[matlab] 范例:opencore组织RISCMCU IP Core全套最新代码 _gpr
2154|0
 楼主| yun888 发表于 2010-8-30 11:09 | 显示全部楼层 |阅读模式
---- WISHBONE RISCMCU IP Core ----
---- This file is part of the RISCMCU project ----
---- http://www.opencores.org/projects/riscmcu/ ----
---- Description ----
---- Implementation of a RISC Microcontroller based on Atmel AVR ----
---- AT90S1200 instruction set and features with Altera Flex10k20 FPGA. ----
---- Author(s): ----
---- - Yap Zi He, yapzihe@hotmail.com ----
---- Copyright (C) 2001 Authors and OPENCORES.ORG ----
---- This source file may be used and distributed without ----
---- restriction provided that this copyright statement is not ----
---- removed from the file and that any derivative work contains ----
---- the original copyright notice and the associated disclaimer. ----
---- This source file is free software; you can redistribute it ----
---- and/or modify it under the terms of the GNU Lesser General ----
---- Public License as published by the Free Software Foundation; ----
---- either version 2.1 of the License, or (at your option) any ----
---- later version. ----
---- This source is distributed in the hope that it will be ----
---- useful, but WITHOUT ANY WARRANTY; without even the implied ----
---- warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR ----
---- PURPOSE. See the GNU Lesser General Public License for more ----
---- details. ----
---- You should have received a copy of the GNU Lesser General ----
---- Public License along with this source; if not, download it ----
---- from http://www.opencores.org/lgpl.shtml ----
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity v_gpr is
port( c : in std_logic_vector(7 downto 0);
wr_reg, inc_zp, dec_zp : in std_logic;
rd, rr, dest : in integer range 0 to 15;
clk, clrn : in std_logic;
reg_rd, reg_rr, addrbus : out std_logic_vector(7 downto 0)
end v_gpr;
architecture gpr of v_gpr is
type regfiletype is array (0 to 15) of std_logic_vector(7 downto 0);
signal reg : regfiletype;
begin
addrbus <= reg(14) - 16#61# when dec_zp = '1' else
reg(14) - 16#60#;
reg_rd <= reg(rd);
reg_rr <= reg(rr);
process(clk, clrn)
begin
if clrn = '0' then
for i in 0 to 15 loop
reg(i) <= "00000000";
end loop;
elsif clk'event and clk = '1' then
if wr_reg = '1' then
reg(dest) <= c;
end if;
if inc_zp = '1' then
reg(14) <= reg(14) + 1;
elsif dec_zp = '1' then
reg(14) <= reg(14) - 1;
end if;
end if;
end process;
end gpr;
