#include <reg52.h>
#include <intrins.h>
#define MAIN_Fosc 11059200UL //宏定义主时钟HZ
#define PCF8591_ADDR 0x90 //PCF8591地址
//#define DACOUT_EN 0x40 //DAC输出使能
#define uchar unsigned char
#define uint unsigned int
#define TemprStart 0
#define Scale 1
#define TableSize 71
#define us 5000;
sbit rs=P2^2;
sbit rw=P2^3;
sbit en=P2^4;
sbit SCL=P1^2;
sbit SDA=P1^3;
uchar code table[]={'0','1','2','3','4','5','6','7','8','9'};
const code NTC_Table[71] = { //温度
0xCA,0xCA,0xCA,0xC9,0xC9,0xC9,0xC9,0xC8,
0xC8,0xC8,0xC8,0xC7,0xC7,0xC7,0xC7,0xC7,
0xC6,0xC6,0xC6,0xC6,0xC5,0xC5,0xC5,0xC5,
0xC4,0xC4,0xC4,0xC4,0xC3,0xC3,0xC3,0xC3,
0xC2,0xC2,0xC2,0xC2,0xC1,0xC1,0xC1,0xC1,
0xC0,0xC0,0xC0,0xC0,0xBF,0xBF,0xBF,0xBF,
0xBE,0xBE,0xBE,0xBE,0xBD,0xBD,0xBD,0xBD,
0xBC,0xBC,0xBC,0xBC,0xBB,0xBB,0xBB,0xBB,
0xBA,0xBA,0xBA,0xBA,0xB9,0xB9,0xB9};
uint AD_Value;//0-65535
//int16 *pTemp;
//pTmp=NTC_Table;
//CuTemp=finetab[pTmp,TempSize,AD_Value];
//uint FineTab(uint *a,uint Tablong,uint data)
// uint st,ed,m;
// uint i;
// st=0;
// ed=Tablong-1;
// i=0;
// if(data>=a[st])
// return st;
// else if(data<=a[ed])
// return ed;
// while(st<ed)
// m=(st+ed)/2;
// if(data=a[m]) break;
// if(data<a[m]&&data>a[m+1]) ed=m;
// else st=m;
// if(i++.TabLong) break;
// if(st>de) return 0;
// return m;
float GetTempr(unsigned int AD_Value)
unsigned char i;
unsigned int SearchStart = 0 , SearchEnd = TableSize - 1 , SearchMax = TableSize;
if(AD_Value >= NTC_Table[SearchStart])
return (float)(SearchStart * Scale) + TemprStart;
if(AD_Value <= NTC_Table[SearchEnd])
return (float)(SearchEnd * Scale) + TemprStart;
for(i = 0 ; i < SearchMax ; i ++)
if((SearchEnd - SearchStart) > 1)
if(NTC_Table[ (SearchEnd + SearchStart) / 2 ] < AD_Value)
SearchEnd = ( SearchEnd + SearchStart ) / 2;
else if(NTC_Table[ ( SearchEnd + SearchStart ) / 2 ] > AD_Value)
SearchStart = ( SearchEnd + SearchStart ) / 2;
else
return (float)((SearchEnd + SearchStart) * Scale / 2) + TemprStart;
else
if((NTC_Table[SearchEnd] - AD_Value) >= (AD_Value - NTC_Table[SearchStart]))
else
return 0;
void Delay_Ms(uint ms)
uint i;
do{
i = MAIN_Fosc / 96000;
while(--i); //96T per loop
}while(--ms);
void Delay5us()
#if MAIN_Fosc == 11059200
_nop_();
#elif MAIN_Fosc == 12000000
_nop_();
#elif MAIN_Fosc == 22118400
_nop_(); _nop_(); _nop_();
#endif
void write_com(uchar com)//写指令
rs=0;
rw = 0;
P0=com;
Delay_Ms(5);
en=1;
Delay_Ms(5);
en=0;
void write_dat(uchar dat)//写数据
rs=1;
rw = 0;
P0=dat;
Delay_Ms(5);
en=1;
Delay_Ms(5);
