ADC
390|0
张さん|  楼主 | 2020-4-24 17:18 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
#define CR2_EXTTRIG_SWSTART_Set     ((uint32_t)0x00500000)
void ADC_SoftwareStartConvCmd(ADC_TypeDef* ADCx, FunctionalState NewState)
  /* Check the parameters */
  assert_param(IS_ADC_ALL_PERIPH(ADCx));
  assert_param(IS_FUNCTIONAL_STATE(NewState));
  if (NewState != DISABLE)
    /* Enable the selected ADC conversion on external event and start the selected
       ADC conversion */
    ADCx->CR2 |= CR2_EXTTRIG_SWSTART_Set;
  else
    /* Disable the selected ADC conversion on external event and stop the selected
       ADC conversion */
    ADCx->CR2 &= CR2_EXTTRIG_SWSTART_Reset;
这里“#define CR2_EXTTRIG_SWSTART_Set     ((uint32_t)0x00500000)”把ADC_CR2的位22SWSTART和位20EXTTRIG都使能了,为什么呀?
