[matlab] 求助啊,ise编译错误,6.1中有,7.1和10.1没问题
10636|22
 楼主| mxjtracy 发表于 2011-10-29 16:01 | 显示全部楼层 |阅读模式
编写了一个aes加密程序在ise10.1和7.1中编译都没问题,但在6.1中出现了问题,求助啊。导师要求必须在6.1中实现,求助各位大侠了。附件是我的代码,round模块调用另外三个子模块。   大家好 我用的是XC2S300E
ERROR:Xst:1844 - Port <mixcolumn_out<0>> of node <Mxor_d_out_Result<0>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<1>> of node <Mxor_d_out_Result<1>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<2>> of node <Mxor_d_out_Result<2>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<3>> of node <Mxor_d_out_Result<3>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<4>> of node <Mxor_d_out_Result<4>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<5>> of node <Mxor_d_out_Result<5>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<6>> of node <Mxor_d_out_Result<6>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<7>> of node <Mxor_d_out_Result<7>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<8>> of node <Mxor_d_out_Result<8>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<9>> of node <Mxor_d_out_Result<9>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<10>> of node <Mxor_d_out_Result<10>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<11>> of node <Mxor_d_out_Result<11>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<12>> of node <Mxor_d_out_Result<12>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<13>> of node <Mxor_d_out_Result<13>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<14>> of node <Mxor_d_out_Result<14>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<15>> of node <Mxor_d_out_Result<15>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<16>> of node <Mxor_d_out_Result<16>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<17>> of node <Mxor_d_out_Result<17>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<18>> of node <Mxor_d_out_Result<18>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<19>> of node <Mxor_d_out_Result<19>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<20>> of node <Mxor_d_out_Result<20>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<21>> of node <Mxor_d_out_Result<21>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<22>> of node <Mxor_d_out_Result<22>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<23>> of node <Mxor_d_out_Result<23>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<24>> of node <Mxor_d_out_Result<24>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<25>> of node <Mxor_d_out_Result<25>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<26>> of node <Mxor_d_out_Result<26>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<27>> of node <Mxor_d_out_Result<27>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<28>> of node <Mxor_d_out_Result<28>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<29>> of node <Mxor_d_out_Result<29>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<30>> of node <Mxor_d_out_Result<30>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<31>> of node <Mxor_d_out_Result<31>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<32>> of node <Mxor_d_out_Result<32>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<33>> of node <Mxor_d_out_Result<33>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<34>> of node <Mxor_d_out_Result<34>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<35>> of node <Mxor_d_out_Result<35>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<36>> of node <Mxor_d_out_Result<36>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<37>> of node <Mxor_d_out_Result<37>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<38>> of node <Mxor_d_out_Result<38>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<39>> of node <Mxor_d_out_Result<39>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<40>> of node <Mxor_d_out_Result<40>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<41>> of node <Mxor_d_out_Result<41>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<42>> of node <Mxor_d_out_Result<42>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<43>> of node <Mxor_d_out_Result<43>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<44>> of node <Mxor_d_out_Result<44>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<45>> of node <Mxor_d_out_Result<45>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<46>> of node <Mxor_d_out_Result<46>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<47>> of node <Mxor_d_out_Result<47>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<48>> of node <Mxor_d_out_Result<48>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<49>> of node <Mxor_d_out_Result<49>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<50>> of node <Mxor_d_out_Result<50>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<51>> of node <Mxor_d_out_Result<51>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<52>> of node <Mxor_d_out_Result<52>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<53>> of node <Mxor_d_out_Result<53>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<54>> of node <Mxor_d_out_Result<54>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<55>> of node <Mxor_d_out_Result<55>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<56>> of node <Mxor_d_out_Result<56>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<57>> of node <Mxor_d_out_Result<57>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<58>> of node <Mxor_d_out_Result<58>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<59>> of node <Mxor_d_out_Result<59>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<60>> of node <Mxor_d_out_Result<60>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<61>> of node <Mxor_d_out_Result<61>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<62>> of node <Mxor_d_out_Result<62>> from unit <round> has no source
ERROR:Xst:1844 - Port <mixcolumn_out<63>> of node <Mxor_d_out_Result<63>> from unit <round> has no source
AutoESL 发表于 2011-10-30 15:34 | 显示全部楼层
ISE太老了
建议用12.4及其以后的版本
墨攻1991 发表于 2011-10-30 18:20 | 显示全部楼层
你们老师使用6.1是不是因为你们用的芯片比较古老呀?建议使用高版本的,我现在用的是12.4
GoldSunMonkey 发表于 2011-10-30 21:59 | 显示全部楼层
ISE太老了
太老了,可以选择更换了。
GoldSunMonkey 发表于 2011-10-30 22:02 | 显示全部楼层
建议用12.4及其以后的版本
可能是器件不支持啊。
评分
参与人数 1威望 +1 收起 理由
mxjtracy + 1
查看全部评分
GoldSunMonkey 发表于 2011-10-30 22:04 | 显示全部楼层
没有代码很难知道怎么回事。
GoldSunMonkey 发表于 2011-10-30 22:31 | 显示全部楼层
[quote]你们老师使用6.1是不是因为你们用的芯片比较古老呀?建议使用高版本的,我现在用的是12.4
墨攻1991 发表于 2011-10-30 18:20 [url=https://bbs.21ic.com/redirect.php?goto=findpost&pid
 楼主| mxjtracy 发表于 2011-10-31 15:48 | 显示全部楼层
8# GoldSunMonkey 你好,这是我的代码程序,在10.1 7.1中都没问题。round模块调用另外三个子模块
 楼主| mxjtracy 发表于 2011-10-31 15:55 | 显示全部楼层
2# AutoESL 您好麻烦您看看我的代码吧
4# 墨攻1991 您好麻烦您看看我的代码吧
GoldSunMonkey 发表于 2011-10-31 16:56 | 显示全部楼层
没有6.1的ISE,没法看
墨攻1991 发表于 2011-10-31 18:27 | 显示全部楼层
11# mxjtracy
你们用的是哪款芯片呀!
Oxygen.Chu 发表于 2011-10-31 20:24 | 显示全部楼层
也不要看代码了,也不用换版本了,直接把你们老师换了,才是硬道理~
墨攻1991 发表于 2011-10-31 20:58 | 显示全部楼层
1# mxjtracy
12.4编译没有问题
ooljo 发表于 2011-11-1 07:25 | 显示全部楼层
过来了解下
氛围真好呀
 楼主| mxjtracy 发表于 2011-11-1 08:30 | 显示全部楼层
XC2S300E 13# 墨攻1991
AutoESL 发表于 2011-11-1 10:16 | 显示全部楼层
我真没有6.1的版本
我最早接触就是7.1的版本了
