| 原本是数码管动态扫描并用按键调加减数字变化,刚开始是OK的,在写EEPROM保存数据设置,后来更改数码管扫描方式按键没作用了,如把显示取消后,按键就有作用,现用LED作测试,发现系统只能执行一道任务类似,MCU用的是STC15W408AS,按键改成最老方式和状态按键都是这样,硬件也更换MCU了,这几天都搞晕了,请各位大神帮忙看看指点下。谢谢! 请看下面的程序 :
 include"STC15W.H"
 #include"intrins.h"
 #define uchar unsigned char
 #define uint unsigned int
 void digplay(uint hig);
 void key();
 sbit PWM=P1^7;
 sbit LED1=P5^5;
 sbit up=P1^4;
 sbit down=P1^5;
 sbit ba=P1^1;
 sbit sh=P1^0;
 sbit ge=P1^2;
 sbit dn=P1^3;
 uint hig=250;
 uchar code LED[]={0xCF,0x81,0xEA,0xE3,0xA5,0x67,0x6F,0xC1,0xEF,0xE7,0x5e};
 /************延时子程序*************/
void delayxms(uint z)
 uint y,x;
for(y=z;x>0;x--)
    for(y=110;y>0;y--);
void KeyScan(void)//按键扫描
   static uchar key1_lock=0;//自锁标志
  static uint count1=0;//计数延时
  static uchar key2_lock=0;//
   static uint count2=0;//
 if(up==0)
    if((count1++>=5)&&(key1_lock==0))
      key1_lock=1;
           LED1=~LED1;
   else
            key1_lock=0;
            count1=0;
         if(down==0)
           if((count2++>=5)&&(key2_lock==0))
             key2_lock=1;
                 LED1=~LED1;
         else
             key2_lock=0;
                 count2=0;
 void Init2()//定时器2初始化
AUXR&=0x04;        //12T
    T2L=0x78;        //定时5MS
    T2H=0xec;        //
    IE2|=0x04;
    AUXR|=0x10;        //开始计时
   EA=1;
 void digplay(uint hig)//数码管动态扫描
         static uchar i=0;
           P3=0x00;
          switch(i)
           case 0:
                 P3=LED[hig/100];
                         P1=0x02;
                         P1=0x00;
                         i++;
                         break;
           case 1:
                 P3=LED[hig/10%10];
                         P1=0x01;
                         P1=0x00;
                         i++;
                         break;
           case 2:
                 P3=LED[hig%10];
                         P1=0x04;
                         P1=0x00;
                         i++;
                         break;
                 case 3:
                     P3=0x5e;
                         P1=0x08;
                         P1=0x00;
                         i=0;
                         break;
                         delayxms(5);
 void main()//主程序
Init2();
 P5M0=0xff;
   P5M1=0x00;
   P3M0=0xff;
   P3M1=0x00;
   P1M0=0xff;
   P1M1=0xf0;
 while(1)
     digplay(hig);
 void t2int() interrupt 12
    KeyScan();
