瑞萨LIN总线例题帮忙解析一下
1195|1
zhangdongze|  楼主 | 2016-8-25 21:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#pragma vector = INTLR_vect
__interrupt static void LIN_Slave_interrupt_receive(void)
  uint16_t  header_receive_flag;
  uint16_t  buffer_receive_flag;
  uint8_t  PID;
  header_receive_flag = UF0STR & 0x0800;
  buffer_receive_flag = UF0STR & 0x0400;
  if(header_receive_flag != 0)
  UF0STC |= 0x0800;    /* clear UF0HDC*/
  PID = UF0ID;
  switch (PID)
  case 0x08 : LIN_Slave_Receive(3);
              break;
  case 0x49 : LIN_Slave_Receive(3);
              break;
  case 0xCA : LIN_Slave_Receive(3);
              break;
  case 0x8B : LIN_Slave_Transmit(Slave_TxData, 2);
              LED1=OFF;
              LED2=OFF;
              break;
   default:   break;
  if(buffer_receive_flag != 0)
    PID = UF0ID;
    switch (PID)
    case 0x08 :    P7 = Get_response_RxData(Slave_RxData1);
                   break;
    case 0x49 :    P7 = Get_response_RxData(Slave_RxData2);
                   break;
    case 0xca  :   P7 = Get_response_RxData(Slave_RxData3);
                   break;
    default:   LIN_Slave_NoResponse();
                  break;
      UF0STC |= 0x0400;   /*Clear UF0BUC*/
在线求高手解析
zhangdongze|  楼主 | 2016-8-26 08:41 | 只看该作者
没人回答
