【萌新求助】我这个stm32矩阵4x4显示数字,按键没反应
1591|4
ruoxin1|  楼主 | 2018-2-28 17:14 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
ruoxin1|  楼主 | 2018-2-28 17:29 | 只看该作者
#include "stm32f10x.h"
#include"sys.h"
u8 KeyValue=0;
void Delay_Ms( u16 time );
u8 anjian(void);
u8 table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};  //Õý³£¹²Ñô¼«´úÂë
void GPIO_Configuration(void);
int main()
    GPIO_Configuration();
    while(1)
                anjian();
                GPIO_ResetBits (GPIOC, GPIO_Pin_0);
                GPIOA->ODR=table[KeyValue%10];
                Delay_Ms(5);
                GPIO_SetBits(GPIOC, GPIO_Pin_0);
                GPIO_ResetBits (GPIOC, GPIO_Pin_1);
                GPIOA->ODR=table[KeyValue/10];
                Delay_Ms(5);
                GPIO_SetBits(GPIOC, GPIO_Pin_1);
void GPIO_Configuration(void)    //GPIO¿ÚÅäÖÃ
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC,ENABLE);
  //LED
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
        GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
        GPIO_Init(GPIOA,&GPIO_InitStructure);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;
        GPIO_SetBits(GPIOB, GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3);
        GPIO_ResetBits(GPIOB, GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7);
void delay_ms(u16 time)       //ÑÓʱº¯Êý½èÓñðÈ˵ĸÄÌì×ÐϸÀí½â´ó¸Å1000Ϊ1s
  u16 i=0;
  while(time--)
    i=12000;
    while(i--);
u8 anjian(void)
        if((GPIO_ReadInputData(GPIOB)&0xff)!=0x0f)
                Delay_Ms(10);
                        GPIO_SetBits(GPIOB, GPIO_Pin_0);
                        GPIO_ResetBits(GPIOB, GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3);
                        switch(GPIO_ReadInputData(GPIOB)&0xff)
                        case 0x11: KeyValue = 1; break;
                        case 0x21: KeyValue = 5; break;
                        case 0x41: KeyValue = 9; break;
                        case 0x81: KeyValue = 13;break;
                        GPIO_SetBits(GPIOB, GPIO_Pin_1);
                        GPIO_ResetBits(GPIOB, GPIO_Pin_0 | GPIO_Pin_2 | GPIO_Pin_3);
                        case 0x12: KeyValue = 2; break;
                        case 0x22: KeyValue = 6; break;
                        case 0x42: KeyValue = 10;break;
                        case 0x82: KeyValue = 14;break;
                        GPIO_SetBits(GPIOB, GPIO_Pin_2);
                        GPIO_ResetBits(GPIOB, GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_3);
                        case 0x14: KeyValue = 3; break;
                        case 0x24: KeyValue = 7; break;
                        case 0x44: KeyValue = 11;break;
                        case 0x84: KeyValue = 15;break;
                        GPIO_SetBits(GPIOB, GPIO_Pin_3);
                        GPIO_ResetBits(GPIOB, GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2);
                        case 0x18: KeyValue = 4; break;
                        case 0x28: KeyValue = 8; break;
                        case 0x48: KeyValue = 12;break;
                        case 0x88: KeyValue = 16;break;
                        GPIO_ResetBits(GPIOB, GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 |GPIO_Pin_7);
                        while((GPIO_ReadInputData(GPIOB)&0xff)!=0x0f)
                Delay_Ms(5);
                Delay_Ms(5);
                        return KeyValue;
        return 0;
                u16 i,j;
                for( i = 0; i < time; i++ )
                                for( j = 10000; j > 0; j-- );
caijie001| | 2018-3-2 00:15 | 只看该作者
单步调试试试,按着一个按键,看看哪个函数没有进入
zhaoyu2005| | 2018-3-2 08:44 | 只看该作者
没电路图,让人家根据你的程序反推电路?
dirtwillfly| | 2018-3-2 16:12 | 只看该作者
那么长的代码,很少有人会读的。
建议楼主逐步调试代码看看,还有就是按键和显示分别调试,调试没问题了再进行整合
