求93c46读写程序
4240|5
 楼主| todozhao 发表于 2008-6-17 16:20 | 显示全部楼层 |阅读模式
谁有93c46的读写程序??<br />要8位模式下的(org接地模式)。<br />不胜感激!!!!!
 楼主| todozhao 发表于 2008-6-17 16:28 | 显示全部楼层
最好是c语言的!!
我用的是keil&nbsp;c51!!<br />最好是c语言编写的程序!!!<br />谢谢!!!!
tyw 发表于 2008-6-17 19:52 | 显示全部楼层
其实网上一搜就有了
<table class=ubb cellspacing=0><TR><td class=ubb><B>c51写的93C46的读写程序</B><br />http://www.eebyte.com&nbsp;&nbsp;2003-4-22&nbsp;&nbsp;电子工程师网站</td></TR><TR><td class=ubb><table class=ubb cellspacing=0><TR><td class=ubb>#include&nbsp;&ltreg52.h&gt<br />sbit&nbsp;CS=P2^7;<br />sbit&nbsp;SK=P2^6;<br />sbit&nbsp;DI=P2^5;<br />sbit&nbsp;DO=P2^4;&nbsp;<br /><br />/*<br />extern&nbsp;unsigned&nbsp;char&nbsp;ReadChar(unsigned&nbsp;char&nbsp;address);<br />extern&nbsp;void&nbsp;WriteChar(unsigned&nbsp;char&nbsp;address,unsigned&nbsp;char&nbsp;InData);<br />extern&nbsp;void&nbsp;ReadString(unsigned&nbsp;char&nbsp;data&nbsp;*RamAddress,unsigned&nbsp;char&nbsp;RomAddress,unsigned&nbsp;char&nbsp;Number);<br />extern&nbsp;void&nbsp;WriteString(unsigned&nbsp;char&nbsp;data&nbsp;*RamAddress,unsigned&nbsp;char&nbsp;RomAddress,unsigned&nbsp;char&nbsp;Number);<br />*/<br />//&nbsp;Write&nbsp;enable&nbsp;must&nbsp;precede&nbsp;all&nbsp;programming&nbsp;modes.<br />void&nbsp;Ewen(void)&nbsp;{<br />unsigned&nbsp;char&nbsp;temp,InData;<br />CS=0;&nbsp;<br />SK=0;<br />CS=1;<br />InData=0x98;&nbsp;//&nbsp;10011XXXX<br />for(temp=9;temp!=0;temp--)&nbsp;{&nbsp;//&nbsp;9<br />DI=InData&0x80;<br />SK=1;&nbsp;SK=0;<br />InData&lt&lt=1;<br />}<br />CS=0;<br />}<br />//&nbsp;Disables&nbsp;all&nbsp;programming&nbsp;instructions.<br />void&nbsp;Ewds(void)&nbsp;{<br />unsigned&nbsp;char&nbsp;temp,InData;<br />CS=0;<br />SK=0;<br />CS=1;<br />InData=0x80;&nbsp;//&nbsp;10000XXXX<br />for(temp=9;temp!=0;temp--)&nbsp;{&nbsp;//&nbsp;9<br />DI=InData&0x80;<br />SK=1;&nbsp;SK=0;<br />InData&lt&lt=1;<br />}<br />CS=0;<br />}<br />//&nbsp;Reads&nbsp;data&nbsp;stored&nbsp;in&nbsp;memory,&nbsp;at&nbsp;specified&nbsp;address.<br />unsigned&nbsp;int&nbsp;Read(unsigned&nbsp;char&nbsp;address)&nbsp;{<br />unsigned&nbsp;char&nbsp;temp;<br />unsigned&nbsp;int&nbsp;result;<br />Ewen();<br />SK=0;&nbsp;DI=1;&nbsp;//&nbsp;110&nbsp;A5-A0<br />CS=0;&nbsp;CS=1;<br />SK=1;&nbsp;SK=0;&nbsp;//&nbsp;1<br />address=address&0x3f|0x80;<br />for(temp=8;temp!=0;temp--)&nbsp;{&nbsp;//&nbsp;8<br />DI=address&0x80;<br />SK=1;&nbsp;SK=0;<br />address&lt&lt=1;<br />}<br />DO=1;<br />for(temp=16;temp!=0;temp--)&nbsp;{&nbsp;//&nbsp;16<br />SK=1;<br />result=(result&lt&lt1)|DO;<br />SK=0;<br />}<br />CS=0;<br />Ewds();<br />return(result);<br />}<br />//&nbsp;Writes&nbsp;memory&nbsp;location&nbsp;An&nbsp;-&nbsp;A0.<br />void&nbsp;Write(unsigned&nbsp;char&nbsp;address,unsigned&nbsp;int&nbsp;InData)&nbsp;{<br />unsigned&nbsp;char&nbsp;temp;<br />Ewen();<br />SK=0;&nbsp;DI=1;&nbsp;//&nbsp;101&nbsp;A5-A0<br />CS=0;&nbsp;CS=1;<br />SK=1;&nbsp;SK=0;&nbsp;//&nbsp;1<br />address=address&0x3f|0x40;<br />for(temp=8;temp!=0;temp--)&nbsp;{&nbsp;//&nbsp;8<br />DI=address&0x80;<br />SK=1;&nbsp;SK=0;<br />address&lt&lt=1;<br />}<br />for(temp=16;temp!