EPS BLDC马达设计讨论
733|0
 楼主| crystal1902 发表于 2016-10-31 16:47 | 显示全部楼层 |阅读模式
各位技术大神们:
本女子在深圳有一个做EPS BLDC马达设计的职位在招聘
JD如下:
Position Summary:
As a key member in EPS Motor Design team, this role aims to develop EPS (Electronic Power Steering) BLDC motors and mechanical analysis, modeling and simulation for the automotive industry, mainly vehicle/OEM customers
Responsibilities:
        Design EPS BLDC motor to meet customer specifications and requirements
        Analyze and evaluate existing design, and conduct design optimization
        Work with internal purchasing team on components and materials supplier selection
        Prepare test plan, samples, and tooling; support test execution and evaluation
        Support the benchmarking and technology scouting. Track state-of-art motor technology for EPS business and application. Provide technical support to customers and JE peers
Requirements:
        Bachelor or above, major in Mechanical Engineering, Electrical Engineering, or Automotive Engineering
        5 years or above working experience in motor design and application in automotive field
        In-depth knowledge on motor manufacturing, machining, tooling and fixtures, quality system
        Skilled in CAD, SolidWorks, Catia, or UG
        Good team player, self-motivated, good problem-solving skills
        Able to work under high pressure
        Good command of written, reading and spoken English
大家如果有兴趣了解更多可以把大家的简历发到 crystal_ye@talentviewprc.com
我会与大家联系的,谢谢!
