呵呵,发一个电工们的"杀**用牛刀"作品
6627|22
在网上转悠,发现一个国外网内非常擂人的作品,的确很有趣,先上图
古道热肠|  楼主 | 2009-11-25 22:30 | 只看该作者
呵呵,您能看出这网友为了啥忙呼吗?
贴上英文提示:
Another unexpected side project.
I decided to use some LPC903 controllers in another project. I ordered a Keil MCB900 evaluation board to program them.
For whatever reason Farnell decided to cancel my order with a "No MCB900 delivery out of the UK" statement. The article was removed from their stock, too.
古道热肠|  楼主 | 2009-11-25 22:31 | 只看该作者
继续上英文
There exist two different programming methods for the LPC900 series:
ISP, in-system programming via serial interface; only supported by "bigger" LPCs
ICP, in-circuit programming via "SPI" interface; for the small ones, like my LPC903
While a direct serial (e.g. a level shifted RS232) connection is sufficient for ISP, I need the more complicated (aka.: not readily available and connectable) one: ICP...
You can hook up the ISP programmables to FlashMagic directly (serial interface) but the ICP types require additional hardware and a "translation" of ISP to ICP codes.
Obviously, all the programming specifications seem(ed) to be *pssst!* a state secret and none of the documents provided by NXP matched the actual programming algorithm.
Anyway, nobody said it can't be done ;)
The equipment...
古道热肠|  楼主 | 2009-11-25 22:32 | 只看该作者
这个单词"*pssst!* "俺不认识.
古道热肠|  楼主 | 2009-11-25 22:34 | 只看该作者
写的代码更擂人,呵呵
-- nxt2nxp v0.3 (ASkr 9/2009)
-- LPC90X ICP programmer (for FlashMagic, until now)
-- !!! pbLua >= v18c required !!!
--  - USB connection preferred
--  - You may need to download this source in several parts.
--    Otherwise pbLuas byte compiler may run out of memory!
--    Use the "*** for download, only ***" (followed by a garbage-collect)
--    markings as a suggested split indicator.
nxt=nil
collectgarbage("collect")
require("nxt_misc")
require("nxt_input")
require("nxt_rs485")
require("nxt_file")
require("nxt_display")
-- *** for download, only ***
gDisCol=0
gChkSum=0
gBytes=0
gAdrHi=0
gAdrLo=0
gRecType=0
gRec7=0
gTB={}
-- utilWait()
-- Waits (blocks) for <tim> ms.
function utilWait(tim)
  local stim=nxt.TimerRead()
  repeat
  until nxt.TimerRead() > stim+tim
end
-- uWait()
-- Waits (blocks) for ~<c> us.
-- Minimum value is ~80us
-- Use this while in a nxt.DisableNXT(1) <-> nxt.DisableNXT(0) loop!
function uWait(c)
  local i
  c=c*10
  c=(c/24)-32
  for i=1,c do
  end
end
-- ICPloop
function ICPloop()
  local ch;
  local i
  while 1 do
    gChkSum=0
    repeat
      ch=ICPecho()
      -- baud rate detection override
      if ch=="U" then
        nxt.FileWrite(0,"U")
      end
      -- try to enter prog mode again
      if ch=="'" then
        ICPinit()
        ICPenter()
      end
    until ch==":" or ch=="*"
    if ch=="*" then break end
    gBytes=ICPget2()
    gAdrHi=ICPget2()
    gAdrLo=ICPget2()
    gRecType=ICPget2()
    for i=0,gBytes-1 do
      gTB[i]=ICPget2()
    end
    gRec7=gChkSum
    if gRec7 ~= ICPget2() then
      print("X")
      gRecType=999
    end
    -- *** READ_VERSION ***
    if gRecType==1 then
      nxt.FileWrite(0,string.format("%02x",0x07))
      print(".")
    -- *** PROGRAM ***
    elseif gRecType==0 then
      ICPprogram()
      print(".")
    -- *** MISC_WRITE ***
    elseif gRecType==2 then
      ICPwrite_config()
      print(".")