=0;temp--)&nbsp;{&nbsp;//&nbsp;16<br />DI=InData&0x8000;<br />SK=1;&nbsp;SK=0;<br />InData&lt&lt=1;<br />}<br />CS=0;&nbsp;DO=1;<br />CS=1;&nbsp;SK=1;<br />while(DO==0)&nbsp;{&nbsp;//&nbsp;busy&nbsp;test<br />SK=0;&nbsp;SK=1;<br />}<br />SK=0;&nbsp;CS=0;<br />Ewds();<br />}<br />/*<br />//&nbsp;Erase&nbsp;memory&nbsp;location&nbsp;An&nbsp;-&nbsp;A0.<br />void&nbsp;Erase(unsigned&nbsp;char&nbsp;address)&nbsp;{<br />unsigned&nbsp;char&nbsp;temp;<br />Ewen();<br />SK=0;&nbsp;DI=1;&nbsp;//&nbsp;111&nbsp;A5-A0<br />CS=0;&nbsp;CS=1;<br />SK=1;&nbsp;SK=0;&nbsp;//&nbsp;1<br />address|=0xc0;<br />for(temp=8;temp!=0;temp--)&nbsp;{&nbsp;//&nbsp;8<br />DI=address&0x80;<br />SK=1;&nbsp;SK=0;<br />address&lt&lt=1;<br />}<br />CS=0;&nbsp;DO=1;<br />CS=1;&nbsp;SK=1;<br />while(DO==0)&nbsp;{<br />SK=0;&nbsp;SK=1;<br />}<br />SK=0;&nbsp;CS=0;<br />Ewds();<br />}<br />//&nbsp;Erases&nbsp;all&nbsp;memory&nbsp;locations.&nbsp;Valid&nbsp;only&nbsp;at&nbsp;VCC&nbsp;=&nbsp;4.5V&nbsp;to&nbsp;5.5V.<br />void&nbsp;Eral(void)&nbsp;{<br />unsigned&nbsp;char&nbsp;temp,InData;<br />Ewen();<br />CS=0;<br />SK=0;<br />CS=1;<br />InData=0x90;&nbsp;//&nbsp;10010XXXX<br />for(temp=9;temp!=0;temp--)&nbsp;{&nbsp;//&nbsp;9<br />DI=InData&0x80;<br />SK=1;&nbsp;SK=0;<br />InData&lt&lt=1;<br />}<br />CS=0;&nbsp;DO=1;<br />CS=1;&nbsp;SK=1;<br />while(DO==0)&nbsp;{<br />SK=0;&nbsp;SK=1;<br />}<br />SK=0;&nbsp;CS=0;<br />Ewds();<br />}<br />//&nbsp;Writes&nbsp;all&nbsp;memory&nbsp;locations.&nbsp;Valid&nbsp;only&nbsp;at&nbsp;VCC&nbsp;=&nbsp;4.5V&nbsp;to&nbsp;5.5V.<br />void&nbsp;Wral(unsigned&nbsp;int&nbsp;InData)&nbsp;{<br />unsigned&nbsp;char&nbsp;temp,address;<br />Ewen();<br />CS=0;<br />SK=0;<br />CS=1;<br />address=0x88;&nbsp;//&nbsp;10001XXXX<br />for(temp=9;temp!=0;temp--)&nbsp;{&nbsp;//&nbsp;9<br />DI=address&0x80;<br />SK=1;&nbsp;SK=0;<br />address&lt&lt=1;<br />}<br />for(temp=16;temp!=0;temp--)&nbsp;{&nbsp;//&nbsp;16<br />DI=InData&0x8000;<br />SK=1;&nbsp;SK=0;<br />InData&lt&lt=1;<br />}<br />CS=0;&nbsp;DO=1;<br />CS=1;&nbsp;SK=1;<br />while(DO==0)&nbsp;{<br />SK=0;&nbsp;SK=1;<br />}<br />SK=0;&nbsp;CS=0;<br />Ewds();<br />}<br />*/<br />unsigned&nbsp;char&nbsp;ReadChar(unsigned&nbsp;char&nbsp;address)&nbsp;{<br />unsigned&nbsp;char&nbsp;temp=address&gt&gt1;<br />if(address&0x01)&nbsp;return((unsigned&nbsp;char)(Read(temp)&gt&gt8));<br />else&nbsp;return((unsigned&nbsp;char)(Read(temp)));<br />}<br />void&nbsp;WriteChar(unsigned&nbsp;char&nbsp;address,unsigned&nbsp;char&nbsp;InData)&nbsp;{<br />unsigned&nbsp;char&nbsp;temp=address&gt&gt1;<br />if(address&0x01)&nbsp;Write(temp,(unsigned&nbsp;int)(Read(temp)&0x00ff|(InData&lt&lt8)));<br />else&nbsp;Write(temp,(unsigned&nbsp;int)(Read(temp)&0xff00|InData));<br />}<br />void&nbsp;ReadString(unsigned&nbsp;char&nbsp;data&nbsp;*RamAddress,unsigned&nbsp;char&nbsp;RomAddress,unsigned&nbsp;char&nbsp;Number)&nbsp;{<br />while(Number!