能不能把枚举成员赋值给非枚举类型的变量
385|0
 楼主| スモモ 发表于 2018-6-7 11:10 | 显示全部楼层 |阅读模式
pi, IO, GPIO, gp, se
typedef enum
{ Bit_RESET = 0,
  Bit_SET
}BitAction;
uint8_t GPIO_ReadInputDataBit(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin)
  uint8_t bitstatus = 0x00;
  /* Check the parameters */
  assert_param(IS_GPIO_ALL_PERIPH(GPIOx));
  assert_param(IS_GET_GPIO_PIN(GPIO_Pin));
  if ((GPIOx->IDR & GPIO_Pin) != (uint32_t)Bit_RESET)
    bitstatus = (uint8_t)Bit_SET;
  else
    bitstatus = (uint8_t)Bit_RESET;
  return bitstatus;
