求助!我用stm32调38KHz,驱动不了红外发射管!急
539|0
 楼主| 考哥 发表于 2019-11-29 07:46 | 显示全部楼层 |阅读模式
[table][tr][td]
我用51单片机调试38kHz可以驱动红外发射管,可以接收。  但是我用stm32调pwm调38KHz就驱动不了,或者说是接收不到。这问题出在哪里呢?手头上只有数字万用表,测出来的频率也是38kHz,
接收头是市面上的38KHz接收头
<div class="blockcode"><div id="code_L7F">
  • #include "bsp_pwm_output.h"
  • static void TIM3_GPIO_Config(void)
  •   GPIO_InitTypeDef GPIO_InitStructure;
  •         /* ÉèÖÃTIM3CLK Ϊ 72MHZ */
  •   RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
  •   /* GPIOA and GPIOB clock enable */
  •   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB, ENABLE);
  •   /*GPIOA Configuration: TIM3 channel 1 and 2 as alternate function push-pull */
  •   GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6 | GPIO_Pin_7;
  •   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;                    // ¸´ÓÃÍÆÍìÊä³ö
  •   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  •   GPIO_Init(GPIOA, &GPIO_InitStructure);
  •   /*GPIOB Configuration: TIM3 channel 3 and 4 as alternate function push-pull */
  •   GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_0 | GPIO_Pin_1;
  •   GPIO_Init(GPIOB, &GPIO_InitStructure);
  • static void TIM3_Mode_Config(void)
  •         TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  •         TIM_OCInitTypeDef  TIM_OCInitStructure;
  •         /* PWMÐÅºÅµçÆ½Ìø±äÖµ */
  •          u16 CCR1_Val = 8;
  •          u16 CCR2_Val = 10;
  •          u16 CCR3_Val = 13;
  •          u16 CCR4_Val = 18;
  •   /* Time base configuration */
  •   TIM_TimeBaseStructure.TIM_Period = 25;       //38kHZ
  •   TIM_TimeBaseStructure.TIM_Prescaler = 71;            //ÉèÖÃÔ¤·ÖƵ
  •   TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1 ;        //ÉèÖÃʱÖÓ·ÖÆµÏµÊý£º²»·ÖƵ(ÕâÀïÓò»µ½)
  •   TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //ÏòÉϼÆÊýģʽ
  •   TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
  •   /* PWM1 Mode configuration: Channel1 */
  •   TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;            //ÅäÖÃΪPWMģʽ1
  •   TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  •   TIM_OCInitStructure.TIM_Pulse = CCR1_Val;           //ÉèÖÃÌø±äÖµ£¬µ±¼ÆÊýÆ÷¼ÆÊýµ½Õâ¸öֵʱ£¬µçƽ·¢ÉúÌø±ä
  •   TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;  //µ±¶¨Ê±Æ÷¼ÆÊýֵСÓÚCCR1_ValʱΪ¸ßµçƽ
  •   TIM_OC1Init(TIM3, &TIM_OCInitStructure);         //ʹÄÜͨµÀ1
  •   TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable);
  •   /* PWM1 Mode configuration: Channel2 */
  •   TIM_OCInitStructure.TIM_Pulse = CCR2_Val;          //ÉèÖÃͨµÀ2µÄµçÆ½Ìø±äÖµ£¬Êä³öÁíÍâÒ»¸öÕ¼¿Õ±ÈµÄPWM
  •   TIM_OC2Init(TIM3, &TIM_OCInitStructure);          //ʹÄÜͨµÀ2
  •   TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Enable);
  •   /* PWM1 Mode configuration: Channel3 */
  •   TIM_OCInitStructure.TIM_Pulse = CCR3_Val;        //ÉèÖÃͨµÀ3µÄµçÆ½Ìø±äÖµ£¬Êä³öÁíÍâÒ»¸öÕ¼¿Õ±ÈµÄPWM
  •   TIM_OC3Init(TIM3, &TIM_OCInitStructure);         //ʹÄÜͨµÀ3
  •   TIM_OC3PreloadConfig(TIM3, TIM_OCPreload_Enable);
  •   /* PWM1 Mode configuration: Channel4 */
  •   TIM_OCInitStructure.TIM_Pulse = CCR4_Val;        //ÉèÖÃͨµÀ4µÄµçÆ½Ìø±äÖµ£¬Êä³öÁíÍâÒ»¸öÕ¼¿Õ±ÈµÄPWM
  •   TIM_OC4Init(TIM3, &TIM_OCInitStructure);        //ʹÄÜͨµÀ4
  •   TIM_OC4PreloadConfig(TIM3, TIM_OCPreload_Enable);
  •   TIM_ARRPreloadConfig(TIM3, ENABLE);                         // ʹÄÜTIM3ÖØÔØ¼Ä´æÆ÷ARR
  •   /* TIM3 enable counter */
  •   TIM_Cmd(TIM3, ENABLE);                   //ʹÄܶ¨Ê±Æ÷3
  • void TIM3_PWM_Init(void)
  •         TIM3_GPIO_Config();
  •         TIM3_Mode_Config();       }
