ADS8344数据老是跳,求助!!
2583|13
 楼主| wjs02 发表于 2009-12-14 13:44 | 显示全部楼层 |阅读模式
哪位用过ADS8344的,能否帮我看下程序,数字量输出老是跳,不稳定。比如2V输入,满量程5V,结果波动会在26200~26000.
或者谁有代码可以给我参考下,万分感谢!!
#include "C8051F040.h"
#include "ABSACC.H"
#include <intrins.h>
  sbit ADC_CLK   =P0^2;//19
  sbit ADC_DOUT  =P0^3;//15
  sbit ADC_DIN   =P0^4;//17
  sbit ADC_CS0   =P0^5; //18
  sbit ADC_CS1   =P0^6;//18
  sbit ADC_BUSY0 =P0^7; //16
  sbit ADC_BUSY1 =P1^0;//16
unsigned char data AttData[3];
void Timer_Init()
    SFRPAGE   = TIMER01_PAGE;
    TMOD      = 0x22;
    TH1       = 0x4C;
    CKCON     = 0x12;
    TCON      = 0x44;
    TH0       = 0x9C;
     SFRPAGE   = TMR2_PAGE;
     TMR2CN    = 0x04;
void UART_Init()
    SFRPAGE   = UART0_PAGE;
    SCON0     = 0x50;
    SCON0     &= 0xFC;
    SSTA0     = 0x10;
void EMI_Init()
    SFRPAGE   = EMI0_PAGE;
    EMI0CF    = 0x3B;
void Port_IO_Init()
{   SFRPAGE   = CONFIG_PAGE;
    P0MDOUT   = 0x76;
    P0=88;
P1MDOUT   = 0xFF;
    P4MDOUT   = 0xFF;
    P5MDOUT   = 0xFF;
    P6MDOUT   = 0xFF;
    P7MDOUT   = 0xFF;
    XBR0      = 0x04;
    XBR2      = 0x40;
void Oscillator_Init()
    int i = 0;
    OSCICN    = 0x80;
  CLKSEL    = 0x00;
void Interrupts_Init()
    IE        = 0xB2;
    IP        = 0xD2;
    EIE2      = 0x20;
void WatchDog_Init()
   WDTCN=0x47;
   WDTCN=0xDE;
   WDTCN=0xAD;
void Init_Device(void)
    WatchDog_Init();
    Timer_Init();
    UART_Init();
    EMI_Init();
    Port_IO_Init();
    Oscillator_Init();
    Interrupts_Init();
void ADC_Delay(void)
  int k=0;
  //for(k=0;k<5;k++);
    for(k=0;k<50;k++); //change by wb
//AD转换函数 chan:0-15
unsigned int ADC ( unsigned char chan)
   unsigned int  ADdata=0;
unsigned char idata outcmd;
unsigned char code ChannelTable[8]={0,4,1,5,2,6,3,7};//转换表格
int i;
   ADC_DIN=0 ;
   //通道有效性检查
if(chan<0)
chan=0;
if(chan>15)
chan=15;
   //使能芯片
ADC_CLK=0;
     ADC_CS0=0;
     ADC_Delay();
   // 写命令
   outcmd=(ChannelTable[chan]<<4) | 0x86;  //内时钟模式。
   for(i=0;i<8;i++)
       ADC_CLK=0;
        ADC_Delay();
   if(outcmd&0x80)
   ADC_DIN=1;
       else ADC_DIN=0;
       outcmd=outcmd<<1;
       ADC_CLK=1;
       ADC_Delay();
     ADC_CLK=0;
         ADC_CS0=1;
//等待转换结束
      if(chan<8)
        while(!ADC_BUSY0);
      else
       while(!ADC_BUSY1);
  //ADC_CLK=1;//by wb
       ADC_CS0=0;
   //ADC_Delay();
for(i=0;i<16;i++)
  { ADdata= ADdata<<1;
   ADC_CLK=1;//by wb
   ADC_Delay();//by wb
   ADC_CLK=0;//by wb
   ADC_Delay();//by wb
   if(ADC_DOUT)
ADdata|=0x0001;
   //ADC_Delay();
for(i=0;i<8;i++)
   ADC_CLK=1;//by wb
   ADC_Delay();//by wb
   ADC_CLK=0;//by wb
   ADC_Delay();//by wb
    ADC_CS0=1;
    return ADdata ;
  void main()
    unsigned int j=0;
int k;
    Init_Device();
    XBYTE[0xFF80]=0x00  ;     //55;
    j=ADC(0);
k=0;
thf2008 发表于 2009-12-15 00:17 | 显示全部楼层
你用的是什么片子?用的是SPI通讯吧,我现在也一直在做ADS8344的通讯,有时间可以交流一下,我的QQ是87478377
linhai2009 发表于 2009-12-15 00:32 | 显示全部楼层
没看懂:dizzy:
thf2008 发表于 2009-12-16 16:28 | 显示全部楼层
怎么没人回答?很想了解这个芯片
五谷道场 发表于 2009-12-16 18:19 | 显示全部楼层
这么长的码……
linhai2009 发表于 2009-12-16 23:56 | 显示全部楼层
还行,好像是51的码,不过没用过ADS8344也帮不上忙
thf2008 发表于 2009-12-18 00:22 | 显示全部楼层
今天想了想,会不会是你的参考电源不稳定造成的啊
linhai2009 发表于 2009-12-18 00:51 | 显示全部楼层
很有可能
 楼主| wjs02 发表于 2009-12-19 10:23 | 显示全部楼层
硬件方面的问题都考虑过了
hulan1985 发表于 2009-12-19 22:16 | 显示全部楼层
那就不是很明白了……
五谷道场 发表于 2009-12-20 23:07 | 显示全部楼层
这个……帮顶……
xiaoxin1986 发表于 2009-12-21 12:27 | 显示全部楼层
同问,过来学习
NICKY99 发表于 2009-12-29 16:15 | 显示全部楼层
时序的精确度影响的吧
linhai2009 发表于 2009-12-29 21:49 | 显示全部楼层
13# NICKY99
什么意思?能详细的说说嘛?