=0)&nbsp;{<br />*RamAddress=ReadChar(RomAddress);<br />RamAddress++;<br />RomAddress++;<br />Number--;<br />}<br />}<br />void&nbsp;WriteString(unsigned&nbsp;char&nbsp;data&nbsp;*RamAddress,unsigned&nbsp;char&nbsp;RomAddress,unsigned&nbsp;char&nbsp;Number)&nbsp;{<br />unsigned&nbsp;int&nbsp;temp;<br />if(Number==0)&nbsp;return;<br />if(RomAddress&0x01)&nbsp;{<br />WriteChar(RomAddress,*RamAddress);<br />RamAddress++;<br />RomAddress++;<br />Number--;<br />}<br />if(Number==0)&nbsp;return;<br />while(Number&gt&gt1)&nbsp;{<br />temp=*RamAddress;<br />RamAddress++;<br />temp=temp|(*RamAddress)&lt&lt8;<br />RamAddress++;<br />Write(RomAddress&gt&gt1,temp);<br />RomAddress++;<br />RomAddress++;<br />Number--;<br />Number--;<br />}<br />if(Number)&nbsp;WriteChar(RomAddress,*RamAddress);<br />}&nbsp;</td></TR></table></td></TR></table><br />
tyw 发表于 2008-6-17 19:54 | 显示全部楼层
这个汇编的解释较多,便于阅读
<br />&nbsp;<br /><font color=#FF0000>93C46&nbsp;串行EEPROM&nbsp;数据读写.pdf&nbsp;→&nbsp;</font><a href="https://bbs.21ic.com/upfiles/img/20078/20078220159183.pdf" target=_blank>https://bbs.21ic.com/upfiles/img/20078/20078220159183.pdf</a><br /><br /><img src="https://bbs.21ic.com/upfiles/img/20078/200782202059469.gif"><br /><br /><img src="https://bbs.21ic.com/upfiles/img/20078/200782202143702.gif"><br /><br /><img src="https://bbs.21ic.com/upfiles/img/20078/200782202211231.gif"><br />&nbsp;<br /><img src="https://bbs.21ic.com/upfiles/img/20078/200782202436714.gif">
 楼主| todozhao 发表于 2008-6-18 11:15 | 显示全部楼层
这个c写的程序试过吗??
这个程序我试过!怎么就是不好用??<br />我现在找了一个93c66的讲究着,用这个93c66的程序最后两位数据没法读写
fangyan2010 发表于 2010-4-13 16:09 | 显示全部楼层
** 函数名称:    WriteChar() , ReadChar() , WriteString() , ReadString() , Erase() , Eral()
** 功能描述:    93c46读取字符和字符串函数
** 输 入:      写入一个字符: address , InData
                                                          写入地址 , 写入数据
                                读出一个字符: address
                                                          读出相应地址的数据
                                写入字符串  : *RamAddress ,RomAddress , Number
                                                           读入数组指针 , 93c46写入起始地址 , 写入字节个数
                                读出字符串  : *RamAddress ,RomAddress , Number
                                擦除一个字节: address
                                                          要擦除的存储区地址
                                擦除所有存储区: 无输入函数
** 输 出:      ...
** 全局变量:    无
** 调用模块:    无
** 作 者:      王恒智  (修改  程序匠人源码)
** 日 期:      2009年5月13日
#ifndef __93C46_H__
#define __93C46_H__
sbit CS=P1^0;
sbit SK=P1^1;
sbit DI=P1^2;
sbit DO=P1^3;
extern          void WriteChar(unsigned char address,unsigned char InData);
extern unsigned char ReadChar(unsigned char address);
extern                         void WriteString(unsigned char data *RamAddress,unsigned char RomAddress,unsigned char Number);
extern                         void ReadString(unsigned char data *RamAddress,unsigned char RomAddress,unsigned char Number);
extern          void Erase(unsigned char address)
extern          void Eral(void)
// Write enable must precede all programming modes.
