STM32的DAC问题
3031|1
 楼主| tairuibao 发表于 2011-10-19 09:27 | 显示全部楼层 |阅读模式
我用F103RC,原程序用TIM8出发,不过我屏蔽了。调试没有结果,请高手看看怎么回事呢?
#include "stm32f10x.h"
#include "GLCD.h"
#include "USART.h"
void GPIO_Configuration(void)
/* Configure DAC channe1 and DAC channel2 outputs pins */
   GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_4 | GPIO_Pin_5;
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
   GPIO_Init(GPIOA, &GPIO_InitStructure);
    /* Configure USART1 Tx (PA.09) as alternate function push-pull
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    Configure USART1 Rx (PA.10) as input floating
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
   GPIO_Init(GPIOA, &GPIO_InitStructure);  */
//系统中断管理
void NVIC_Configuration(void)
   /* Configure the NVIC Preemption Priority Bits */
   NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
#ifdef  VECT_TAB_RAM
   /* Set the Vector Table base location at 0x20000000 */
   NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else  /* VECT_TAB_FLASH  */
   /* Set the Vector Table base location at 0x08000000 */
   NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
//配置系统时钟,使能各外设时钟
void RCC_Configuration(void)
SystemInit();
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA
                           |RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC
                           |RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE
         |RCC_APB2Periph_ADC1  | RCC_APB2Periph_AFIO
                           |RCC_APB2Periph_SPI1, ENABLE );
    // RCC_APB2PeriphClockCmd(RCC_APB2Periph_ALL ,ENABLE );
     RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4
                           |RCC_APB1Periph_USART3|RCC_APB1Periph_TIM2
                           , ENABLE );
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
  /* Enable peripheral clocks --------------------------------------------------*/
   /* DMA clock enable */
   RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA2, ENABLE);
   /* AFIO and GPIOA Periph clock enable */
   RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO | RCC_APB2Periph_GPIOA, ENABLE);
   /* DAC Periph clock enable */
   RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE);
   /* TIM8 Periph clock enable */
   //RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM8, ENABLE);
/*void InitDis(void)
   LCD Module init
   GLCD_init();
   GLCD_clear(White);
   GLCD_setTextColor(Blue);
   GLCD_displayStringLn(Line1, "     GoldBull");
   GLCD_displayStringLn(Line2, "   DAC example");
   GLCD_setTextColor(Red);
//配置所有外设
void Init_All_Periph(void)
RCC_Configuration();
//InitDis();
// GLCD_Test();
GPIO_Configuration();
NVIC_Configuration();
//USART1_Configuration();
//USART1Write((u8*)"    GoldBull  ADC_example ",sizeof("    GoldBull  DAC_example "));
#define DAC_DHR12RD_Address      0x40007420
/* Init Structure definition */
DAC_InitTypeDef            DAC_InitStructure;
DMA_InitTypeDef            DMA_InitStructure;
TIM_TimeBaseInitTypeDef    TIM_TimeBaseStructure;
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
ErrorStatus HSEStartUpStatus;
uc16 Sine12bit[32] = {2047, 2447, 2831, 3185, 3498, 3750, 3939, 4056, 4095, 4056,
                      3939, 3750, 3495, 3185, 2831, 2447, 2047, 1647, 1263, 909,
                      599, 344, 155, 38, 0, 38, 155, 344, 599, 909, 1263, 1647};
u32 DualSine12bit[32];
u8 Idx = 0;
int main(void)
Init_All_Periph();
/* TIM8 Configuration
    Time base configuration
   TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
   TIM_TimeBaseStructure.TIM_Period = 0x19;
   TIM_TimeBaseStructure.TIM_Prescaler = 0x0;
   TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;
   TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
   TIM_TimeBaseInit(TIM8, &TIM_TimeBaseStructure);
    TIM8 TRGO selection
   TIM_SelectOutputTrigger(TIM8, TIM_TRGOSource_Update);*/
   /* DAC channel1 Configuration */
   DAC_InitStructure.DAC_Trigger = DAC_Trigger_None;
  DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None;
   DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Disable;
   DAC_Init(DAC_Channel_1, &DAC_InitStructure);
   /* DAC channel2 Configuration */
   DAC_Init(DAC_Channel_2, &DAC_InitStructure);
   /* Fill Sine32bit table */
   for (Idx= 0; Idx<32; Idx++)
     DualSine12bit[Idx] = (Sine12bit[Idx] << 16) + (Sine12bit[Idx]);
   /* DMA2 channel4 configuration */
   DMA_DeInit(DMA2_Channel4);
   DMA_InitStructure.DMA_PeripheralBaseAddr = DAC_DHR12RD_Address;
   DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&DualSine12bit;
   DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
   DMA_InitStructure.DMA_BufferSize = 32;
   DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
   DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
   DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word;
   DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Word;
   DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
   DMA_InitStructure.DMA_Priority = DMA_Priority_High;
   DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
   DMA_Init(DMA2_Channel4, &DMA_InitStructure);
   /* Enable DMA2 Channel4 */
   DMA_Cmd(DMA2_Channel4, ENABLE);
   /* Enable DAC Channel1 */
  DAC_Cmd(DAC_Channel_1, ENABLE);
   /* Enable DAC Channel2 */
   DAC_Cmd(DAC_Channel_2, ENABLE);
   /* Enable DMA for DAC Channel2 */
   //DAC_DMACmd(DAC_Channel_2, ENABLE);
   /* TIM8 enable counter */
   //TIM_Cmd(TIM8, ENABLE);
  while(1)
huang1shan 发表于 2011-10-20 08:54 | 显示全部楼层
这就是ARM程序啊?这么复杂,打字母都打半天啊!到底是什么意思啊
