[Atmel] Atmel SMART™ SAM D09 ARM®-Cortex®-M0+ MCU介绍
1019|0
 楼主| ddllxxrr 发表于 2016-3-21 06:29 | 显示全部楼层 |阅读模式
Atmel SMART SAM D09 ARM-Cortex-M0+ 单片机是小的,减少ARM Cortex-M0+的特性集的MCU。
SAM D09 MCU设计为简单的SAM D系列设备之间的代码迁移。它们的管脚与SAM D10系列兼容。
这允许很容易增加特性并迁移到容量大的设备上。SAM D09 芯片运行最大频率是48MHz。
提供14-24个管脚封装,高达16KB Flash和4KB SRAM。所有的芯片包括Atmel为内部外设信号的事件系统
和捕捉触摸接口
Processor
  • ARM Cortex-M0+ CPU running at up to 48MHz
    • Single-cycle hardware multiplier
    • Micro Trace Buffer
Memories
  • 8/16KB in-system self-programmable Flash
  • 4KB SRAM Memory
System
  • Power-on reset (POR) and brown-out detection (BOD)
  • Internal and external clock options with 48MHz Digital Frequency Locked Loop (DFLL48M) and 48MHz to 96MHz Fractional Digital Phase Locked Loop (FDPLL96M)
  • External Interrupt Controller (EIC)
  • 8 external interrupts
  • One non-maskable interrupt
  • Two-pin Serial Wire Debug (SWD) programming, test and debugging interface
Low Power
  • Idle and standby sleep modes SleepWalking peripherals
I/O
  • Up to 22 programmable I/O pins
Packages
  • 24-pin QFN
  • 14-pin SOIC
Operating Voltage
  • 2.4V – 3.63V
Peripherals
  • 6-channel Direct Memory
  • Access Controller (DMAC)
  • 6-channel Event System
  • Two 16-bit Timer/Counters (TC), configurable as either:
    • One 16-bit TC with compare/capture channels
    • One 8-bit TC with compare/capture channels
    • One 32-bit TC with compare/capture channels, by using two TCs
  • 32-bit Real Time Counter (RTC) with clock/calendar function
  • Watchdog Timer (WDT)
  • CRC-32 generator
  • Two Serial Communication Interfaces (SERCOM), each configurable to operate as either:
    • USART with full-duplex and single-wire half-duplex configuration
    • I²C Bus
    • SMBUS/PMBUS
    • SPI
    • LIN slave
  • 12-bit, 350ksps Analog-to-Digital Converter (ADC) with up to 10 channels
    • Differential and single-ended input
    • 1/2x to 16x programmable gain stage
    • Automatic offset and gain error compensation
    • Oversampling and decimation in hardware to support 13-, 14-, 15- or 16-bit resolution
0" unselectable="on" style="box-sizing: border-box; border-collapse: separate; font-size: 12px; border: 0px; width: 730px; background-color: transparent;">
Part NumberPackage / CaseProgram Memory SizeNumber of I/OsNumber of ADC Channels
ATSAMD09C13A-SSUT
SOIC-14
8 kB
12 I/O
5 Channel
ATSAMD09D14A-MUT
QFN-24 EP
16 kB
22 I/O
10 Channel
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2404
