Magnetically Immune Transformerless Power for Isolated Shunt Current Measurem...
1289|3
 楼主| dirtwillfly 发表于 2017-2-12 21:27 | 显示全部楼层 |阅读模式
描述
The TIDA-01094 reference design implements a class 0.5 three-phase  transformerless energy measurement system with isolated shunt sensors by using isolated delta-sigma modulators. The delta sigma modulators have their output circuitry capacitively isolated from input circuitry, thereby providing transformerless data isolation. The high-side of each modulator is powered by a cap-drop supply that is also transformerless. Since a transformer is not used in this design, this design is inherently magnetically immune. In addition, the high-side cap-drop power supply reduces the entire system cost, has inherent low conducted and radiated emissions, and  reduces the current consumption drawn from the low-side power supply since the high-side is separately powered from Mains instead of being derived from the low-side power supply.
特性
  • Class 0.5% three-phase metrology with galvanically isolated shunt current sensors
  • Cap-drop power supplies for high side of modulators
  • Isolation performance of up to 1-kV AC (working voltage) and a voltage of 7 kV (peak)
  • Supports both AMC1304M05 and AMC1305M04+TLV70450 configurations
  • TI energy library firmware calculates all energy measurement parameters including active and reactive power and energy, root mean square (RMS) current and voltage, power factor, and line frequency
  • Isolated RS-232 With 3-kV[size=0.7em]RMS operating isolation boundary for communication to PC graphical user interface (GUI)
 楼主| dirtwillfly 发表于 2017-2-12 21:29 | 显示全部楼层
 楼主| dirtwillfly 发表于 2017-2-12 21:34 | 显示全部楼层
个人签名:欢迎进入TI MCU论坛      21ic TI技术交流1群:61549143(已满),  21ic TI技术交流2群:311421422 我的博客:http://blog.timcu.com/
1203
