 参照3.0库写的例程为何只能进入TIM_IT_Update而不能进入TIM_IT_CC1
 右边对应3.0库代码:
 void Tim2_Init(void)
 TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
 TIM_OCInitTypeDef  TIM_OCInitStructure;
 TIM_TimeBaseStructure.TIM_Period = 5000;// 1us * 50 000 = 50ms;TIM_TimeBaseStructure.TIM_Period = 65535;
 TIM_TimeBaseStructure.TIM_Prescaler = 35;// 36mhz /36 = 1mhz, =1us  TIM_TimeBaseStructure.TIM_Prescaler = 0;
 TIM_TimeBaseStructure.TIM_ClockDivision = 0;//  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
 TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;//  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
 TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);//  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
 /* Prescaler configuration */
 TIM_PrescalerConfig(TIM2, 256, TIM_PSCReloadMode_Immediate);//  TIM_PrescalerConfig(TIM2, 4, TIM_PSCReloadMode_Immediate);
 /* Output Compare Timing Mode configuration: Channel1 */
 TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Timing;
 TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
 TIM_OCInitStructure.TIM_Pulse = 500;//  TIM_OCInitStructure.TIM_Pulse = CCR1_Val;  __IO uint16_t CCR1_Val = 49152;
 TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
 TIM_OC1Init(TIM2, &TIM_OCInitStructure);
 TIM_OC1PreloadConfig(TIM2, TIM_OCPreload_Disable);
 /* TIM IT enable */
 TIM_ITConfig(TIM2, TIM_IT_CC1 | TIM_IT_Update, ENABLE);//  TIM_ITConfig(TIM2, TIM_IT_CC1 | TIM_IT_CC2 | TIM_IT_CC3 | TIM_IT_CC4, ENABLE);我没有使用cc2,cc3,cc4
 /* TIM2 enable counter */
 TIM_Cmd(TIM2, ENABLE);
 中断处理
 void TIM2_IRQHandler(void)
 uint8_t b;
 b=10;
 b=b+1;
 #ifdef _DEBUG_
 printf("TIM2_IRQHnadler Success!\n");
 #endif
 if (TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET)
 #ifdef _DEBUG_
 printf("TIM2_IRQHnadler_Update Success!\n");
 #endif
 TIM_ClearITPendingBit(TIM2, TIM_IT_Update);
 if (TIM_GetITStatus(TIM2, TIM_IT_CC1) != RESET)
 #ifdef _DEBUG_
 printf("TIM2_IRQHnadler_CC1 Success!\n");
 #endif
 TIM_ClearITPendingBit(TIM2, TIM_IT_CC1);
 TIM_Cmd(TIM2, DISABLE);
 keil4.12 调试结果