en=0;
void I2C_Start()
SCL = 1;
_nop_();
SDA = 1;
Delay5us();
SDA = 0;
Delay5us();
函数:I2C_Stop()
描述:I2C停止信号
void I2C_Stop()
SDA = 0;
_nop_();
SCL = 1;
Delay5us();
SDA = 1;
Delay5us();
函数:Master_ACK(bit i)
参数:i 为0时发送非应答 为1时发送应答
描述:I2C主机发送应答
void Master_ACK(bit i)
SCL = 0; // 拉低时钟总线允许SDA数据总线上的数据变化
_nop_(); // 让总线稳定
if (i) //如果i = 1 那么拉低数据总线 表示主机应答
SDA = 0;
else
SDA = 1; //发送非应答
_nop_();//让总线稳定
SCL = 1;//拉高时钟总线 让从机从SDA线上读走 主机的应答信号
_nop_();
SCL = 0;//拉低时钟总线, 占用总线继续通信
_nop_();
SDA = 1;//释放SDA数据总线。
_nop_();
函数:Test_ACK()
返回:0为非应答 1为应答
描述:I2C检测从机应答
bit Test_ACK() // 检测从机应答
SCL = 1;//时钟总线为高电平期间可以读取从机应答信号
Delay5us();
if (SDA)
SCL = 0;
I2C_Stop();
return(0);
else
SCL = 0;
return(1);
函数:I2C_send_byte(uchar byte)
参数:byte 要发送的字节
描述:I2C发送一个字节
void I2C_send_byte(uchar byte)
uchar i;
for(i = 0 ; i < 8 ; i++)
SCL = 0;
_nop_();
if (byte & 0x80) //
SDA = 1;
_nop_();
else
SDA = 0;
_nop_();
SCL = 1;
_nop_();
byte <<= 1;
SCL = 0;
_nop_();
SDA = 1;
_nop_();
函数:I2C_read_byte()
返回:读取的字节
描述:I2C读一个字节
uchar I2C_read_byte()
uchar i, dat;
SCL = 0 ;
_nop_();
SDA = 1;
_nop_();
SCL = 1;
_nop_();
dat <<= 1;
if (SDA)
dat |= 0x01;
_nop_();
SCL = 0;
_nop_();
return(dat);
/*DAC输出*/
//bit DAC_OUT(uchar DAT)
// I2C_Start();
// I2C_send_byte(PCF8591_ADDR+0);
// if (!Test_ACK())
// return(0);
// I2C_send_byte(DACOUT_EN); //DA输出使能
// if (!Test_ACK())
// return(0);
// I2C_send_byte(DAT);
// if (!Test_ACK())
// return(0);
// I2C_Stop();
// return(1);
/*读AD数据*/
bit ADC_Read(uchar CON)
I2C_Start();
if (!Test_ACK())
return(0);
I2C_send_byte(CON);
Master_ACK(0);
I2C_Start();
I2C_send_byte(PCF8591_ADDR+1);
if (!Test_ACK())
return(0);
AD_Value = I2C_read_byte();
AD_Value=(5.0/255)*AD_Value;//读出电压
Master_ACK(0);
I2C_Stop();
return(1);
//void lop()
// AD_Value=(AD_Value/255)*5.0;//AD值
void init()
SDA = 1; //数据总线高
_nop_();
SCL = 1; //时钟总线高
_nop_();
// write_com(0x01);
write_com(0x38);
write_com(0x0f);
write_com(0x06);
void main()
uint a;
// int *pTemp;
//pTmp=NTC_Table;
init();
while(1)
if(ADC_Read(0x00));//判断AD是否输出
a=GetTempr(AD_Value);//带入计算
Delay_Ms(5);
write_com(0x80+0x00);
write_dat(table[a/100]);
Delay5us();
write_com(0x80+0x01);
write_dat(table[a%100/10]);
Delay5us();
write_com(0x80+0x02);
write_dat('.');
Delay5us();
write_com(0x80+0x03);
write_dat(table[a%10]);
Delay5us();
// write_com(0x80+0x04);
// write_dat(table[a%100/10]);
// Delay5us();
// write_com(0x80+0x05);
// write_dat(table[a%10]);
// Delay5us();
write_com(0x80+0x06);
write_dat('V');
Delay_Ms(5);
