有人知道veripool么
3734|8
 楼主| ma9453 发表于 2011-8-17 17:41 | 显示全部楼层 |阅读模式
有人知道verilog-perl么?这个是做什么的啊
AutoESL 发表于 2011-8-18 09:58 | 显示全部楼层
一种基于Perl的Verilog代码自动生成的EDA工具?
AutoESL 发表于 2011-8-18 09:59 | 显示全部楼层
http://www.veripool.org/wiki/verilog-perl
Introduction to Verilog-Perl
Written by Wilson Snyder <wsnyder@wsnyder.org>.
Summary
The Verilog-Perl library is a building point for Verilog support in the Perl language. It includes:
    Verilog::Getopt which parses command line options similar to C++ and VCS.
    Verilog::Language which knows the language keywords and parses numbers.
    Verilog::Netlist which builds netlists out of Verilog files. This allows easy scripts to determine things such as the hierarchy of modules.
    Verilog::Parser invokes callbacks for language tokens.
    Verilog::Preproc preprocesses the language, and allows reading post-processed files right from Perl without temporary files.
    vpassert inserts PLIish warnings and assertions for any simulator.
    vppreproc preprocesses the complete Verilog 2001 and SystemVerilog language.
    vrename renames and cross-references Verilog symbols. Vrename creates Verilog cross references and makes it easy to rename signal and module names across multiple files. Vrename uses a simple and efficient three step process. First, you run vrename to create a list of signals in the design. You then edit this list, changing as many symbols as you wish. Vrename is then run a second time to apply the changes.
See also
See the buttons at the top of this page, which include:
Verilog-Perl installation
Verilog-Perl documentation
Verilog-Perl mailing lists
没用过
 楼主| ma9453 发表于 2011-8-19 10:06 | 显示全部楼层
3# AutoESL
请问有什么工具可以解析VERILOG代码,能得到verilog内module间的连接关系(综合前的网表,不知道是不是可以这么叫)
AutoESL 发表于 2011-8-19 17:28 | 显示全部楼层
没有这样玩过, 不了解
ooljo 发表于 2011-8-19 23:09 | 显示全部楼层
这个我也不太了解了
opple 发表于 2011-8-20 10:08 | 显示全部楼层
解析VERILOG代码 这个貌似很少接触吧
opple 发表于 2011-8-20 22:59 | 显示全部楼层
没有人理我呀 好失败
 楼主| ma9453 发表于 2011-8-20 23:38 | 显示全部楼层
8# opple
我理你。。。。
你接触过这方面么