void Ewen(void)
unsigned char temp,InData;
CS=0;
SK=0;
CS=1;
InData=0x98; // 10011XXXX
for(temp=9;temp!=0;temp--) { // 9
  DI=InData&0x80;
  SK=1; SK=0;
  InData<<=1;
CS=0;
// Disables all programming instructions.
void Ewds(void)
CS=0;
SK=0;
CS=1;
InData=0x80; // 10000XXXX
  DI=InData&0x80;
  SK=1; SK=0;
  InData<<=1;
CS=0;
// Reads data stored in memory, at specified address.
unsigned int Read(unsigned char address)
unsigned char temp;
unsigned int result;
Ewen();  //擦除和写入允许
SK=0; DI=1; // 110 A5-A0
CS=0; CS=1;
SK=1; SK=0;   // 1
for(temp=8;temp!=0;temp--) // 8
  DI=address&0x80;
  SK=1; SK=0;
  address<<=1;
DO=1;
for(temp=16;temp!=0;temp--)// 16
  SK=1;
  result=(result<<1)|DO;
  SK=0;
CS=0;
Ewds();   //擦除和写入禁止
return(result);
// Writes memory location An - A0.
void Write(unsigned char address,unsigned int InData) {
unsigned char temp;
Ewen();
SK=0; DI=1; // 101 A5-A0
CS=0; CS=1;
SK=1; SK=0;   // 1
for(temp=8;temp!=0;temp--) { // 8
  DI=address&0x80;
  SK=1; SK=0;
  address<<=1;
for(temp=16;temp!=0;temp--) { // 16
  DI=InData&0x8000;
  SK=1; SK=0;
  InData<<=1;
CS=0; DO=1;
CS=1; SK=1;
while(DO==0) {   // busy test
  SK=0; SK=1;
SK=0; CS=0;
Ewds();
// Erase memory location An - A0.
void Erase(unsigned char address) {
unsigned char temp;
Ewen();
SK=0; DI=1; // 111 A5-A0
CS=0; CS=1;
SK=1; SK=0;   // 1
address|=0xc0;
  DI=address&0x80;
  SK=1; SK=0;
  address<<=1;
CS=0; DO=1;
CS=1; SK=1;
while(DO==0) {
  SK=0; SK=1;
SK=0; CS=0;
Ewds();
// Erases all memory locations. Valid only at VCC = 4.5V to 5.5V.
void Eral(void) {
Ewen();
CS=0;
SK=0;
CS=1;
InData=0x90; // 10010XXXX
  DI=InData&0x80;
  SK=1; SK=0;
  InData<<=1;
CS=0; DO=1;
CS=1; SK=1;
while(DO==0) {
  SK=0; SK=1;
SK=0; CS=0;
Ewds();
// Writes all memory locations. Valid only at VCC = 4.5V to 5.5V.
void Wral(unsigned int InData) {
unsigned char temp,address;
Ewen();
CS=0;
SK=0;
CS=1;
address=0x88; // 10001XXXX
  DI=address&0x80;
  SK=1; SK=0;
  address<<=1;
  DI=InData&0x8000;
  SK=1; SK=0;
  InData<<=1;
CS=0; DO=1;
CS=1; SK=1;
while(DO==0) {
  SK=0; SK=1;
SK=0; CS=0;
Ewds();
unsigned char ReadChar(unsigned char address) {
unsigned char temp=address>>1;
if(address&0x01) return((unsigned char)(Read(temp)>>8));
else return((unsigned char)(Read(temp)));
void WriteChar(unsigned char address,unsigned char InData) {
if(address&0x01) Write(temp,(unsigned int)(Read(temp)&0x00ff|(InData<<8)));
else Write(temp,(unsigned int)(Read(temp)&0xff00|InData));
void ReadString(unsigned char *RamAddress,unsigned char RomAddress,unsigned char Number) {
while(Number!=0) {
  RamAddress++;
  RomAddress++;
  Number--;
void WriteString(unsigned char *RamAddress,unsigned char RomAddress,unsigned char Number) {
unsigned int temp;
if(Number==0) return;
if(RomAddress&0x01)
  RamAddress++;
  RomAddress++;
  Number--;
while(Number>>1)
  temp=*RamAddress;
  RamAddress++;
  temp=temp|(*RamAddress)<<8;
  RamAddress++;
  Write(RomAddress>>1,temp);
  RomAddress++;
  RomAddress++;
  Number--;
  Number--;
if(Number) WriteChar(RomAddress,*RamAddress);
#endif
这是对93c46设计的头文件,是一些示例程序。我测试了,可以在板子上跑。但是我没有弄明白里面的result是指什么。
