帮忙看看这个红外线接收程序有什么问题
2012|0
 楼主| 独来独往32 发表于 2010-9-10 10:30 | 显示全部楼层 |阅读模式
#include <reg52.h>
#define uchar unsigned char
#define uint unsigned int
sbit IR=P3^2;
uchar disp[4];
void chushi();
void display();
void extr0();
bit right();
void main()
{uint n;
chushi();
P1=0xff;
while(1)
  {display();
void chushi()
{TMOD=0X01;
IE=0X81;
IT0=1;
void display()
{uchar code shuma[17]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71};
uchar code *sm=shuma;
uchar i,n;
P2=0x03;
for(i=0;i<4;i++)
  {P0=*(sm+disp[i]);
  P2=(++P2)&0x03;
  n=200;
  while(--n);
void extr0() interrupt 0 using 1
{uint n;
uint lowt,higt;
EA=0;
TH0=0;
TL0=0;
TR0=1;
while(IR==0);
TR0=0;
lowt=TH0*256+TL0;
TH0=0;
TL0=0;
TR0=1;
while(IR==1);
TR0=0;
higt=TH0*256+TL0;
if((lowt<8800)&&(lowt>7800)&&(higt<4700)&&(higt>3600))
if(right())
   {            P1=0x00;
           n=20000;
           while(--n);
   EA=1;
bit right()
{uchar i,j;
uchar tem[4];
uint lowt,higt;
  for(i=0;i<4;i++)
    {for(j=0;j<8;j++)
        {tem[i]>>=1;
         TH0=0;
     TL0=0;
     TR0=1;
         while(IR==0);
     TR0=0;
     lowt=TH0*256+TL0;
     TH0=0;
     TL0=0;
     TR0=1;
     while(IR==1);
     TR0=0;
     higt=TH0*256+TL0;
         if((lowt>370)&&(lowt<640))
           {if((higt<620)&&(higt>420))
           tem[i]=tem[i]&0x7f;
           else
           if((higt>1300)&&(higt<1800))
            tem[i]|=0x80;
           else return (0);
           else return (0);
               disp[0]=tem[2]/100; //数码管显示数据的百位 十位 和个位
               disp[1]=(tem[2]%100)/10;
                disp[2]=tem[2]%10;
           return (1);
