[程序源码] 有人能帮帮我把程序详细的注释一下么,刚开始接触19264,...
1521|9
 楼主| sunny鱼儿 发表于 2016-4-8 11:39 | 显示全部楼层 |阅读模式
#include<C8051F020.h>
#include <stdio.h>
#include<INTRINS.h>
#define CsbOn  P5|=0X1;
#define CsbOff P5&=~0X1;
#define CsaOn  P5|=0X2;
#define CsaOff P5&=~0X2;
#define DiOn   P5|=0X4;
#define DiOff  P5&=~0X4;
#define RWOn   P5|=0X8;
#define RWOff  P5&=~0X8;
#define EOn    P5|=0X10;
#define EOff   P5&=~0X10;
/********************引脚定义********************/
/*sbit    DI  =P2^5;      //数据指令
sbit    RW  =P2^4;      //读写
sbit    E   =P3^7;      //使能
sbit    CSA =P2^7;      //片选信号A
sbit    CSB =P2^6;*/      //片选信号B
unsigned char page;     //页 地址
unsigned char col;      //列 地址
void wtcom(void);
/*unsigned char code BMP1[];
unsigned char code BMP2[];*/
unsigned char code puts[];
//unsigned char code bmp[2000];
/*unsigned char code puts2[];
unsigned char code puts3[];
unsigned char code puts4[];
unsigned char code puts5[];
unsigned char code puts6[];
unsigned char code puts7[];
unsigned char code puts8[];*/
void Delay (unsigned int MS);
/*void nop(void)
        int i;
        //for (i=0;i<1;i++);
        //i=1;
/*检查Busy                 */
void BusyL(void)
{                 CsaOff;
        //CSA=0;
                 CsbOff;
                //CSB=0;
        wtcom();
void BusyM(void)
       // CSA=0;
           CsaOff;
        //CSB=1;
           CsbOn;
        wtcom();
void BusyR(void)
        //CSA=1;
                CsaOn;
                //CSB=0;
                CsbOff
        wtcom();
void wtcom(void)
        //DI = 0;         //指令
        //RW = 1;                //读指令
                DiOff;
                RWOn;
        P6 = 0xFF;      //输出0xff以便读取正确
                EOn;
        //E  = 1;
       _nop_();
        while(P6 & 0x80);       //Status Read Bit7 = BUSY;如果忙,死循环,等待
                EOff;
        //E  = 0;
        _nop_();
void Locatexy(void)          //坐标定位
        unsigned char x,y;
        switch (col &0xc0)
                case 0x00:{BusyL();break;}
                case 0x40:{BusyM();break;}
                case 0x80:{BusyR();break;}
        x =col &0x3f | 0x40;
        y=page &0x07 | 0xB8;
        wtcom();
        //DI =0;
        //RW =0;
        DiOff;
        RWOff;
        P6=y;
        //E =1;
         EOn;
    _nop_();
        //E=0;
         EOff;
        _nop_();
        wtcom();
        //DI =0;
        //RW =0;
        DiOff;
        RWOff;
        P6 =x;
        //E =1;
        EOn;
        _nop_();
        //E=0;
        EOff;
        _nop_();
void WriteCommandL( unsigned char CommandByte)
        BusyL();
        P6 = CommandByte;
        //DI =0;
        //RW =0;
        //E =1;
        DiOff;
        RWOff;
        EOn;
        _nop_();
        //E=0;
        EOff;
        _nop_();
void WriteCommandM( unsigned char CommandByte)
        BusyM();
        P6 = CommandByte;
        //DI =0;
        //RW =0;
        //E =1;
        DiOff;
        RWOff;
