关于I2C的指针问题
563|1
 楼主| 考哥 发表于 2020-4-3 21:12 | 显示全部楼层 |阅读模式
uint32_t I2C_EE_PageWrite(u8* pBuffer, u8 WriteAddr, u8 NumByteToWrite)
  I2CTimeout = I2CT_LONG_TIMEOUT;
  while(I2C_GetFlagStatus(EEPROM_I2Cx, I2C_FLAG_BUSY))
    if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(4);
  /* Send START condition */
  I2C_GenerateSTART(EEPROM_I2Cx, ENABLE);
  I2CTimeout = I2CT_FLAG_TIMEOUT;
  /* Test on EV5 and clear it */
  while(!I2C_CheckEvent(EEPROM_I2Cx, I2C_EVENT_MASTER_MODE_SELECT))
    if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(5);
  /* Send EEPROM address for write */
  I2C_Send7bitAddress(EEPROM_I2Cx, EEPROM_ADDRESS, I2C_Direction_Transmitter);
  /* Test on EV6 and clear it */
  while(!I2C_CheckEvent(EEPROM_I2Cx, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED))
    if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(6);
  /* Send the EEPROM's internal address to write to */
  I2C_SendData(EEPROM_I2Cx, WriteAddr);
  /* Test on EV8 and clear it */
  while(! I2C_CheckEvent(EEPROM_I2Cx, I2C_EVENT_MASTER_BYTE_TRANSMITTED))
    if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(7);
  /* While there is data to be written */
  while(NumByteToWrite--)
    /* Send the current byte */
    I2C_SendData(EEPROM_I2Cx, *pBuffer);
    /* Point to the next byte to be written */
    pBuffer++;
    while (!I2C_CheckEvent(EEPROM_I2Cx, I2C_EVENT_MASTER_BYTE_TRANSMITTED))
      if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(8);
  /* Send STOP condition */
  I2C_GenerateSTOP(EEPROM_I2Cx, ENABLE);
  return 1;
oid I2C_EE_BufferWrite(u8* pBuffer, u8 WriteAddr, u16 NumByteToWrite)
  u8 NumOfPage = 0, NumOfSingle = 0, Addr = 0, count = 0;
  Addr = WriteAddr % I2C_PageSize;
  count = I2C_PageSize - Addr;
  NumOfPage =  NumByteToWrite / I2C_PageSize;
  NumOfSingle = NumByteToWrite % I2C_PageSize;
  /* If WriteAddr is I2C_PageSize aligned  */
  if(Addr == 0)
    /* If NumByteToWrite < I2C_PageSize */
    if(NumOfPage == 0)
      I2C_EE_PageWrite(pBuffer, WriteAddr, NumOfSingle);
      I2C_EE_WaitEepromStandbyState();
    /* If NumByteToWrite > I2C_PageSize */
    else
      while(NumOfPage--)
        I2C_EE_PageWrite(pBuffer, WriteAddr, I2C_PageSize);
        WriteAddr +=  I2C_PageSize;
        pBuffer += I2C_PageSize;
      if(NumOfSingle!=0)
  /* If WriteAddr is not I2C_PageSize aligned  */
  else
    if(NumOfPage== 0)
    else
      NumByteToWrite -= count;
      if(count != 0)
        I2C_EE_PageWrite(pBuffer, WriteAddr, count);
        WriteAddr += count;
        pBuffer += count;
      while(NumOfPage--)
      if(NumOfSingle != 0)
火哥为什么pBuffer指针在I2C_EE_PageWrite函数中自加了   I2C_SendData(EEPROM_I2Cx, *pBuffer);
    pBuffer++; 但是在I2C_EE_BufferWrite当中又加上页面大小呢? while(NumOfPage--)      {
        pBuffer += I2C_PageSize;他自加的时候指针不是已经跳转了8次吗?再加不就多了吗?另外那个WriteAddr地址变量不是写一个数据就直接跳到下一个地址吗?为什么还是要加页面大小?他在页写的时候都没有地址变量自加,说明他是自己跳转啊,为什么还要加页面大小呢?请指教
21ic小喇叭 发表于 2020-4-7 09:55 | 显示全部楼层
帮顶一下,希望问题得到解决
