请高人帮帮分析这段小程序
2620|4
lovedfrien|  楼主 | 2010-4-23 21:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity Decoder is
  port (
        Coder_In:in std_logic_vector(4 downto 0);
     Code_out:out std_logic_vector(31 downto 0)
end;
architecture behavioral of Decoder is
begin
process (Coder_In)
begin
     case Coder_In is
     WHEN "00000" =>Code_out<="11111111111111111111111111111110";
  WHEN "00001" =>Code_out<="11111111111111111111111111111101";
  WHEN "00010" =>Code_out<="11111111111111111111111111111011";
  WHEN "00011" =>Code_out<="11111111111111111111111111110111";
  WHEN "00100" =>Code_out<="11111111111111111111111111101111";
  WHEN "00101" =>Code_out<="11111111111111111111111111011111";
  WHEN "00110" =>Code_out<="11111111111111111111111110111111";
  WHEN "00111" =>Code_out<="11111111111111111111111101111111";
  WHEN "01000" =>Code_out<="11111111111111111111111011111111";
  WHEN "01001" =>Code_out<="11111111111111111111110111111111";
  WHEN "01010" =>Code_out<="11111111111111111111101111111111";
  WHEN "01011" =>Code_out<="11111111111111111111011111111111";
  WHEN "01100" =>Code_out<="11111111111111111110111111111111";
  WHEN "01101" =>Code_out<="11111111111111111101111111111111";
  WHEN "01110" =>Code_out<="11111111111111111011111111111111";
  WHEN "01111" =>Code_out<="11111111111111110111111111111111";
  WHEN "10000" =>Code_out<="11111111111111101111111111111111";
  WHEN "10001" =>Code_out<="11111111111111011111111111111111";
  WHEN "10010" =>Code_out<="11111111111110111111111111111111";
  WHEN "10011" =>Code_out<="11111111111101111111111111111111";
  WHEN "10100" =>Code_out<="11111111111011111111111111111111";
  WHEN "10101" =>Code_out<="11111111110111111111111111111111";
  WHEN "10110" =>Code_out<="11111111101111111111111111111111";
  WHEN "10111" =>Code_out<="11111111011111111111111111111111";
  WHEN "11000" =>Code_out<="11111110111111111111111111111111";
  WHEN "11001" =>Code_out<="11111101111111111111111111111111";
  WHEN "11010" =>Code_out<="11111011111111111111111111111111";
  WHEN "11011" =>Code_out<="11110111111111111111111111111111";
  WHEN "11100" =>Code_out<="11101111111111111111111111111111";
  WHEN "11101" =>Code_out<="11011111111111111111111111111111";
  WHEN "11110" =>Code_out<="10111111111111111111111111111111";
  WHEN "11111" =>Code_out<="01111111111111111111111111111111";
     WHEN others  =>Code_out<="11111111111111111111111111111111";
end case;
end process;
end;
编译后结果是
所有输出端口 stuck at GND ,如
Warning: Pin "Rev_Sel_22" stuck at GND
输入无效,如:
Warning: No output dependent on input pin "Send_Grp_Dr[4]"
其中Rev_Sel_22和Send_Grp_Dr都是接在模块上的输出输入端口,咋回事啊,百思不得其解
ZHOUNACHU| | 2010-4-24 12:20 | 只看该作者
我帮你编译了一下,没有错误了:
library ieee;
entity Decoder is
        port(        Coder_In:in  std_logic_vector(4 downto 0);
end;
begin
        process (Coder_In)
        begin
                case Coder_In is
                end case;
        end process;
end;
ZHOUNACHU| | 2010-4-24 12:22 | 只看该作者
但是要把QQ表情那里修改一下,他遮住了几个字母,完整的是:
ZHOUNACHU| | 2010-4-24 12:24 | 只看该作者
:L怎么这个QQ表情老是在那个位置啊,,
sinetech| | 2010-4-24 22:49 | 只看该作者
二楼的代码风格很好:) 值得提倡