        EOn;
        _nop_();
        //E=0;
        EOff;
        _nop_();
void WriteCommandR( unsigned char CommandByte)
        BusyR();
        P6 = CommandByte;
        //DI =0;
        //RW =0;
        //E =1;
        DiOff;
        RWOff;
        EOn;
        _nop_();
        //E=0;
        EOff;
        _nop_();
unsigned char ReadData(void)
        unsigned char DataByte;
        Locatexy();
        //DI =1;
        //RW =1;
        DiOn;
        RWOn;
        P6 =0xFF;
        //E =1;
        EOn;
        _nop_();
        DataByte =P6;
        //E =0;
        EOff;
        _nop_();
        return DataByte;
void WriteData (unsigned char DataByte)
        Locatexy();
        //DI =1;
        //RW =0;
     DiOn;
         RWOff;
        P6=DataByte;
        //E =1;
        EOn;
        _nop_();
        //E =0;
        EOff;
    _nop_();
void LcmClear(void)
        page =0;
        col =0;
        for (page=0;page<8;page++)
                for (col =0;col<192;col++)
                        WriteData(0);
void LcmInit(void)
        WriteCommandL(0x3f);
        WriteCommandM(0xc0);
        WriteCommandR(0x3f);
        WriteCommandL(0xc0);
        WriteCommandR(0xc0);
        WriteCommandM(0x3f);
        LcmClear();
        col =0;
        page =0;
        Locatexy();
void LcmPutThreehz ( unsigned char *puts)
        unsigned  int x=0;
    page =0;
        col =0;
                for (col=0;col<64;col++)
                        WriteData(puts[x]);
                        x++;
        page =0;
        col =64;
                for (col=64;col<128;col++)
                        WriteData(puts[x]);
                        x++;
        page =0;
        col =128;
                for (col=128;col<192;col++)
                        WriteData(puts[x]);
                        x++;
void Delay(unsigned int MS)
        unsigned char us,usn;
        while (usn!=0)
                usn =2;
                while (usn!=0)
                        us =0xf6;
                        while(us!=0) {us--;};
                        usn--;
                MS--;
void main (void)
         WDTCN     = 0xDE;
         WDTCN     = 0xAD;
         XBR2      = 0x40;
//        unsigned int i;
        Delay(1);
        LcmInit();
        while(1)
       LcmPutThreehz( puts );
                Delay(30);
/*--  文字:  小  --*/
/*--  宋体12;  此字体下对应的点阵为:宽x高=16x16   --*/
/*unsigned char code puts[]={
0x00,0x00,0x00,0xC0,0x70,0x20,0x00,0xFF,0x00,0x10,0x20,0xC0,0x80,0x00,0x00,0x00,
0x04,0x02,0x01,0x00,0x00,0x40,0x80,0x7F,0x00,0x00,0x00,0x00,0x01,0x07,0x02,0x00,
0x00,0x08,0x28,0x49,0x8A,0x0C,0xC8,0x38,0x08,0x00,0xF8,0x00,0x00,0xFF,0x00,0x00,
0x40,0x20,0x10,0x08,0x04,0x03,0x06,0x38,0x10,0x00,0x07,0x20,0x40,0x3F,0x00,0x00,
0x00,0xFE,0x02,0x12,0x92,0x92,0x92,0x92,0x92,0x92,0x92,0x12,0x02,0xFE,0x00,0x00,
0x00,0xFF,0x00,0x00,0x1F,0x08,0x08,0x08,0x08,0x08,0x1F,0x40,0x80,0x7F,0x00,0x00,