    -- *** MISC_READ ***
    elseif gRecType==3 then
      ICPread_config()
      nxt.FileWrite(0,string.format("%02x",gTB[0]))
      print(".")
    -- *** ERASE ***
    elseif gRecType==4 then
      if gTB[0]==0 then
        ICPerase_page()
        print(".")
      elseif gTB[0]==1 then
        ICPerase_sector()
        print(".")
      else
        print("R")
      end
    -- *** SECTOR CRC ***
    elseif gRecType==5 then
      ICPcrcsector()
      gRecType=888
    -- *** GLOBAL CRC ***
    elseif gRecType==6 then
      ICPcrcglobal()
      gRecType=888
    -- *** CHIP_ERASE ***
    elseif gRecType==8 then
      ICPerase_global()
      print(".")
    -- *** CONTINUE ***
    elseif gRecType==999 then
      i=i
    -- *** INCORRECT RECORD TYPE ***
    elseif 1 then
      print("R")
    end -- elseif
    -- *** PRINT CRC ***
    if gRecType==888 then
      nxt.FileWrite(0,string.format("%02x",gTB[3]))
      nxt.FileWrite(0,string.format("%02x",gTB[2]))
      nxt.FileWrite(0,string.format("%02x",gTB[1]))
      print(".")
    end
  end -- while 1
end
-- dp()
-- debug print
function dp(msg)
  nxt.DisplayText(string.format("%02x",msg),gDisCol)
  gDisCol=gDisCol+20
  if gDisCol >= 100 then
    gDisCol=0
    nxt.DisplayScroll()
  end
end
-- ICPinit
function ICPinit()
  -- Port 2
  --   dig0 -> PDA
  --   dig1 -> PCL
  --   POWER
  nxt.InputSetType(2,0)
  nxt.InputSetDir(2,1,1)
  nxt.InputSetState(2,0,0)
  -- Port 3
  --   dig0 -> n.c.
  --   dig1 -> VDD
  nxt.InputSetType(3,0)
  nxt.InputSetDir(3,1,1)
  nxt.InputSetState(3,0,0)
  -- Port 4
  --   dig0 -> n.c.
  --   dig1 -> RESET
  nxt.InputSetType(4,0)
  nxt.InputSetDir(4,1,0)
  utilWait(1000)
end
-- ICPexit
function ICPexit()
  -- damn, someone deleted this ;)
end
-- ICPenter
-- PureMagic ;)
function ICPenter()
  local dat=string.char(0xf0,0xf0,0xf0,0xf0,0xf0,0xf0,0xf0)
  local i
  local j
  nxt.DisableNXT(1)
  nxt.RS485Enable(230000)   -- works fine...
--  nxt.RS485Enable(460000) -- NORMAL !!!
--  nxt.RS485Enable(921600)
  nxt.InputSetState(4,1,1)
  utilWait(1500)
  nxt.InputSetState(3,1,1)
  uWait(1000)
  nxt.RS485SendData(dat)
  nxt.InputSetState(4,1,0)
  -- for 460000 bit/s: 45
  -- for 230000 bit/s: 90
  for i=1,90 do
    j=i
  end
  nxt.DisableNXT(0)
end
-- ICPwait128
function ICPwait128()
  local i
  repeat
    ICPmultishiftout({0x0f})
    i=ICPshift_in()
    -- emergency exit
    if nxt.ButtonRead() ~= 0 then
      break
    end
  until(i>127)
end
-- ICPecho
function ICPecho()
  local ch
  ch=nxt.FileRead(0,1)
  ch=string.upper(ch)
  nxt.FileWrite(0,ch)
  return ch
end
-- ICPascii2hex
function ICPascii2hex(ch)
  -- alternative:
  local i
  ch=string.byte(ch)
  if ch > 0x3f then
    ch=ch+9
  end
  i=ch/16   -- shift right and snip
  i=i*16    -- shift snipped val left
  ch=ch-i
--  ch=string.byte(ch)
--  if nxt.band(ch,0x40) ~= 0 then
