| #include <avr/io.h> #include <avr/delay.h>
 #define uchar unsigned char
 #define uint unsigned int
 uchar np;
 //步进电机运行数据表
 const uchar motortb[]={0x11,0x99,0x88,0xcc,0x44,0x66,0x22,0x33};
 void delay_nms(uint ms)// 每步延时的子程序
 uint i;
 for(i=0;i<ms;i++)
 _delay_loop_2(8*250);
 void a_step(uchar d,uchar t) //步进电机走一步d=0 正转d=1 反转 t 越大走得越慢
 if (d&0x01)
 if (np==0)
 np=7;
 else
 np--;
 else
 if (np==7)
 np=0;
 else
 np++;
 PORTD=motortb[np];
 delay_nms(t);
 void a_turn(uchar d,uchar t)// 步进电机走一圈
 uchar i;
 for (i=0;i<96;i++)
 a_step(d,t);
 int main(void)
 DDRD=0xff;
 PORTD=0x44;
 DDRB=0xff;
 PORTB=0xff;
 np=4;
 while (1)
 a_turn(1,200);
