[Quartus] ISE13.3和S6 伤不起,有木有
11761|61
Avnet_xlx 发表于 2011-11-9 14:51 | 显示全部楼层
嘿嘿,我天天身边都是Xilinx的人
到现在我从来没听说过会有这个。
GoldSunMonkey 发表于 2011-11-9 13:59
Description        This Answer Record describes the Known Issues for the Spartan-6 FPGA family used with ISE Design Suite 13.
                                                   Solution
The following items represent a collection of issues that have been identified in the 13.3 ISE design tools and are related to Spartan-6 FPGA. There might be issues which are present and are not listed here. If you discover an issue that is not on this list, please open a WebCase with Xilinx Technical Support.
It is strongly recommended that designs be re-synthesized (and IP cores re-implemented) when re-implementing for production using the software that has production status speed files for the target device. This ensures that the changes to DRCs, timing models, clock topologies, and other fixes in software are picked up.
Avnet_xlx 发表于 2011-11-9 14:52 | 显示全部楼层
Speed Files:
(Xilinx Answer 44192) - Design Advisory for Spartan-6 FPGA Speed File - Updates for Block RAM fMAX in Lower Power -1L Devices
(Xilinx Answer 44193) - Design Advisory for Spartan-6 FPGA Speed File - Updates for DCM Phase Alignment
GoldSunMonkey 发表于 2011-11-9 15:44 | 显示全部楼层
我刚才看了一下,这只是性能的改变,并不是S6的问题啊。
而且关于这个说明是:他是针对XA和XQ的,我们国内全部正规途径的都是XC的啊。
07-NOV-11 Updated Design Advisories: An update was made to the Speed File patch to include Automotive (XA) and Q Grade (XQ) devices. The new patch should be used if targeting XA or XQ parts.
GoldSunMonkey 发表于 2011-11-9 15:45 | 显示全部楼层
如果设计没有问题的时候,并不需要升级软件的。
我们一直是如此进行的,所有客户都用的很好。
sleepybear 发表于 2011-11-9 16:26 | 显示全部楼层
个人水平有限,只用过V5和S6。确实感觉S6有点不好用,时钟资源的使用方面。。。当然,我水平有限,只代表我个人感觉。
不过Xilinx还是很好的,AVnet的支持也很到位,有时候还会主动为我们提供我们可能会用到的功能特性的信息什么的。
stm32_ck 发表于 2011-11-9 19:02 | 显示全部楼层
我不是Xilinx的人。
兄弟,你把代码弄过来,
我们可以一起讨论一下。
我还没遇到转到S6有问题的客户。
我们可以一起讨论一下。
GoldSunMonkey 发表于 2011-11-9 14:16
这个不现实,FPGA代码属于公司的核心机密了。你是avnet的FAE吧,我估计你是新员工。我和avnet的FAE和Altera的FAE都沟通过。Altera说S6的lone line有问题。AVNET的fae不承认也不否认。不过平心而论。AVNET的FAE技术水平上挺不错,态度也很好,这也是我选择xilinx的理由,工程师都理解,产品可能有各个方面的问题,这是无法避免的,但是好的技术支持的态度是承认有问题并帮你寻找一个合适的解决办法。我是我欣赏的技术支持。
stm32_ck 发表于 2011-11-9 19:03 | 显示全部楼层
这个不现实,FPGA代码属于公司的核心机密了。你是avnet的FAE吧,我估计你是新员工。我和avnet的FAE和Altera的FAE都沟通过。Altera说S6的lone line有问题。AVNET的fae不承认也不否认。不过平心而论。AVNET的FAE技术 ...
写错一个字,这是我欣赏的技术支持,抱歉
GoldSunMonkey 发表于 2011-11-9 19:04 | 显示全部楼层
嘿嘿,那可以简化讨论。没有关系的。
GoldSunMonkey 发表于 2011-11-9 19:08 | 显示全部楼层
谢谢对安富利的支持。
其实我们不是回避问题,
只是有问题,我们能解决问题。
如果解决到能很好性能的实现自己的功能,那还是问题么??
所以不喜欢楼主说的,一上来就是S6没有生命周期。
altera的FPGA就一点问题没有?那要altera的FAE干什么?
不喜欢一上来就把S6打死的态度。
希望以后机会合作。谢谢啦。
 楼主| SuperX-men 发表于 2011-11-9 19:11 | 显示全部楼层
没有想到一石激起千层浪,多谢大家都热情讨论,目前看到唯一解决方案就是SmartXexplor来穷举看看是否能在13.3上能找到一个合适的软件设置,其实13.2的那个几分钟的结果也是Smartxplore跑出来的,再没有用这个功能前,13.2也要跑1个多小时,特别是Map的时候,现在调整参数后map无论13.2,还是13.3都很快,但是P&R就有非常大的差异在两个版本上,如果GSM能从Xilinx了解一下两个版本为何有这样的差异,如何修正,我想对我才是有最大的帮助
drentsi 发表于 2011-11-9 20:39 | 显示全部楼层
看到一堆CORE Generator,暴露了实力
GoldSunMonkey 发表于 2011-11-9 20:46 | 显示全部楼层
没有想到一石激起千层浪,多谢大家都热情讨论,目前看到唯一解决方案就是SmartXexplor来穷举看看是否能在13.3上能找到一个合适的软件设置,其实13.2的那个几分钟的结果也是Smartxplore跑出来的,再没有用这个功能前 ...
兄弟,这个归XILINX 的工厂,我没有这个权限或者说能力去了解这么深。
但使我觉得不要太绝对,因为真的是只有最适合脚的鞋子,而没有最好的鞋子。
balabalaa 发表于 2011-11-9 21:16 | 显示全部楼层
这贴要火。。。
GoldSunMonkey 发表于 2011-11-9 21:18 | 显示全部楼层
blacorse 发表于 2011-11-11 13:13 | 显示全部楼层
何为友邦?
ertu 发表于 2011-11-11 13:39 | 显示全部楼层
火大了
继续关注
fjzzclc 发表于 2011-11-15 16:56 | 显示全部楼层
丑到被通缉 发表于 2011-11-16 13:21 | 显示全部楼层
看不懂哦
ligg2005 发表于 2011-11-16 20:33 | 显示全部楼层