--    ch=ch+9
--  end
--  ch=nxt.band(ch,0x0f)
  return ch
end
-- ICPget2
function ICPget2()
  local ch
  ch=ICPascii2hex(ICPecho())*(2^4)
  ch=ch+ICPascii2hex(ICPecho())
  gChkSum=gChkSum-ch
  if gChkSum < 0 then
    gChkSum=gChkSum+256
  end
  return ch
end
-- ICPmultishiftout
--   DIG0 -> PDA
--   DIG1 -> PCL
function ICPmultishiftout(ch)
  local i,j
  local byte
  for _,byte in ipairs(ch) do
    nxt.DisableNXT(1)
    for i=1,8 do
      nxt.InputSetState(2,0,0)      -- PCL low (NEW: was low before)
      if byte%2 == 1 then
        j=1
      else
        j=0
      end
      nxt.InputSetState(2,j,0)        -- set PDA (and keep PCL)
      nxt.InputSetState(2,j,1)        -- PCL high (but keep PDA)
      byte=byte/2
    end
    nxt.InputSetState(2,0,0)        -- PCL and PDA low
    nxt.DisableNXT(0)
  end -- end for whole table
end
-- ICPshift_in
--   DIG0 -> PDA
--   DIG1 -> PCL
function ICPshift_in()
  local i,rbit
  local di=0
  nxt.DisableNXT(1)
  nxt.InputSetDir(2,0,1)        -- PDA input
  for i=1,8 do
    di=di/2
    nxt.InputSetState(2,nil,1)      -- PCL high
    _,rbit=nxt.InputGetStatus(2)
    if rbit == 1 then
      di=di+128
    end
    nxt.InputSetState(2,nil,0)      -- PCL low
  end
  nxt.InputSetState(2,0,0)        -- keep both low
  nxt.DisableNXT(0)
  return di
end
-- ICPprogram
function ICPprogram()
  local i
  for i=0,gBytes-1 do
    ICPmultishiftout({0x08,gAdrLo,0x0a,gAdrHi,0x0e,0x00,0x0c,gTB[i],0x0e,0x48})
    ICPwait128()
    gAdrLo=gAdrLo+1
    if gAdrLo>255 then
      gAdrLo=0
      gAdrHi=gAdrHi+1
    end
  end -- end for
end
-- ICPcrcsector
function ICPcrcsector()
  local i
  ICPmultishiftout({0x0a,gTB[0],0x0e,0x19})
  ICPwait128()
  for i=0,3 do
    ICPmultishiftout({0x05})
    gTB[i]=ICPshift_in()
  end
end
-- ICPcrcglobal
function ICPcrcglobal()
  local i
  ICPmultishiftout({0x0e,0x1a})
  ICPwait128()
  for i=0,3 do
  end
end
-- ICPwrite_config
function ICPwrite_config()
  local i=0
  if gTB[0] == 0x10 then
    ICPmultishiftout({0x0e,0x67,0x0c,0x96 })
  else
    ICPmultishiftout({0x0e,0x6c,0x08,gTB[0],0x0c,gTB[1]})
  end
  ICPwait128()
end
-- ICPread_config
function ICPread_config()
  ICPmultishiftout({0x0e,0x6c,0x08,gTB[0],0x0d})
  gTB[0]=ICPshift_in()
end
-- ICPerase_global
function ICPerase_global()
  local i
  ICPmultishiftout({0x0e,0x72})
-- NEW
  for i=1,5 do
    ICPshift_in()
  end
  ICPwait128()
end
-- ICPerase_page
function ICPerase_page()
  local i
  ICPmultishiftout({0x08,gTB[2],0x0a,gTB[1],0x0e,0x70})
  ICPwait128()
end
-- ICPerase_sector
function ICPerase_sector()
  local i
  ICPmultishiftout({0x0a,gTB[1],0x0e,0x71})
  ICPwait128()
end
-- kill
-- On larger programs, like this, you may experience download problems of
-- changed functions because luas byte compiler needs too much memory...
-- Usually, there is no other way than rebooting you NXT.
