STM32F103 ADC+DMA和UART2中断冲突问题求助
6894|3
 楼主| zddpy 发表于 2010-12-3 20:46 | 显示全部楼层 |阅读模式
程序中使用了TIM2,UART1,UART2和ADC+DMA1中断,不加上UART2时都正常,加上UART2中断后,运行几分钟后ADC+DMA1的中断就不能进去了,更改了几种中断优先级方式后都没有解决。请大家看看是什么原因?
void NVIC_Configuration(void)
   NVIC_InitTypeDef NVIC_InitStructure;
#ifdef  VECT_TAB_RAM
  /* Set the Vector Table base location at 0x20000000 */
   NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else  /* VECT_TAB_FLASH  */
  /* Set the Vector Table base location at 0x08000000 */
   NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
/* Configure one bit for preemption priority */
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
  /* Enable the TIM2 gloabal Interrupt */
   NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQChannel;
   NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
   NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
   NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
   NVIC_Init(&NVIC_InitStructure);
  /* Enable the DMA channel1 gloabal Interrupt */
   NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel1_IRQChannel;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  /* Enable Interrupt */
   NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQChannel;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
   NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQChannel;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 5;
//   NVIC_Init(&NVIC_InitStructure);
 楼主| zddpy 发表于 2010-12-4 08:01 | 显示全部楼层
但定时中断一直能正常运行,启动ADC,
void TIM2_IRQHandler(void)
static INT16U count = 0;
  if (TIM_GetITStatus(TIM2, TIM_IT_CC1) != RESET)
    TIM_ClearITPendingBit(TIM2, TIM_IT_CC1);
    ADC_SoftwareStartConvCmd(ADC1,ENABLE);
    // Start ADC1 Software Conversion
    capture = TIM_GetCapture1(TIM2);
    TIM_SetCompare1(TIM2, capture + TimerCount_500);
  else if (TIM_GetITStatus(TIM2, TIM_IT_CC2) != RESET)
    TIM_ClearITPendingBit(TIM2, TIM_IT_CC2);
    capture = TIM_GetCapture2(TIM2);
    TIM_SetCompare2(TIM2, capture + CCR2_Val);
  else if (TIM_GetITStatus(TIM2, TIM_IT_CC3) != RESET)
    TIM_ClearITPendingBit(TIM2, TIM_IT_CC3);
    capture = TIM_GetCapture3(TIM2);
    TIM_SetCompare3(TIM2, capture + CCR3_Val);
  else
    TIM_ClearITPendingBit(TIM2, TIM_IT_CC4);
    capture = TIM_GetCapture4(TIM2);
    TIM_SetCompare4(TIM2, capture + CCR4_Val);
 楼主| zddpy 发表于 2010-12-4 08:06 | 显示全部楼层
void DMA1_Channel1_IRQHandler(void)
        static INT8U        channel = 0;
        static INT8U        vchannel = 0;
        if(DMA_GetITStatus(DMA1_IT_TC1)==SET)
        gAllSampleData[channel]= ADC_ConvertedValue[0]&0x0fff;                 //ADC_IN0
        gVSampleData[vchannel] = ADC_ConvertedValue[1]&0x0fff;                 //ADC_IN1
        gDCSampleData[channel] = ADC_ConvertedValue[2]&0x0fff;                 //ADC_IN8
        if(++channel ==4){
              //一次的采样完成,设置数据处理标志位
            channel = 0;
              ADFinished = TRUE;
          else {
              ADC_SoftwareStartConvCmd(ADC1,ENABLE);                                      /* Start ADC1 Software Conversion     */
           DMA_ClearITPendingBit(DMA1_IT_TC1);
        else if(DMA_GetITStatus(DMA1_IT_HT1)==SET)
           DMA_ClearITPendingBit(DMA1_IT_HT1);
void USART1_IRQHandler(void)
        if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
                UART1_Rec_Isr();
                /* Clear the USART1 Receive interrupt */
                USART_ClearITPendingBit(USART1, USART_IT_RXNE);
        else if(USART_GetITStatus(USART1, USART_IT_TXE) != RESET)
                UART1_Send_Isr();
                USART_ClearITPendingBit(USART1, USART_IT_TXE);
* Function Name  : USART2_IRQHandler
* Description    : This function handles USART2 global interrupt request.
* Input          : None
* Output         : None
* Return         : None
void USART2_IRQHandler(void)
        if(USART_GetITStatus(USART2, USART_IT_RXNE) != RESET)
                UART2_Rec_Isr();
                USART_ClearITPendingBit(USART2, USART_IT_RXNE);
        else if(USART_GetITStatus(USART2, USART_IT_TXE) != RESET)
                UART2_Send_Isr();
                USART_ClearITPendingBit(USART2, USART_IT_TXE);
wubing1211 发表于 2010-12-4 12:33 | 显示全部楼层
