[资料分享] TI新产品介绍-INA303
475|0
 楼主| xyz549040622 发表于 2017-3-29 20:41 | 显示全部楼层 |阅读模式
INA, TI, AN, COM, se
描述
The INA302 and INA303 devices feature a high common-mode, bidirectional, current-sensing        amplifier and two high-speed comparators to detect out-of-range current conditions. The INA302        comparators are configured to detect and respond to overcurrent conditions. The INA303 comparators        are configured to respond to both over- and undercurrent conditions in a windowed configuration.        The device features an adjustable limit threshold range for each comparator set using an external        limit-setting resistor. These current-shunt monitors can measure differential voltage signals on        common-mode voltages that can vary from –0.1 V up to 36 V, independent of the supply.
The open-drain alert outputs can be configured to operate in either a transparent mode        (output status follows the input state) or in a latched mode (alert output is cleared when the        latch is reset). The alert response time for comparator 1 is under 1 µs and the alert response for        comparator 2 is set through an external capacitor ranging from 2 µs to 10 s.
This device operates from a single 2.7-V to 5.5-V supply, drawing a maximum supply        current of 950 µA. The device is specified over the extended operating temperature range (–40°C to        +125°C), and is available in a 14-pin TSSOP package.
特性
  • Wide Common-Mode Input Range: –0.1 V to 36 V
  • Dual Comparator Outputs:
    • INA302: Two Independent Overlimit Alerts
    • INA303: Window Comparator
    • Threshold Levels Set Individually
    • Comparator 1 Alert Response: 1 µs
    • Comparator 2 Adjustable Delay: 2 µs to 10 s
    • Open-Drain Outputs With Independent Latch Control Modes
  • High Accuracy Amplifier:
    • Offset Voltage: 30 µV (Max, A3 Version)
    • Offset Voltage Drift: 0.5 µV/°C (Max)
    • Gain Error: 0.15% (Max, A3 Version)
    • Gain Error Drift: 10 ppm/°C
  • Available Amplifier Gains:
    • INA302A1, INA303A1: 20 V/V
    • INA302A2, INA303A2: 50 V/V
    • INA302A3, INA303A3: 100 V/V
个人签名:qq群: 嵌入式系统arm初学者 224636155←← +→→点击-->小 i 精品课全集,21ic公开课~~←←→→点击-->小 i 精品课全集,给你全方位的技能策划~~←←
2841
