[matlab] 范例:opencore组织RISCMCU IP Core全套最新代码 _timer
2298|0
 楼主| wangjun88 发表于 2010-8-27 10:02 | 显示全部楼层 |阅读模式
---- WISHBONE RISCMCU IP Core       ----
---- This file is part of the RISCMCU project     ----
---- http://www.opencores.org/projects/riscmcu/    ----
---- Description        ----
---- Implementation of a RISC Microcontroller based on Atmel AVR ----
---- AT90S1200 instruction set and features with Altera Flex10k20 FPGA. ----
---- Author(s):        ----
----  - Yap Zi He, yapzihe@hotmail.com     ----
---- Copyright (C) 2001 Authors and OPENCORES.ORG    ----
---- This source file may be used and distributed without   ----
---- restriction provided that this copyright statement is not   ----
---- removed from the file and that any derivative work contains  ----
---- the original copyright notice and the associated disclaimer.  ----
---- This source file is free software; you can redistribute it  ----
---- and/or modify it under the terms of the GNU Lesser General  ----
---- Public License as published by the Free Software Foundation;  ----
---- either version 2.1 of the License, or (at your option) any  ----
---- later version.        ----
---- This source is distributed in the hope that it will be   ----
---- useful, but WITHOUT ANY WARRANTY; without even the implied  ----
---- warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR   ----
---- PURPOSE. See the GNU Lesser General Public License for more  ----
---- details.         ----
---- You should have received a copy of the GNU Lesser General   ----
---- Public License along with this source; if not, download it  ----
---- from http://www.opencores.org/lgpl.shtml     ----
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity v_timer is
port( extpin, clr_tov0 : in std_logic;
  rd_timsk, wr_timsk, rd_tifr, wr_tifr : in std_logic;
  rd_tccr0, wr_tccr0, rd_tcnt0, wr_tcnt0 : in std_logic;
  clk, clrn : in std_logic;
  c : inout std_logic_vector(7 downto 0);
  timerirq : out std_logic
end v_timer;
architecture timer of v_timer is
signal toie0, tov0 : std_logic;
signal cs : integer range 0 to 7;
signal tcnt0 : std_logic_vector(7 downto 0);
signal div1, div2, div4, div8, div16, div32, div64, div128, div256, div512, div1024 : std_logic;
signal timerclk, inc_tcnt0, currentstate, laststate : std_logic;
begin
-- Timer Interrupt Request
timerirq <= toie0 and tov0;
-- Read 4 Registers
c <=  "000000" & toie0 & "0"   when rd_timsk = '1' else
    "000000" & tov0 & "0"   when rd_tifr  = '1' else
  conv_std_logic_vector(cs,8) when rd_tccr0 = '1' else
  tcnt0       when rd_tcnt0 = '1' else
  "ZZZZZZZZ";
-- Select Clock Source
with cs select
timerclk <= '0'   when 0,
     clk   when 1,
    div8   when 2,
    div64  when 3,
    div256   when 4,
    div1024  when 5,
    not extpin  when 6,
    extpin   when 7;
-- Timer : clear/write 4 registers, increment timer, set overflow flag, sample clock source
process(clrn, clr_tov0, wr_tifr, c, clk)
begin
if clrn = '0' then
  toie0 <= '0';
  cs <= 0;
  tcnt0 <= "00000000";
  tov0 <= '0';
  currentstate <= '0';
  laststate <= '0';
elsif clr_tov0 = '1' or (wr_tifr = '1' and c(1) = '1') then
  tov0 <= '0';
elsif clk'event and clk = '1' then
  if wr_tcnt0 = '1' then
   tcnt0 <= c;
  elsif inc_tcnt0 = '1' then
   tcnt0 <= tcnt0 + 1;
   if tcnt0 = "11111111" then
    tov0 <= '1';
   end if;
  end if;
  if wr_timsk = '1' then
   toie0 <= c(1);
  end if;
  if wr_tccr0 = '1' then
   cs <= conv_integer(c(2 downto 0));
  end if;
  currentstate <= timerclk;
  laststate <= currentstate;
end if;
end process;
-- Detect rising edge
inc_tcnt0 <= '1' when (laststate ='0' and currentstate = '1') or cs = 1 else
    '0';
-- 10 bit prescaler
process(clk, clrn)
begin
if clrn = '0' then
  div2 <= '0';
  div4 <= '0';
  div8 <= '0';
  div16 <= '0';
  div32 <= '0';
  div64 <= '0';
  div128 <= '0';
  div256 <= '0';
  div512 <= '0';
  div1024 <= '0';
  div2 <= not div2;
  if div2 = '1' then
    div4 <= not div4;
    if div4 = '1' then
      div8 <= not div8;
    if div8 = '1' then
     div16 <= not div16;
     if div16 = '1' then
      div32 <= not div32;
      if div32 = '1' then
       div64 <= not div64;
       if div64 = '1' then
        div128 <= not div128;
        if div128 = '1' then
         div256 <= not div256;
         if div256 = '1' then
          div512 <= not div512;
          if div512 = '1' then
           div1024 <= not div1024;
          end if;
         end if;
         end if;
       end if;
      end if;
     end if;
    end if;
   end if;
  end if;
end if;
end process;
end timer;
