AD7799坏了??使用注意!
4673|2
jianghuang|  楼主 | 2007-4-7 15:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我用的是AD7799BRUZ芯片,打算应用于称重。
电路连接参照数据手册(Rev.0) 27页的那个电路,
我只用了AIN1一个通道,其余未用。
出现的问题是:采不出数据。
进行满量程校准后读出的数据全为FF,读状态寄存器有错误标志。把REF_DEC置位后有NOREF错误标志,可是我的参考电压接是是正5V啊,是不是AD7799内部的参考电压电路部分损坏了啊!!
#include <intrins.h>        /* use _nop_() function */
AD7799写寄存器函数
WriteData:要写的数据
void WriteByteToAd7799(unsigned char WriteData)
   unsigned char i;
   //AD7799_CS=0;
   for(i=0;i<8;i++)
      AD7799_SCLK=0;
      if(WriteData&0x80)AD7799_DIN=1;
      else AD7799_DIN=0;
      WriteData=WriteData<<1;
      AD7799_SCLK=1;
    //AD7799_CS=1;
AD7799读寄存器函数
unsigned char ReadByteFromAd7799(void)
   unsigned char i;
   unsigned char ReadData;
   //AD7799_CS=0;
   ReadData=0;
   for(i=0;i<8;i++)
      AD7799_SCLK=0;
      ReadData=ReadData<<1;
      if(AD7799_DOUT)ReadData+=1;
      AD7799_SCLK=1;
   //AD7799_CS=1;
   return(ReadData);
void WaiteRDY(void)
    unsigned int iint;
    iint=0;
    while(AD7799_RDY)
        iint++;
        if(iint>20000)
            //reset ad7799
            WriteByteToAd7799(0xff);
            for(iint=0;iint<1000;iint++)
                _nop_();
                _nop_();
            Ad7799_Ini(0);
            break;
void Ad7799_Ini(unsigned char ChannelNum)
    WriteByteToAd7799(0x10);//b0000 1000
    /* Writes to Communications Register Setting Next Operation as Write to
    CONFIGURATION Register*/
    WriteByteToAd7799(0x00); //增益为0
    WriteByteToAd7799(0x10+ChannelNum); //1通道
    /*CONFIGURATION REGISTER[00,BO(0),U/B(0),
    0(0),G2(1),G1(1),G0(1),0,0,REF_DET(0),BUF(1),0(0),CH2(0),CH1(0),CH0(0)]*/
    WriteByteToAd7799(0x08); //b0000 1000
    Mode Register*/
    WriteByteToAd7799(0x80);
    WriteByteToAd7799(0x0a);
    /* Writes to Mode Register Initiating Internal Zero-Scale Calibration*/
    WaiteRDY();
    /* Wait for RDY pin to go low to indicate end of calibration cycle*/
    Mode Register*/
    WriteByteToAd7799(0xa0);
    /* Writes to Mode Register Initiating Internal Full-Scale Calibration*/
    WaiteRDY();
    Mode Register*/
    WriteByteToAd7799(0x0A);
    /* Mode Register[MD2(0),MD1(0),MD0(0),PSW(0),0(0),0(0),0(0),0(0),
    (0),(0),0(0),0(0),FS3(1),FS2(0),FS1(1),FS0(0)]*/
    /*模式0 Continuous-Conversion Mode.,Fadc=16.7HZ;*/
long ReadAd7799ConversionData(void)
    long ConverData;
    unsigned char ADSAT;
    unsigned int iint;
    WaiteRDY();
    WriteByteToAd7799(0x40);
    ADSAT=ReadByteFromAd7799();
    if((ADSAT&0x40)||(ADSAT& 0x08)==0)  //出错或者读写异常
   for(iint=0;iint<3000;iint++)
        _nop_();
    Ad7799_Ini(0);
       return(0);
    else
    WriteByteToAd7799(0x58);
    /* Writes to Communications Register Setting Next Operation as Continuous
    Read From Data Register*/
    WaiteRDY();
   if(!AD7799_RDY)
       ConverData=0;
       ConverData=ReadByteFromAd7799();
       ConverData=ConverData<<8;
       ConverData=ReadByteFromAd7799()+ConverData;
   /* Read Conversion Result from AD7730's Data Register*/
   return(ConverData);
#include <reg52.h>
#include "ad7799.h"
idata long addata;
main()
   Ad7799_Ini(0);
   while(1)
     addata=ReadAd7799ConversionData();
haolei432370| | 2012-8-21 00:31 | 只看该作者
可能是焊接  虚焊
仔细检查电路
shell.albert| | 2012-8-21 08:26 | 只看该作者
仔细检查电路图,仔细检查时序图,仔细检查程序流程图。
