stm32串口1,2,3,4为什么1,2可以,3,4就不行啊。
14810|13
 楼主| qljqlj 发表于 2010-3-24 11:47 | 显示全部楼层 |阅读模式
USART_InitStructure.USART_BaudRate = 115200;
    USART_InitStructure.USART_WordLength = USART_WordLength_8b;
    USART_InitStructure.USART_StopBits = USART_StopBits_1;
    USART_InitStructure.USART_Parity = USART_Parity_No ;
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
    USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
    /* Configure the USART */
    USART_Init(USART1, &USART_InitStructure);
    USART_Init(USART2, &USART_InitStructure);
    USART_Init(USART3, &USART_InitStructure);
    USART_Init(UART4, &USART_InitStructure);
    /* Configure the IT */
    USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
    USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);
    USART_ITConfig(USART3, USART_IT_RXNE, ENABLE);
    USART_ITConfig(UART4, USART_IT_RXNE, ENABLE);
    /* Enable the USART */
    USART_Cmd(USART1, ENABLE);
     USART_Cmd(USART2, ENABLE);
     USART_Cmd(USART3, ENABLE);
     USART_Cmd(UART4, ENABLE);
 楼主| qljqlj 发表于 2010-3-24 11:48 | 显示全部楼层
不行。。。是指发送不出数据来,但是能中断接收,另外gpio和rcc初始化都是一样的。郁闷。。。
 楼主| qljqlj 发表于 2010-3-24 13:33 | 显示全部楼层
我承认这个问题很简单,可是我初始化4个串口的代码是完全一样的,可是为什么1,2可以,3,4不行啊。。。。该有的,我都初始化了。。。。。
笑苍天 发表于 2010-3-24 16:31 | 显示全部楼层
能收不能发,说明串口配置是正确的
请检查串口3,4的发送脚硬件连接
acent 发表于 2010-3-24 16:38 | 显示全部楼层
楼主可以参考一下 我用3.0的库
void USART3_Configuration(void)
        USART_ClockInitTypeDef USART_ClockInitStructure;
        USART_InitTypeDef USART_InitStructure;
        /*使能USART1时钟*/
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE);
    /* Configure USART3 Rx (PB.11) as input floating */
          GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
          GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
          GPIO_Init(GPIOB, &GPIO_InitStructure);
        /* Configure USART3 Tx (PB.10) as alternate function push-pull */
          GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
          GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    /*设置USART3波特率为115200*/
          USART_InitStructure.USART_Parity = USART_Parity_No;
          /* Configure USARTx */
        USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
        USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
        USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
        USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
        USART_ClockInit(USART3, &USART_ClockInitStructure);
    /* Enable the USARTx */
    /* Enable the USARTx rx it*/
    USART_ITConfig(USART3, USART_IT_RXNE, ENABLE);}
另外发送函数USART_SendData(USARTx, c);因为库函数没有等待发送完成标志,所以连续发送可能会出错,可以改成这样void USARTx_Putc(USART_TypeDef* USARTx,char c)
     while(USART_GetFlagStatus(USARTx, USART_FLAG_TC) == RESET);
IJK 发表于 2010-3-24 17:42 | 显示全部楼层
是要注意:串口3,4的发送脚如果与其它外设共用,就可能有冲突,导致LZ的结果。
 楼主| qljqlj 发表于 2010-3-24 18:13 | 显示全部楼层
感谢楼上兄弟们的回复
1,管教应该没有虚焊之类的错误,我做了个io脉冲输出,都正常,这样应该确认芯片,硬件没问题吧,
2,我的串口没有复用,只是和外设相连。最简单的连接。
3,我搜遍google,发现用芯片不支持的问题,我用的是stm32f103vet6,datasheet上指出,是支持5串口的。
4,另外,我尝试着在接收3,接收4设置断点,结果都正常中断。
    啧啧,奇了,现在任务紧,没空瞎想,其他用的外设驱动进行的很顺利,不到一个礼拜,全打通了。妈的,居然在这上面栽跟头了。
    另外,用一次在仿真调试时,突然把主板电源断了,导致主板芯片,调试异常,啧啧,stm32感觉不是很泼辣。。。
   明天把异常的芯片焊下来,再装一个新的,看看是不是还是如此。。。。。:Q
pkat 发表于 2010-3-24 20:31 | 显示全部楼层
有可能是芯片问题,确定硬件外围没问题,就只能换芯片了
香水城 发表于 2010-3-25 09:29 | 显示全部楼层
楼主可以搜索一下,本版以前也有人遇到相似的问题,有的是PCB接线错了,有的是外部的232芯片有问题,有的是程序问题,还没有人说是STM32的问题。
香水城 发表于 2010-3-25 09:58 | 显示全部楼层
gwb721123 发表于 2010-3-25 12:27 | 显示全部楼层
看你的口线功能是不是在其他地方给改了
rider1 发表于 2010-3-25 12:53 | 显示全部楼层
UART3和SPI2有冲突,要把SPI的时钟关掉。
 楼主| qljqlj 发表于 2010-3-25 13:51 | 显示全部楼层
今天早上来就把调试异常的芯片换掉,结果还是一样,不是硬件,那肯定是软件了。
仔细分析程序,最有可能的就是rcc了,我把她们全都打开了,结果我逐一调试,发现
RCC_APB1Periph_I2C1,RCC_APB1Periph_I2C2打开导致usart3不正常,RCC_AHBPeriph_SDIO打开导致usart4不正常,想的可能是管脚冲突,打开管教定义,呵呵,的确如此。
刚才上网回帖的时候,rider1说的对,早看到,我就不逐一测试找原因了,耗5个小时,
谢谢大家。。。。。吃午饭去了
fengyan81 发表于 2010-3-25 16:16 | 显示全部楼层
呵呵,学习了
