实现让8个二极管依次以200ms的间隔连续闪烁5次
2120|22
 楼主| langgq 发表于 2017-6-30 19:09 | 显示全部楼层 |阅读模式
但是实际运行时发现有问题
#include"reg51.h"
#define uchar unsigned char
#define uint unsigned int
sbit led1=P1^0;
sbit led2=P1^1;
sbit led3=P1^2;
sbit led4=P1^3;
sbit led5=P1^4;
sbit led6=P1^5;
sbit led7=P1^6;
sbit led8=P1^7;
uchar num1;
void main()
        TMOD=0x01;
        TH0=(65536-45872)/256;
        TL0=(65536-45872)%256;
        EA=1;
        ET0=1;
        TR0=1;
        led1=1;
        led2=1;
        led3=1;
        led4=1;
        led5=1;
        led6=1;
        led7=1;
        led8=1;
        while(1)
                if((num1==4)||(num1==8)||(num1==12)||(num1==16)||(num1==20))
                        led1=~led1;
                if((num1==24)||(num1==28)||(num1==32)||(num1==36)||(num1==40))
                {        led1=1;
                        led2=~led2;
                if((num1==44)||(num1==48)||(num1==52)||(num1==56)||(num1==60))
                {        led2=1;
                        led3=~led3;
                if((num1==64)||(num1==68)||(num1==72)||(num1==76)||(num1==80))
                {        led3=1;
                        led4=~led4;
                if((num1==84)||(num1==88)||(num1==92)||(num1==96)||(num1==100))
                {        led4=1;
                        led5=~led5;
                if((num1==104)||(num1==108)||(num1==112)||(num1==116)||(num1==120))
                {        led5=1;
                        led6=~led6;
                if((num1==124)||(num1==128)||(num1==132)||(num1==136)||(num1==140))
                {        led6=1;
                        led7=~led7;
                if((num1==144)||(num1==148)||(num1==152)||(num1==156))
                {        led7=1;
                        led8=~led8;
                if(num1==160)
                        led8=~led8;
                        led8=1;
                        num1=0;
void T0_time()interrupt 1
                num1++;
wangzsa 发表于 2017-6-30 19:10 | 显示全部楼层
有什么问题?
wangzsa 发表于 2017-6-30 19:14 | 显示全部楼层
你这个错误关键在num1的处理上,这个变量在不停的被中断累加,在主循环的一次循环处理中可能值会发生变化,导致错误
zhuww 发表于 2017-6-30 19:15 | 显示全部楼层
你这个程序还有明显不合理的地方,加个else合理些,会大大提高效率
 楼主| langgq 发表于 2017-6-30 19:17 | 显示全部楼层
哦,哪儿
zhanglli 发表于 2017-6-30 19:21 | 显示全部楼层
     led1=~led1;
}else
但仍然会有问题
typedef unsigned char U8;
#define BIT0        (1<<0)
#define BIT1        (1<<1)
#define LED0_7        P1
sbit LED0 = P1^0;
bit flag_200ms;
#define ms        /50
void main(void)
        U8 stage = 0;
        init()
        while(1)
                if(flag_200ms){
                        flag_200ms = 0;
                        stage++;
                        if(stage >= 8){
                                stage = 0;
                        switch(stage){
                        default:
                        case 0:
                                LED0 = (LED0_7 & BIT0) ^ BIT0;
                                break;
                        case 1:
                                LED1 = (LED0_7 & BIT1) ^ BIT1;
                                break;
                        case 2:
                        case 3:
                        case 4:
                        case 5:
                        case 6:
                        case 7:
                                break
        num1++;
                static U8 c = 0;
                if(++c >= 200ms){
                        c = 0;
                        flag_200ms = 1;
 楼主| langgq 发表于 2017-6-30 19:23 | 显示全部楼层
所有的灯都会闪
虽然现在我还没有发现问题出在什么地方,但是我认为应该不是出在num1上,下面我这程序也是用的num++,运行就很正确
#include"reg51.h"
sbit led1=P1^0;
sbit led2=P1^1;
sbit led3=P1^2;
sbit led4=P1^3;
sbit led5=P1^4;
sbit led6=P1^5;
sbit led7=P1^6;
sbit led8=P1^7;
uchar num1,num2;
