[DSP] TI ARM和DSP双核平台的一个编译例程
500|8
 楼主| coshi 发表于 2019-8-1 11:24 | 显示全部楼层 |阅读模式
一个适用于TI ARM与DSP双核平台的makefile。该makefile示意了如何同时编译出ARM平台和DSP平台的执行文件,以便于比较ARM核和DSP核在进行运算时表现出来的性能差异。
makefile
# Makefile        #
# Builds the emqbit benchmark source for ARM and DSP                        #
#   Copyright (C) 2010 Texas Instruments Incorporated                       #
#     http://www.ti.com/                                                    #
#  Redistribution and use in source and binary forms, with or without       #
#  modification, are permitted provided that the following conditions       #
#  are met:        #
#    Redistributions of source code must retain the above copyright         #
#    notice, this list of conditions and the following disclaimer.          #
#    Redistributions in binary form must reproduce the above copyright      #
#    notice, this list of conditions and the following disclaimer in the    #
#    documentation and/or other materials provided with the                 #
#    distribution.                                                          #
#    Neither the name of Texas Instruments Incorporated nor the names of    #
#    its contributors may be used to endorse or promote products derived    #
#    from this software without specific prior written permission.          #
#  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS      #
#  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT        #
#  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR    #
#  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT     #
#  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,    #
#  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT         #
#  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,    #
#  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY    #
#  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT      #
#  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE    #
#  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.     #
PROJNAME := matmult
#   Name of the ARM GCC cross compiler
ARM_TOOLCHAIN_PREFIX  ?= arm-none-linux-gnueabi-
ifdef ARM_TOOLCHAIN_PATH
ARM_CC := $(ARM_TOOLCHAIN_PATH)/bin/$(ARM_TOOLCHAIN_PREFIX)gcc
else
ARM_CC := $(ARM_TOOLCHAIN_PREFIX)gcc
endif
# Pick up any ARM compiler and linker flags from the environment
ARM_CFLAGS = $(CFLAGS)
ARM_CFLAGS += -std=gnu99 \
-Wdeclaration-after-statement -Wall -Wno-trigraphs \
-fno-strict-aliasing -fno-common -fno-omit-frame-pointer \
-c -O3
ARM_LDFLAGS = $(LDFLAGS)
ARM_LDFLAGS+=-lm
#   Name of the DSP compiler
#   TI C6RunApp Frontend (if path variable provided, use it, otherwise assume
#   the tools are in the path)
C6RUN_TOOLCHAIN_PREFIX=c6runapp-
ifdef C6RUN_TOOLCHAIN_PATH
C6RUN_CC := $(C6RUN_TOOLCHAIN_PATH)/bin/$(C6RUN_TOOLCHAIN_PREFIX)cc
else
C6RUN_CC := $(C6RUN_TOOLCHAIN_PREFIX)cc
endif
DSPLIB_PATH := $(HOME)/C64x+DSPLIB/dsplib_v210
C6RUN_CFLAGS = -c -O3 -I$(DSPLIB_PATH) -DUSE_DSPLIB
C6RUN_LDFLAGS=
 楼主| coshi 发表于 2019-8-1 11:25 | 显示全部楼层
#   List of source files
SRCS := $(PROJNAME).c
ARM_OBJS := $(SRCS:%.c=gpp/%.o)
DSP_OBJS := $(SRCS:%.c=dsp/%.o)
#   Makefile targets
.PHONY : dsp dsp_clean gpp gpp_clean all clean
all: dsp gpp
clean: dsp_clean gpp_clean
gpp: gpp/.created $(ARM_OBJS)
        $(ARM_CC) $(ARM_LDFLAGS) -o $(PROJNAME)_gpp $(ARM_OBJS)
gpp/%.o : %.c
        $(ARM_CC) $(ARM_CFLAGS) $(CINCLUDES) -o $@ $<
gpp/.created:
        @mkdir -p gpp
        @touch gpp/.created
gpp_clean:
        @rm -Rf $(PROJNAME)_gpp
        @rm -Rf gpp
dsp: dsp/.created $(DSP_OBJS)
        $(C6RUN_CC) $(C6RUN_LDFLAGS) -o $(PROJNAME)_dsp $(DSP_OBJS) $(DSPLIB_PATH)/dsplib64plus.lib
dsp/%.o : %.c
        $(C6RUN_CC) $(C6RUN_CFLAGS) $(CINCLUDES) -o $@ $<
dsp/.created:
        @mkdir -p dsp
        @touch dsp/.created
dsp_clean:
        @rm -Rf $(PROJNAME)_dsp
        @rm -Rf dsp
源文件:
matmult.c
#include <stdio.h>
#include <stdlib.h>
#include <time.h>
#ifdef USE_DSPLIB
  #include "src/DSP_mat_mul/DSP_mat_mul.h"
#endif
// Random matrix fill
void matfill(int size, short *mat)
  int i, j;
  for (i = 0; i < size; i++)
    for (j = 0; j < size; j++)
      mat[j+size*i] = (short) (rand() % 100);
void printmat(int size, short *mat)
// Matrix multiply using Fixed point C64x+ DSPLib function
void matmult(int size, int shift, short *A, short *B, short *C)
#ifdef USE_DSPLIB
  DSP_mat_mul( A,size,size,
               B,     size,
               C,
               shift );
#else
  int i, j, k;
  int sum;
      sum = 0;
      for (k = 0; k < size; k++)
        sum += (A[i*size + k] * B[k*size  + j]);
      C[i*size + j] = sum >> shift;
#endif
 楼主| coshi 发表于 2019-8-1 11:26 | 显示全部楼层
//square matrices only
int main(int argc, char *argv[])
  short *A, *B, *C;
  int matsize, shift;
  time_t t;
  if (argc != 2) exit(-1);
  matsize = atoi(argv[1]);
  shift = 0;
  while ((matsize>>shift) > 0)
    ++shift;
  srand(time(NULL));
  if (matsize == 0) exit(-1);
  // Allocate space for matrices
  A = calloc(matsize*matsize, sizeof(short));
  matfill(matsize, A);
  B = calloc(matsize*matsize, sizeof(short));
  matfill(matsize, B);
  C = calloc(matsize*matsize, sizeof(short));
  // Perform multiply and time it
  t = time(NULL);
  matmult(matsize, shift, A, B, C);
  t = time(NULL) - t;
  printf("time of multiply: %d seconds\n",(int)t);
  // Free allocated spaces
  free(A);
  free(B);
  free(C);
运行结果:
root@dm37x-evm:/opt# for i in 100 200 300 400 500 600; do ./matmult_gpp $i; done
time of multiply: 0 seconds
time of multiply: 2 seconds
time of multiply: 6 seconds
time of multiply: 18 seconds
time of multiply: 39 seconds
root@dm37x-evm:/opt# for i in 100 200 300 400 500 600; do ./matmult_dsp $i; done
time of multiply: 1 seconds
time of multiply: 3 seconds
可见当数据量大时,DSP表现出来的性能优越性更明显。
