- /* Copyright(c) 2015 Nuvoton Technology Corp. All rights reserved. */
- // Nuvoton Technology Corp.
- // E-mail: MicroC-8bit@nuvoton.com
- // Application : UART Function
- // RXD => P1.1 ; TXD => P1.0 (default)
- // Output : UART receive a byte and transmit the same byte to PC
- //------------------------- <<< Use Configuration Wizard in Context Menu >>> --------------------------------
- // <o0.6> UART pin Select
- // <0=> Select P1.0, P1.1 as UART pin(default)
- // <1=> Select P2.6, P2.7 as UART pin(28 pin only)
- //-------------------------------- <<< end of configuration section >>> -------------------------------------
- #define Uart_Port_Sel 0x00
- #include <stdio.h>
- #include "N79E715.h"
- #include "Typedef.h"
- #include "Define.h"
- #include "Common.h"
- #include "Delay.h"
- #include "Version.h"
- UINT8 u8Uart_Data;
- void main (void)
- AUXR1 |= Uart_Port_Sel; // Select P10/P11 as UART pin(default)
- InitialUART0_Timer1(9600); // 9600 Baud Rate [url=home.php?mod=space&uid=72445]@[/url] 11.0592MHz
- Show_Version_Number_To_PC();
- printf ("\n*===================================================================");
- printf ("\n* Name: N79E715 Series UART Sample Code.");
- printf ("\n UART receive a byte and transmit the same byte to PC.\n");
- ES = 1; // Enable serial interrupt
- EA = 1; // Enable global interrupt
- while(1); // Endless
- void UART_ISR(void) interrupt 4
- if (RI == 1)
- { // If reception occur
- RI = 1; // Clear reception flag for next reception
- u8Uart_Data = SBUF; // Read receive data
- SBUF = u8Uart_Data; // Send back same data on UART
- else TI = 0; // If emission occur
- // Clear emission flag for next emission