void main()
        TMOD=0x01;
        EA=1;
        ET0=1;
        TR0=1;
        while(1)
        switch(num1)
                case 0:
                while(num1<=20)
                        if(num2==4)
                                num2=0;
                                led1=~led1;
                case 20:
                        while(num1<=40)
                        if(num2==4)
                        {        led1=1;
                                num2=0;
                                led2=~led2;
                case 40:
                        while(num1<=60)
                        if(num2==4)
                        {        led2=1;
                                num2=0;
                                led3=~led3;
                case 60:
                        while(num1<=80)
                        if(num2==4)
                        {        led3=1;
                                num2=0;
                                led4=~led4;
                case 80:
                        while(num1<=100)
                        if(num2==4)
                        {        led4=1;
                                num2=0;
                                led5=~led5;
                case 100:
                        while(num1<=120)
                        if(num2==4)
                        {        led5=1;
                                num2=0;
                                led6=~led6;
                case 120:
                        while(num1<=140)
                        if(num2==4)
                        {        led6=1;
                                num2=0;
                                led7=~led7;
                case 160:
                        while(num1<=180)
                        if(num2==4)
                        {        led7=1;
                                num2=0;
                                led8=~led8;
                }led8=1;num1=0;break;
                num1++;
                num2++;
lium 发表于 2017-6-30 19:29 | 显示全部楼层
既然这么认为,我也就不说什么了,
此没有问题只能说明这个没有问题,也只能说明没有看到问题。。。
 楼主| langgq 发表于 2017-6-30 19:31 | 显示全部楼层
恩,我是不会放弃治疗的
guoyt 发表于 2017-6-30 19:32 | 显示全部楼层
if(num2==4)
    num2=0;
    led1=~led1;
  delay(50ms); // 加延时函数就能看出问题
yufe 发表于 2017-6-30 19:33 | 显示全部楼层
简单的修改最先的代码
        while(1)
                        uchar t;
                        t = num1;
                        while(t == num1);
                        led1=~led1;
yufe 发表于 2017-6-30 19:39 | 显示全部楼层
定时200ms准不准?
还是先把程序简化。
                        led1=~led1;
先试第一个灯,看对不对。对了,再加第二个灯。。。
llia 发表于 2017-6-30 19:41 | 显示全部楼层
~是字节按位取反.  准确的应该是: led1=!led1;
zhanglli 发表于 2017-6-30 19:42 | 显示全部楼层
有些编译器不会出问题.  但不能保证所有的编译都正确
wangpe 发表于 2017-6-30 19:44 | 显示全部楼层
本逻辑有问题
我前面的说法有些不正确的
本应每中断一次才进行一次主循环处理,这样就逻辑合理了,但LZ的程序是在不停的处理,而CPU相对很快,所以不停的符合条件,不停的闪烁
LZ对num1这个变量的访问还是有些问题,这个变量类似计数器的飞读概念,
建议先赋值给局部变量,再使用局部变量进行判断,这样要可靠多了
wangzsa 发表于 2017-6-30 19:45 | 显示全部楼层
楼上说到本质了。 应该在中断里再加一个标志,主程序每处理一次中断溢出、就将改标志清掉。
zhuww 发表于 2017-6-30 19:47 | 显示全部楼层
嗯,另外,应该在主程序中加一个变量,移位控制。主循环没理由那么大、那么繁琐。
zhanglli 发表于 2017-6-30 19:50 | 显示全部楼层
问题在于num1 == 4 之类的条件成立可持续50ms,而主程序循环跑得很快,在50ms里灯的状态会不停的快速变换
uchar  last_num;
if(last_num == num1)
    continue;
else
    last_num = num1;
后面的处理怎么方便怎么做就好了
zhuww 发表于 2017-6-30 19:52 | 显示全部楼层
void  T0_timer()   interrupt 1
       num1++;
       if  (num1==4)
                num1=0;
                Bflash=1;
uchar  sta=0x01, counter=0;
while(1)
          if  (Bflash)
                 Bflash=0;
                 sta=~sta;
                 counter++;
                  if (counter==6)
                          counter=0;
                          sta=sta<<1;         if (!sta)   sta=0x01;
                  P1=sta;
