[技术问答] N76E003 Timer0/1 Mode0 demo code
633|5
 楼主| darklighttt 发表于 2020-3-30 19:35 | 显示全部楼层 |阅读模式
  1. /*---------------------------------------------------------------------------------------------------------*/
  2. /*        */
  3. /* Copyright(c) 2017 Nuvoton Technology Corp. All rights reserved.                                         */
  4. /*        */
  5. /*---------------------------------------------------------------------------------------------------------*/
  6. //***********************************************************************************************************
  7. //  Nuvoton Technoledge Corp.
  8. //  Website: http://www.nuvoton.com
  9. //  E-Mail : MicroC-8bit@nuvoton.com
  10. //  Date   : Apr/21/2017
  11. //***********************************************************************************************************
  12. //***********************************************************************************************************
  13. //  File Function: N76E003 Timer0/1 Mode0 demo code
  14. //***********************************************************************************************************
  15. #include "N76E003.h"
  16. #include "Common.h"
  17. #include "Delay.h"
  18. #include "SFR_Macro.h"
  19. #include "Function_define.h"
  20. //*****************  The Following is in define in Fucntion_define.h  ***************************
  21. //****** Always include Function_define.h call the define you want, detail see main(void) *******
  22. //***********************************************************************************************
  23. #if 0
  24. //#define                TIMER1_MODE0_ENABLE                TMOD&=0x0F
  25. //#define                TIMER1_MODE1_ENABLE                TMOD&=0x0F;TMOD|=0x10
  26. //#define                TIMER1_MODE2_ENABLE                TMOD&=0x0F;TMOD|=0x20
  27. //#define                TIMER1_MODE3_ENABLE                TMOD&=0x0F;TMOD|=0x3F
  28. //#define                TIMER0_MODE0_ENABLE                TMOD&=0xF0
  29. //#define                TIMER0_MODE1_ENABLE                TMOD&=0xF0;TMOD|=0x01
  30. //#define                TIMER0_MODE2_ENABLE                TMOD&=0xF0;TMOD|=0x02
  31. //#define                TIMER0_MODE3_ENABLE                TMOD&=0xF0;TMOD|=0xF3
  32. #endif
  33. #define TH0_INIT        0xFC //5.0ms@XTAL=12MHz, Period = (10.85/2) ms@XTAL=22.1184MHz
  34. #define TL0_INIT        0x0F
  35. #define TH1_INIT        0xE0 //2.5ms@XTAL=12MHz, Period = (5.425/2) ms@XTAL=22.1184MHz
  36. #define TL1_INIT        0x00
  37. /************************************************************************************************************
  38. *    TIMER 0 interrupt subroutine
  39. ************************************************************************************************************/
  40. void Timer0_ISR (void) interrupt 1          //interrupt address is 0x000B
  41. {
  42.     TH0 = TH0_INIT;
  43.     TL0 = TL0_INIT;
  44.     P12 = ~P12;        // GPIO toggle when interrupt
  45. }
  46. /************************************************************************************************************
  47. *    TIMER 1 interrupt subroutine
  48. ************************************************************************************************************/
  49. void Timer1_ISR (void) interrupt 3          //interrupt address is 0x001B
  50. {
  51.     TH1 = TH1_INIT;
  52.     TL1 = TL1_INIT;
  53.     P03 = ~P03;        // GPIO toggle when interrupt
  54. }
  55. /************************************************************************************************************
  56. *    Main function
  57. ************************************************************************************************************/
  58. void main (void)
  59. {
  60.         TMOD = 0XFF;
  61.         Set_All_GPIO_Quasi_Mode;
  62.         TIMER0_MODE0_ENABLE;                        //Timer 0 and Timer 1 mode configuration
  63.         TIMER1_MODE0_ENABLE;
  64.
  65.         clr_T0M;
  66.         clr_T1M;
  67.
  68.         TH0 = TH0_INIT;
  69.         TL0 = TL0_INIT;
  70.         TH1 = TH1_INIT;
  71.         TL1 = TL1_INIT;
  72.
  73. //        set_ET0;                                    //enable Timer0 interrupt
  74.         set_ET1;                                    //enable Timer1 interrupt
  75.         set_EA;                                     //enable interrupts
  76.
  77.         set_TR0;                                    //Timer0 run
  78. //        set_TR1;                                    //Timer1 run
  79.   while(1)
  80.         {
  81.                 TH0 = TH0_INIT;
  82.                 TL0 = TL0_INIT;
  83.                 set_TR0;
  84.                 while(!TF0);
  85.                 clr_TR0;
  86.                 P12 = ~P12;
  87.                 TF0 = 0 ;
  88. }
  89. }
晓伍 发表于 2020-4-6 15:55 | 显示全部楼层
非常感谢楼主分享
八层楼 发表于 2020-4-6 15:56 | 显示全部楼层
非常感谢楼主分享
观海 发表于 2020-4-6 15:56 | 显示全部楼层
非常感谢楼主分享
guanjiaer 发表于 2020-4-6 15:56 | 显示全部楼层
非常感谢楼主分享
heimaojingzhang 发表于 2020-4-6 15:56 | 显示全部楼层
非常感谢楼主分享