-- Here's my strategy to empty the memory ;)
function kill()
  utilWait=nil
  uWait=nil
  ICPloop=nil
  dp=nil
  ICPinit=nil
  ICPexit=nil
  ICPenter=nil
  ICPwait128=nil
  ICPecho=nil
  ICPascii2hex=nil
  ICPget2=nil
  ICPmultishiftout=nil
  ICPshift_in=nil
  ICPprogram=nil
  ICPcrcsector=nil
  ICPcrcglobal=nil
  ICPwrite_config=nil
  ICPread_config=nil
  ICPerase_global=nil
  ICPerase_page=nil
  ICPerase_sector=nil
  t=nil
  print(collectgarbage("count"))
end
-- run
-- Leaves programming mode and "starts" your LPC90X.
-- !!! Be aware of potential short-circuit conditions if you use it for more than
-- !!! programming test firmware!
-- !!! Reset and PCL pins are always outputs on NXT2NXP!
function run()
  -- hold in reset (low)
  nxt.InputSetDir(4,1,1)
  nxt.InputSetState(4,0,1)
  -- power off
  utilWait(1500)
  -- power on
  nxt.InputSetState(3,0,1)
  -- go...
  nxt.InputSetState(4,0,0)
end
-- prog
-- Starts programming mode.
-- Disconnect from your port and start FlashMagic afterwards...
function prog()
  local i
  for i=1,8 do
    nxt.DisplayScroll()
  end
  ICPinit()
  ICPenter()
  ICPloop()
  ICPexit()
end
古道热肠|  楼主 | 2009-11-25 22:38 | 只看该作者
老外敢于实践,乐于动手的精神还是值得国人学习的.
程序匠人| | 2009-11-25 23:02 | 只看该作者
热肠给解说一下吧
古道热肠|  楼主 | 2009-11-25 23:33 | 只看该作者
哈哈,俺的英文也不好,连猜带蒙大概说说原创作者的杰作吧! 这老外估计也是个51铁杆粉丝,有一天要选中LPC903(1K代码,8脚Flash单片机)作为项目的主控芯片,由于LPC903只支持ICP编程,于是计划向Keil公司订购一台MCB900开发板做为ICP编程器使用.由于.....原因,订单被取消.作者气不打一处来,心想用万能编程器也太贵了,何不自己做一台ICP来完成功能呢?于是找来一台类似于"西门子"PLC的名叫NXT的装置作为主控 ,通个该设备的4个输出口,自制一个ICP接口电路,说干就干,先手绘,测试,再制板,终于整出个像模像样的东西, 那代码是NXT能识别的专用编程语言编写的,呵呵,太有趣了.
a1z26| | 2009-11-26 07:52 | 只看该作者
滔滔江水绵绵不绝。
aq_fd| | 2009-11-26 09:46 | 只看该作者
勇于钻研的老外啊。
杜专| | 2009-11-26 09:48 | 只看该作者
MARK
wolfli| | 2009-11-26 11:32 | 只看该作者
NXT是积木式机器人控制器,不是西门子的PLC。
精益求精| | 2009-11-26 12:18 | 只看该作者
呵呵。。
ningling_21| | 2009-11-26 12:26 | 只看该作者
比较强,相当的强.
zhenxing2000| | 2009-11-26 13:01 | 只看该作者
先收藏了
aq_fd| | 2009-11-26 15:03 | 只看该作者
勇于钻研的老外啊。
yangloong| | 2009-11-26 21:32 | 只看该作者
请求上传源文件 供大家瞧瞧
   谢谢。
北辰风~| | 2009-11-26 22:12 | 只看该作者
nnnn
hsw_21| | 2009-11-27 08:29 | 只看该作者
老外虽然人高马大,但是做事情相当仔细,认真;心灵手巧程度和苏州刺绣的小姑娘有的一拼啊。  :) 佩服!
john_light| | 2009-11-27 08:33 | 只看该作者
这分明是在玩吗!
个人签名:以VS1003B和山景SOC芯片为背景,倾心研制数字化语音录放产品. 排忧邮箱:xg_2004_sy@126.com 得意之作是做了个AVR高压编程器,用起来爽歪歪, 串口MP3录放音模块,全面进入数字录放音时代
284