0x00,0x08,0x48,0x48,0x48,0x48,0x48,0x7F,0x48,0x48,0x48,0x48,0x48,0x48,0x08,0x00,
0x20,0x1C,0x00,0x00,0x3E,0x40,0x40,0x41,0x4E,0x44,0x40,0x70,0x22,0x1C,0x08,0x00,
0x00,0x40,0x40,0x48,0x48,0xC8,0x09,0xFA,0x46,0x80,0x40,0x20,0x30,0x00,0x00,0x00,
0x20,0x20,0x10,0x0C,0x03,0x40,0x80,0x7F,0x00,0x00,0x03,0x04,0x08,0x10,0x10,0x00,
0x80,0x90,0x94,0x94,0xF4,0x94,0x94,0xFE,0x92,0x92,0xF2,0x93,0x92,0x90,0x90,0x00,
0x00,0x04,0x44,0x44,0x47,0x44,0x44,0x7F,0x44,0x44,0x47,0x44,0x44,0x44,0x00,0x00,
0x00,0x02,0x02,0x02,0x02,0x82,0x42,0xFE,0x06,0x42,0xC2,0x82,0x02,0x03,0x02,0x00,
0x00,0x08,0x04,0x02,0x01,0x00,0x00,0x7F,0x00,0x00,0x00,0x01,0x07,0x02,0x00,0x00,
0x08,0x08,0xC8,0xFF,0x48,0x88,0x0A,0x02,0x42,0x7E,0x42,0x42,0x42,0xC2,0x02,0x00,
0x04,0x03,0x00,0x7F,0x00,0x01,0x00,0x00,0x00,0x00,0x20,0x40,0x20,0x1F,0x00,0x00,}; */
/*--  文字:  人  --*/
/*--  宋体48;  此字体下对应的点阵为:宽x高=64x64   --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0xF0,0xF0,0xE0,
0xE0,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFC,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFD,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0xFF,0xFF,0xFF,0xFF,0x1F,
0x3F,0xFF,0xFC,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0xFF,0xFF,0xFF,0xFF,0x0F,0x00,
0x00,0x07,0x7F,0xFF,0xF8,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xF0,0xFE,0xFF,0xFF,0x7F,0x0F,0x01,0x00,0x00,
0x00,0x00,0x00,0x07,0x1F,0xFF,0xFF,0xF8,0xE0,0x80,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x80,0xC0,0xE0,0xF8,0xFE,0x7F,0x1F,0x0F,0x03,0x01,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x0F,0x1F,0x7F,0xFF,0xFC,0xF8,0xE0,0xC0,0x80,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xC0,0xE0,0xE0,0x70,0x78,0x3C,
0x1E,0x0F,0x07,0x03,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x07,0x0F,0x1F,0x3F,
0x7F,0xFE,0xFE,0xFC,0xF8,0xF0,0xF0,0xE0,0xE0,0xE0,0xC0,0xC0,0xC0,0x80,0x00,0x00,
0x00,0x00,0x00,0x18,0x1C,0x0C,0x0E,0x07,0x07,0x03,0x01,0x01,0x00,0x00,0x00,0x00,
0x00,0x00,0x01,0x03,0x07,0x07,0x0F,0x03,0x03,0x01,0x01,0x01,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x38,0x78,0xF0,0xF0,0xE0,0xE0,0xC0,0x80,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x03,0x1F,0x7F,0x7F,0x7F,
0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xC0,0xC0,0x80,0x00,
0x00,0x00,0x00,0x00,0x00,0x02,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,
0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,
0x06,0x06,0x06,0x06,0x06,0x86,0xC6,0xE6,0xFE,0xFE,0xFF,0x7F,0x3F,0x3F,0x1F,0x0F,
0x0E,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xC0,
0xE0,0xF0,0xF8,0x7C,0x3E,0x1F,0x0F,0x07,0x03,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xC0,0xE0,0xF0,0x78,0x3C,0x1F,0x0F,0x07,
0x03,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xC0,0xC0,
0xE0,0xF0,0xF8,0x7C,0x3E,0x1E,0x0F,0x07,0x03,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x10,0x30,0x78,0xF8,0xFC,0xFC,0x7E,0x3E,0x1F,0x0F,0x07,0x07,0x03,0x03,
