        // Enable crossbar and weak pull-ups
 //  P0 = 0xFF;
// SMBus Interrupt Service Routine (ISR)
// SMBus ISR state machine
// - Master only implementation - no slave or arbitration states defined
// - All incoming data is written starting at the global pointer <pSMB_DATA_IN>
// - All outgoing data is read from the global pointer <pSMB_DATA_OUT>
void SMBus_ISR (void) interrupt 7
   bit FAIL = 0;                       // Used by the ISR to flag failed
                                       // transfers
   static char i;                      // Used by the ISR to count the
                                       // number of data bytes sent or
                                       // received
   static bit SEND_START = 0;          // Send a start
   switch (SMB0CN & 0xF0)              // Status vector
      // Master Transmitter/Receiver: START condition transmitted.
      case SMB_MTSTA:
         SMB0DAT = TARGET;             // Load address of the target slave
         SMB0DAT &= 0xFE;              // Clear the LSB of the address for the
                                       // R/W bit
         SMB0DAT |= SMB_RW;            // Load R/W bit
         STA = 0;                      // Manually clear START bit
         i = 0;                        // Reset data byte counter
         break;
      // Master Transmitter: Data byte (or Slave Address) transmitted
      case SMB_MTDB:
         if (ACK)                      // Slave Address or Data Byte
         {                             // Acknowledged?
            if (SEND_START)
               STA = 1;
               SEND_START = 0;
               break;
            if(SMB_SENDWORDADDR)       // Are we sending the word address?
               SMB_SENDWORDADDR = 0;   // Clear flag
               SMB0DAT = WORD_ADDR;    // Send word address
               if (SMB_RANDOMREAD)
                  SEND_START = 1;      // Send a START after the next ACK cycle
                  SMB_RW = READ;
               break;
            if (SMB_RW==WRITE)         // Is this transfer a WRITE?
               if (i < SMB_DATA_LEN)   // Is there data to send?
                  // send data byte
                  SMB0DAT = *pSMB_DATA_OUT;
                  // increment data out pointer
                  pSMB_DATA_OUT++;
                  // increment number of bytes sent
                  i++;
               else
                 STO = 1;              // Set STO to terminte transfer
                 SMB_BUSY = 0;         // Clear software busy flag
            else {}                    // If this transfer is a READ,
                                       // then take no action. Slave
                                       // address was transmitted. A
                                       // separate 'case' is defined
                                       // for data byte recieved.
         else                          // If slave NACK,
            if(SMB_ACKPOLL)
               STA = 1;                // Restart transfer
            else
               FAIL = 1;               // Indicate failed transfer
            }                          // and handle at end of ISR
         break;
      // Master Receiver: byte received
      case SMB_MRDB:
         if ( i < SMB_DATA_LEN )       // Is there any data remaining?
            *pSMB_DATA_IN = SMB0DAT;   // Store received byte
            pSMB_DATA_IN++;            // Increment data in pointer
            i++;                       // Increment number of bytes received
            ACK = 1;                   // Set ACK bit (may be cleared later
                                       // in the code)
         if (i == SMB_DATA_LEN)        // This is the last byte
            SMB_BUSY = 0;              // Free SMBus interface
            ACK = 0;                   // Send NACK to indicate last byte
                                       // of this transfer
            STO = 1;                   // Send STOP to terminate transfer
         break;
      default:
         break;
   if (FAIL)                           // If the transfer failed,
      SMB0CF &= ~0x80;                 // Reset communication
      SMB0CF |= 0x80;
      STA = 0;
      STO = 0;
      ACK = 0;
      FAIL = 0;
   SI = 0;                             // Clear interrupt flag
// Timer3 Interrupt Service Routine (ISR)
// A Timer3 interrupt indicates an SMBus SCL low timeout.
// The SMBus is disabled and re-enabled if a timeout occurs.
void Timer3_ISR (void) interrupt 14
   SMB0CF &= ~0x80;                    // Disable SMBus
   SMB0CF |= 0x80;                     // Re-enable SMBus
   TMR3CN &= ~0x80;                    // Clear Timer3 interrupt-pending flag
   SMB_BUSY = 0;                       // Free bus
// Support Functions
// EEPROM_ByteWrite ()
// Parameters   :
//   1) unsigned char addr - address to write in the EEPROM
//                        range is full range of character: 0 to 255
//   2) unsigned char dat - data to write to the address <addr> in the EEPROM
// This function writes the value in <dat> to location <addr> in the EEPROM
// then polls the EEPROM until the write is complete.
   while (SMB_BUSY);                   // Wait for SMBus to be free.
   SMB_BUSY = 1;                       // Claim SMBus (set to busy)
   // Set SMBus ISR parameters
   TARGET = EEPROM_ADDR;               // Set target slave address
   SMB_RW = WRITE;                     // Mark next transfer as a write
   SMB_SENDWORDADDR = 1;               // Send Word Address after Slave Address
   SMB_RANDOMREAD = 0;                 // Do not send a START signal after
                                       // the word address
   SMB_ACKPOLL = 1;                    // Enable Acknowledge Polling (The ISR
                                       // will automatically restart the
                                       // transfer if the slave does not
                                       // acknoledge its address.
                                        // Specify the Outgoing Data
   WORD_ADDR = addr;                   // Set the target address in the
                                       // EEPROM's internal memory space
   SMB_SINGLEBYTE_OUT = dat;           // Store <dat> (local variable) in a
                                       // global variable so the ISR can read
                                       // it after this function exits
                                        // The outgoing data pointer points to the <dat> variable
   pSMB_DATA_OUT = &SMB_SINGLEBYTE_OUT;
   SMB_DATA_LEN = 1;                   // Specify to ISR that the next transfer
                                       // will contain one data byte
                                         // Initiate SMBus Transfer
   STA =
 楼主| 还我今生 发表于 2008-12-4 14:52 | 显示全部楼层
关于这段程序
是引用了C8051F340的例程  : F34x_SMBus_EEPROM.c
目的是 将CH450驱动的 数码管点亮  比如就发0X3F
 EEPROM_ByteWrite(0x48, 0x01);      表示启动显示
   mDelayS(1);
while(1){
   EEPROM_ByteWrite(0x64, 0x3f);  显示一个管子(0x64是CH450的地址)
   mDelayS(1);
   EEPROM_ByteWrite(0x68, 0x3f);  显示一个管子
   mDelayS(1);
   EEPROM_ByteWrite(0x6A, 0x3f);  显示一个管子
   mDelayS(1);
地址应该不会错了 不知道程序还有没有错误的地方
请高人解答。
 楼主| 还我今生 发表于 2008-12-4 14:53 | 显示全部楼层
现在的情况就是 不会亮
改了很多次 都不亮一个数码管,郁闷中
 楼主| 还我今生 发表于 2008-12-4 14:59 | 显示全部楼层
我就是将CH450看作是EEPROM来理解这个程序的
不知道对不对
 楼主| 还我今生 发表于 2008-12-4 17:03 | 显示全部楼层
高手在安? 求之不得。。。
