关于GAL16V8的烧写工作
3176|1
 楼主| fenglingchen 发表于 2010-5-18 13:48 | 显示全部楼层 |阅读模式
* Inputs:  define inputs to build simple gates from
Pin 3 =  a;
Pin 2 =  b;
* Outputs:  define outputs as active HI levels
Pin 12 = inva;
Pin 13 = invb;
Pin 14 = and;
Pin 15 = nand;
Pin 16 = or;
Pin 17 = nor;
Pin 18 = xor;
Pin 19 = xnor;
* Logic:  examples of simple gates expressed in CUPL
inva = !a;              /* inverters */
invb = !b;
and  = a & b;           /* and gate */
nand = !(a & b);        /* nand gate */
or   = a # b;           /* or gate */
nor  = !(a # b);        /* nor gate */
xor  = a $ b;           /* exclusive or gate */
xnor = !(a $ b);        /* exclusive nor gate */
以上是ATMEL WINCUPL软件自带的一款程序,编译和软件仿真都正常,用WELLON的烧写器烧到GAL16V8后却工作不正常,如PIN2,PIN3都接低电平时,12pin,13pin也输出低电平,哪位对此比较了解,请给予指导,万分感谢。(本人由项目所迫,刚搞GAL器件)
 楼主| fenglingchen 发表于 2010-5-19 11:32 | 显示全部楼层
有知道的没有啊?
还有啊,*.JED文件中,0代表熔断,1代表不动,对不对啊?