0x03,0x07,0x0E,0x1C,0x3C,0x78,0xF0,0xF0,0xF0,0xE0,0xE0,0xE0,0xC0,0xC0,0xC0,0xC0,
0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,
0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xE0,0xE0,0xE0,0x60,0x60,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x03,0x03,0x03,0x03,0x03,
0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,
0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x07,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x1C,0x38,0xF8,
0xF0,0xE0,0xE0,0xC0,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x81,
0x8F,0x9F,0x9F,0x9F,0x87,0xC0,0xE0,0xE0,0xC0,0x80,0x00,0x00,0x00,0x30,0x30,0x30,
0x30,0x30,0x30,0x30,0x30,0xF0,0xF0,0xF0,0xF0,0x30,0x30,0x30,0x30,0x30,0x30,0x30,
0x30,0x30,0x30,0x30,0x30,0x30,0xF0,0xF8,0xFC,0xFC,0xF8,0x30,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
0x81,0xC1,0xF1,0xFD,0xFF,0x7F,0x1F,0x0F,0x03,0x03,0x01,0x80,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0x01,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xC0,0xE0,0xF0,0xFC,0xFE,
0xFF,0xFF,0xFF,0x01,0x00,0x00,0x80,0xE0,0xF0,0x7C,0x3F,0x1F,0x1F,0x0E,0x0C,0x00,
0x00,0x00,0x00,0x00,0xFE,0xFF,0xFF,0xFF,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0xF0,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x80,0xC0,0xE0,0x70,0x38,0x1C,0x0E,0x0F,0x07,0x03,0x01,0x00,0xFF,
0xFF,0xFF,0xFF,0x06,0x0E,0x0F,0x1F,0x3D,0x7C,0xF8,0xF8,0xF0,0xE0,0x00,0x00,0x00,
0x00,0x00,0x80,0xFC,0xFF,0xFF,0x7F,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0x03,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,
0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x03,0x07,0x03,0x00,0x00,0xC0,
0xF0,0xFC,0xFF,0x3F,0x0F,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0xFE,0xFF,0xFF,0xFF,0x3F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,
0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xC0,0xF0,0xF8,0x7C,0x3F,0x0F,
0x07,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,
0xC0,0xC0,0xC0,0xF8,0xFF,0xFF,0xFF,0x3F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,
0x1F,0x1F,0x0F,0x00,0x00,0x08,0x0C,0x0E,0x07,0x03,0x01,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x03,0x07,0x0F,
0x1F,0x1F,0x0F,0x0F,0x07,0x03,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,};
dirtwillfly 发表于 2016-4-8 11:48 | 显示全部楼层
这里面不是有注释么?
 楼主| sunny鱼儿 发表于 2016-4-8 12:20 | 显示全部楼层
这里面不是有注释么?
他这个注释我看不太明白,还有就是那些个函数都有什么作用 我也不懂...
lr_xgm 发表于 2016-4-8 13:16 | 显示全部楼层
哪句不懂可以问
 楼主| sunny鱼儿 发表于 2016-4-8 14:13 | 显示全部楼层
哪句不懂可以问
        unsigned char x,y;
        switch (col &0xc0)
这一段是什么意思啊
lyping 发表于 2016-4-8 16:00 | 显示全部楼层
哪位闲的蛋疼可以试一下
ningling_21 发表于 2016-4-8 16:37 | 显示全部楼层
        unsigned char x,y;
可以结合芯片资料去看程序,光看程序不太好懂
123654789 发表于 2016-4-8 16:40 | 显示全部楼层
购买液晶,商家赠送程序。
如果不送程序,就不买。
根本就不用自己写程序。
 楼主| sunny鱼儿 发表于 2016-4-8 16:59 | 显示全部楼层
购买液晶,商家赠送程序。
如果不送程序,就不买。
商家赠送的是汇编
lr_xgm 发表于 2016-4-8 17:24 | 显示全部楼层
这个屏分左中右三个区,列 0-63,64-127, 128-191,根据显示的位置,设置列地址,由于列地址只有0-63,所以有3个片选,分别设置3个区域。
