[技术问答] stm32 spi 的demo 我要用NUC123实现 要怎么配啊, 弄了好多次.....
1252|8
 楼主| 王春炜 发表于 2017-8-28 15:31 | 显示全部楼层 |阅读模式
void SPI_Configuration(void)
        GPIO_InitTypeDef         GPIO_InitStructure;
        SPI_InitTypeDef           SPI_InitStructure;
          RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_SPI1 | RCC_APB2Periph_AFIO, ENABLE);
        /* 初始化SCK、MISO、MOSI引脚 */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        GPIO_SetBits(GPIOA,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
        /* 初始化CS引脚 */
        GPIO_InitStructure.GPIO_Pin = W5500_SCS;
        GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
        GPIO_Init(W5500_SCS_PORT, &GPIO_InitStructure);
        GPIO_SetBits(W5500_SCS_PORT, W5500_SCS);
        /* 初始化配置STM32 SPI1 */
        SPI_InitStructure.SPI_Direction=SPI_Direction_2Lines_FullDuplex;        //SPI设置为双线双向全双工
        SPI_InitStructure.SPI_Mode=SPI_Mode_Master;                                                        //设置为主SPI
        SPI_InitStructure.SPI_DataSize=SPI_DataSize_8b;                                                //SPI发送接收8位帧结构
        SPI_InitStructure.SPI_CPOL=SPI_CPOL_Low;                                                        //时钟悬空低
        SPI_InitStructure.SPI_CPHA=SPI_CPHA_1Edge;                                                        //数据捕获于第1个时钟沿
        SPI_InitStructure.SPI_NSS=SPI_NSS_Soft;        //NSS由外部管脚管理
        SPI_InitStructure.SPI_BaudRatePrescaler=SPI_BaudRatePrescaler_2;        //波特率预分频值为2
        SPI_InitStructure.SPI_FirstBit=SPI_FirstBit_MSB;                                        //数据传输从MSB位开始
        SPI_InitStructure.SPI_CRCPolynomial=7;        //CRC多项式为7
        SPI_Init(SPI1,&SPI_InitStructure);        //根据SPI_InitStruct中指定的参数初始化外设SPI1寄存器
        SPI_Cmd(SPI1,ENABLE);        //STM32使能SPI1
############NUC123#################
CLK_SetModuleClock(SPI0_MODULE, CLK_CLKSEL1_SPI0_S_HCLK, MODULE_NoMsk);
CLK_EnableModuleClock(SPI0_MODULE);
SPI_Open(SPI0, SPI_MASTER, SPI_MODE_3, 8, NULL);
SPI_SET_SS0_LOW(SPI0);
SPI_SET_MSB_FIRST(SPI0);
SYS->GPC_MFP = SYS_GPC_MFP_PC0_SPI0_SS0 | SYS_GPC_MFP_PC1_SPI0_CLK | SYS_GPC_MFP_PC2_SPI0_MISO0 | SYS_GPC_MFP_PC3_SPI0_MOSI0;
SYS->ALT_MFP = SYS_ALT_MFP_PC0_SPI0_SS0 | SYS_ALT_MFP_PC1_SPI0_CLK | SYS_ALT_MFP_PC2_SPI0_MISO0 | SYS_ALT_MFP_PC3_SPI0_MOSI0;
稳稳の幸福 发表于 2017-8-28 15:46 | 显示全部楼层
那你去找123的demo啊。
稳稳の幸福 发表于 2017-8-28 15:47 | 显示全部楼层
去新唐下载相关的BSP,里面有的。
xinpian101 发表于 2017-8-28 16:28 | 显示全部楼层
你用STM32的改肯定不行了,他们做的不一样, 你去找新唐的改。
a_ziliu 发表于 2017-8-29 11:06 | 显示全部楼层
這貼子有SPI FLASH操作的例子
QQ1099811789 发表于 2019-6-14 14:22 | 显示全部楼层
dongnanxibei 发表于 2019-6-15 16:27 | 显示全部楼层
123有自己的DEMO
直接下载BSP就行了。
huangcunxiake 发表于 2019-6-17 09:24 | 显示全部楼层
发错地方了。
